last edit...
Ionization & Water Fuel
@Tim
Thanks Tim, the record can show that you and h2opower concede to the
fact that they cannot answer these questions.
So, basically, TIM (h2opower's messenger):
1. why does h2opower claim there is almost no nitrogen dissolved in
water when Meyer says it is 17% - 17% is HUGE.
2. why does h2opower claim nitrogen is just getting in the way when
Meyer spells out that the ionized gas, which IS ionized air, mostly nitrogen,
is receiving the electron from the splitting of water, splitting of water gas,
splitting of vapor, etc... bottom line, the nitrogen is absorbing the electron
to keep the hydrogen and oxygen from recombining.Sincerely,
nitrogen doesn't just "get in the way"
"electrons are ejected from the water molecule and absorbed by ionized gases" - Stanley MeyerSincerely,
Bad news
I have some bad news for the ionization theory...
No electron or ion positive or negative or charge can remain charged inside the cylinder of an engine under pressure without discharging instantaneously by the millions of contacts per sec (gas molecules shake or collides like crazy under pressure) contact with the cylinder metal! Also because of the same effect on van de graf. Because no electron or charge can stay in the middle of a conductor! (the cylinder)
Hi Isolating Hi Temperature and self lubricating Ceramics need to be used to cover the cylinder and the head and piston!
The engine must be charged entirely!
This way ionization may have a sense! For a specialist in molecular Physics
She said that using Led Is possible to help the energy aperture of the atom to help giving to it a charge because of a principle that two low energy photons can reach the atom at the same time.
If i was you guys, i would stop guessing and would really study molecular physics, materials physics, and plasma physics...
I'm already doing this!
I hope my words could help!
Oxygen love electrons!
Nitrogen in atomic configuration is very reactive
N2 conversion into N + N is endothermic. Needs energy!
She said that de-energized water molecule does not exist and that this can maybe mean that he created other type of molecule as exhaust...
She said that H3O+ Or OH- as i proposed is not possible because how combustion happen, and that H3O+ or H+ can exist only in water form.
You still don't understand the humans.
spark circuit
I see, thanks.Originally posted by VickersIf you remove the switch, the diode and , the coil so that the only way the cap will discharge is with a dead short at plug electrodes...., What do we have to add to our fuel to get our dead short?
And if our fuel making process consists of air, water and electricity..., What kind of spark plug (that we can buy from any auto parts store) will be best suited to the process?
So, you want the fuel/air mixture to be the trigger for the cap to discharge
across a gap that is bigger than the the voltage of the cap can jump
on its own.
If the air itself is ionized, it is a conductive medium that can cause a spark
across a gap at relatively low voltages...lower than what is supposed to
jump the gap without the conductive air. I don't know if a 400v cap
for example can jump a sparkplug with just ionized air, I'm sure it is possible
but don't know how practical.
With the vapor or liquid fuel, water, nh3, whatever, there is going to be
some conductivity but I think it is mostly going to be misted instead of
a good solid drop that will short the gap on the plug so I think HV is still
needed.
Whatever the case may be, surface gap geometry is what Peter and I
had the best results on our lawnmower tests - that was with humidifier
hot moisture mixed with nothing but gas vapor...we had the jet turned
all the way in so just the idle jet was letting in some gas but we were
able to get full power at full throttle with the plasma, hot moisture and
gas vapor. The plug that we used simply had the j-strap cut off and ground
smooth (around the rim).
You can buy resistor-less surface gap plugs off the shelf. Not all shops
carry them. Not sure if they're available in tungsten. But you can sure
order them online. Champion, NGK and most main companies make them.
And if they are in tungsten, it will only be the center electrode.Sincerely,
Give facts to back up the bad news
Explain how Ashtweth can measure current in the GEET pipe then. Explain why no one need ceramic coating on 80% water as fuel in a GEET system. French even dare to use it on helicopter!Originally posted by sebosfato View PostNo electron or ion positive or negative or charge can remain charged inside the cylinder of an engine under pressure without discharging instantaneously by the millions of contacts per sec (gas molecules shake or collides like crazy under pressure) contact with the cylinder metal! Also because of the same effect on van de graf. Because no electron or charge can stay in the middle of a conductor! (the cylinder)
It is impossible for all molecule in the pipe to be in contact with the metal, it will be only part of it. Metal corrode if there is constant DC polarity. If the metal is same, there would be no corrotion since all would have the same charge, same voltage, same polarity.
The bolt at a bridge corrode because different metal create a potential that will allow electrolysis process to happen. Salty water accelerate the process. The one that corrode first is the more positive one. This also show that you need a conducting liquid for corrotion. How many ohm is ionized air?
Originally posted by sucahyo View PostExplain how Ashtweth can measure current in the GEET pipe then. Explain why no one need ceramic coating on 80% water as fuel in a GEET system. French even dare to use it on helicopter!
Please explain how a gas inside a conductor get ionized.Originally posted by sebosfato View PostThe fact that the gas enter inside the engine and the engine is a conductor, get all the possibilities of having or at least think that this air is ionized.
Are you suggesting that air inside van degraf copper sphere will react too not just betweent the HV polarity?Originally posted by sebosfato View PostI believe that if you charge the all engine maybe positively, this could be possible but is very hard since it will be discharging into the ground.
Hi sucayo I wanted to mean
The fact that the gas enter inside the engine and the engine is a conductor, (similar to a van de graf or a cylinder) (and grounded) cancel all the possibilities of keeping air minimally charged or "ionized".
This is because no electron can remain in the middle of a conductor.
Think of a metallic sphere and you put an electron inside of it. It will immediately move toward the metal just because of the geometry even not having a voltage. !!!
Thats why in the van de graf generator they charge the sphere from inside, this way they can always charge and charge and again charge because inside the sphere the electric charge will always be zero. This is how its possible to generate millions of volts with a piece of plastic...
I aways believed that the fact that meyer used the positive electrode the outside cylinder had something to do with this!!! I believe that somehow he used this geometric configuration to lower the needed energy to accomplish the electrolysis. The delrin around and inside the cylinders even should help by allowing the cylinder to hold the charge.
All i'm saying is that inside a van de graf the charge should be zero. or inside an engine or inside a tube.
And that if you put an ion inside this cylinder it will readily discharge.
I was guessing that if you could charge the entire engine than something would change. But i'm not sure of it. But if you think about, having the engine charged positively, when you inject positive ions, when they touch the cylinder they should not discharge because it is already charged up to 40kv where corona is already happening...
I believe that this is one of the reasons why he used a buggy simple engine...
I think that if we could have the piston at least covered with ceramic but having a small point in the top of it metallic, and the block of the engine isolated by some ceramic, we could generate electricity, straight from combustion. Because when the explosion happens is quite easy to have a voltage as result of the plasma (explosion) + van de graf effect + theromoelectric.
Maybe the spark plug can do this for us... to be this isolated positive contact.
If we could have a car with two spark plugs we could measure if there is voltage in the other while leaving it disconnected... I guess
If we have plasma as exhaust crossing magnetic fields MHD electricity could be generated.
( maybe one could do this test )
would require a high voltage dc probe to measure the charge accumulated in the cylinder.
To put the spark plug in a metallic cylinder and just apply 40kv negative in the center electrode of the spark plug and see what happen. with the voltage
and if a spark could happen...
thermionic emission
Have you considered thermionic emissions from different hot metal(s) in the engine?Originally posted by sebosfato View PostThis is because no electron can remain in the middle of a conductor.
Also, the heat of the mixture from pressure?Sincerely,
I believe in the attraction and repulsion theory. The enclosing wall may have polarity, the ion that is most opposite with the wall polarity will try to get closer, and the ion that is most similar will try to distance.Originally posted by sebosfato View PostThe fact that the gas enter inside the engine and the engine is a conductor, (similar to a van de graf or a cylinder) (and grounded) cancel all the possibilities of keeping air minimally charged or "ionized".
I don't use electron stripping theory.Originally posted by sebosfato View PostThis is because no electron can remain in the middle of a conductor.
I don't understand. Even if the wall more negative than the electron?Originally posted by sebosfato View PostThink of a metallic sphere and you put an electron inside of it. It will immediately move toward the metal just because of the geometry even not having a voltage. !!!
I think electrolysis need potential difference, if there is no potential difference, how charging the car help electrolysis?Originally posted by sebosfato View PostI aways believed that the fact that meyer used the positive electrode the outside cylinder had something to do with this!!! I believe that somehow he used this geometric configuration to lower the needed energy to accomplish the electrolysis. The delrin around and inside the cylinders even should help by allowing the cylinder to hold the charge.
How do we charge the whole car positively? We charge it more positive compare to what?Originally posted by sebosfato View PostI was guessing that if you could charge the entire engine than something would change. But i'm not sure of it. But if you think about, having the engine charged positively, when you inject positive ions, when they touch the cylinder they should not discharge because it is already charged up to 40kv where corona is already happening...
I think it is easier to capture vortex iduced electricity than by movement.Originally posted by sebosfato View PostI think that if we could have the piston at least covered with ceramic but having a small point in the top of it metallic, and the block of the engine isolated by some ceramic, we could generate electricity, straight from combustion. Because when the explosion happens is quite easy to have a voltage as result of the plasma (explosion) + van de graf effect + theromoelectric.
