Ionization & Water Fuel
  • #76
    Meyer's confusion
    Originally posted by tutanka View Post
    YOU CLEAN UP YOUR MIND FROM MEYER CONCEPTS.. MEYER DRUNK ITS READERS
    Yes, but I did point out that you are saying something different apparently.
    • #77
      nitrogen - natural EEC
      I can't ask clear but nitrogen is used outside and inside chambre of reactor.. and .. only inside is used as natural EEC
      Ok, I feel progress. I can see nitrogen as being an attractor for free
      electrons. Thank you!
      I think that is significant.
      • #78
        ionization by collision
        This is a good reference on gas ionization I posted a few times before
        but looks like the original site disappeared!
        K9 Passage of electricity through gases
        • #79
          H2no3
          EDIT - I thought this abstract was about Nitrogen Hydroxide but it is about
          Nitrogen Hydroxide Oxide. I'll leave it anyway. If anyone wants to explore
          Nitrogen Hydroxide, please use this thread:
          If there is confirmation that Nitrogen Hydroxide is the molecule, then
          I guess there is a very specific direction this thread can take at that time.
          Wiley InterScience :: Session Cookies
          Cover Picture: Experimental Detection of the H2NO3 Radical (ChemPhysChem 10/2003)
          Fulvio Cacace, Prof. Dr. *, Giulia de Petris, Prof. Dr. *Italy, Fax: (+39)06-49-913-602
          email: Fulvio Cacace (fulvio.cacace@uniroma1.it)**Keywords
          Abstract
          The cover pictures showsDigital Object Identifier (DOI)
          10.1002/cphc.200390107 About DOI
          • #80
            Are you saying you're using an injector as the wfc instead of an
            electrolysis cell? I understand that Meyer's injector is to split water locally
            instead of in a WFC. Obviously the reaction is possible with a WFC, which
            is more practical for everyone to build instead of custom injectors.
            I don't believe in a magical mix of ambient air without nitrogen.
            NO is naturally occuring in the air and I suppose it can be created in the
            AP. NO is a free radical so therefore it is positively charged. When NO
            is in the presence of other oxygen, it will attract the oxygen to produce
            NO2 (nitrogen dioxide - ONO).
            NO2, or nitrogen dioxide you say
            You say you only use AMBIENT AIR in your AP or GP. However, you have
            posted in the other thread that the AP processes ambient air and the
            GP processes water.
            Yes, I understand the ionized gas mixture is also a plasma - different
            from plasma from spark plug.
            But if you're talking about only processing AMBIENT AIR, does that mean
            you are only using AP now and not GP for water? If so, I think it needs to
            be clarified because you distinctly pointed out that the AP does air and
            the GP does water (steam) as indicated by your diagram above.
            Are you saying that you have moved past all of that and have evolved
            your process since you posted this steam processor? It would make a
            difference to know this - otherwise, it looks like a contradiction.
            If you're treating ONLY AMBIENT AIR, then the HHO/HOH moisture is
            simply ducted into the AP outlet and they come together.
            So first reaction externally is the mixing of the HHO/HOH with the
            positively charged ambient air of N and O. This mixing or blending or
            ducting together is the first process.
            The "NEUTRAL" PLASMA is the balance of positively charged air and
            HHO with water moisture. Creating this "neutral plasma" is the first
            step in the reaction and is created before anything enters the intake
            valve.
            Therefore the GP that negatively charges the steam is not needed for
            a more advanced and simplified process? So can we say the GP or
            steam processor that negatively charges the steam is an older step that
            you have moved away from and is no longer necessary?
            Second, that mixture entering intake valve under vacuum creating
            NITROGEN HYDROXIDE. Compression comes up, it is heated and pressurized.
            "Heat ionizes the mixture" and I'm sure it is quite homogenized at this point.
            During the entire intake, compression and partial down stroke, that is
            ENOUGH TIME to have the neutral plasma mix together. The heat and
            pressure heats the mixture and the mixture tries to expand against the
            compression. Piston goes down a bit and mixture is allowed to expand
            a bit more.
            "plasma capacitor have two characteristics very important respect to other. However Nitrogen and oxygen have very important part, first and on the reaction inside chambre of reactor"
            The neutral plasma is like a capacitor that lets it energy out when the
            plasma ignition hits it.
            Yes, this is my old idea but I need to create mixture fuel and that isn't needed or only in part..
            • #81
              Allotropic Nitrogen
              Ok, thanks Tutanka. I really appreciate your patience. I'm not sure if
              anyone else is excited about this as I am but I think the lights are turning on.
              Just bumped up this thread on Allotropic Nitrogen. You might find the
              first post interesting. Anyway...
              • #82
                I'm not sure if
                Aaron, I am just as excited as you and am following this thread closely. Because it just so happens that I am also experimenting with air ionization with HV now, also I have some experience with plasma spark and hho. So I have all the building blocks if you can say that, we just need to find how to get them together properly.
                I would like to thank Tutanka and others for all the info you can share And I totally understand if there is something you can't share.
                Jetijs
                • #83
                  http://www.energeticforum.com/renewa...-nitrogen.html
                  Active Nitrogen or Atomic Nitrogen is very reactive
                  • #84
                    @Jetijs
                    Jetijs
                    Cool! It just so happens I was going to ask YOU and a few others with good
                    quality cells to try it out! I was wondering if you were the engineer
                    mentioned or not. You certainly are capable!
                    • #85
                      Thanks Tutanka!
                      I've lost a bit of sleep over this. lol
                      That active nitrogen is very interesting and has been used
                      in what I think is a nitrogen capacitor that gets charged and
                      discharged. It has been used in some interesting gas tubes
                      with curious electromagnetics turning rotors, etc...
                      Seems evident that this really is the key that everyone
                      needs - it seems self apparent now - after the fact
                      Anyway, thanks Tutanka and I'm sure some people will
                      post some experiments with this. I have to wait until my
                      shop warms up early spring. My wfc right now is a frozen
                      container of ice.
                      Thank you thank you!
                      • #86
                        ionizer
                        I found this patent last night, very simple circuits to either positively
                        charge air, negatively charge it or both.
                        Ion emitting hot air blower - Google Patent Search
                        • #87
                          Allotropic or Active Nitrogen
                          Everyone should read this, it is the "original" active nitrogen experiment
                          by exposing nitrogen to hv.
                          • #88
                            Very good example As you can see all start from AC and grid numbered 120 is more similar to EEC of Meyer but instead to have light bulb have only an simple resistor R1.
                            • #89
                              Please read all...
                              H2OPOWER WROTE: As you can see I am not perfect I make mistakes all the time
                              • #90
                                Here is the full post so my words are not taken out of context: http://www.energeticforum.com/82397-post1485.html
                                h2opower.
