Originally posted by tutanka
Ionization & Water Fuel
Sorry but what you want obtain from reaction?? You need to know how appear when you use UV field. If you use UV-C field you obtain some O3 (ozone), if you use UV-A field you obtain ionization of water.. you have to see Lens experiment. But if you want start casually tests you lost only time and moneysOriginally posted by sucahyo View PostWhy should we avoid ozone? If the reaction produce ozone then it should make the other gas react better too?
Ok, thanksOriginally posted by tutanka View PostSorry but what you want obtain from reaction?? You need to know how appear when you use UV field. If you use UV-C field you obtain some O3 (ozone), if you use UV-A field you obtain ionization of water.. you have to see Lens experiment. But if you want start casually tests you lost only time and moneys
Sucess in building the ionizer with the help of 4 x 2.2 MOhm resistor. I rectify current with 4 diode in series. Still not try it on verhicle yet. Currently try to run it for hours. The transistor is cool.Originally posted by tutanka View PostHi Sucahyo,
How proceed your work/study?
555 based driving car coil, draw 80mA at 12V.
Still figuring out a way to isolate the voltage leak. Even the transistor is sparking now. And when the output is near any metal or ground object it start sparking. Still use small gap though. Will try to make it bigger.Last edited by sucahyo; 03-17-2010, 08:28 AM.
First step is to see if ionizer increase rpm. Will see if sparking surface is better than non sparking one. Currently testing on experiment table by smelling ozone. If it work will try with water spray and see if the gas processor can ionize water droplet fast enough.Originally posted by tutanka View PostHI Sucahyo,
Your project is build gas processor? and how you want process??
If I can made a complete hho cells, will try it with hho output too. The gas processor should at least prevent H2 and O2 from hho booster output from recombining longer than few seconds.
+ or -
The question thats on my mind is which type of ions we need.
Do we need the human friendly negative ions or the positive ions from the ambient air?
Tutanka? Others?
My current setup is so that i can make or positive or negative ions.
The negative ions are more fun to test with. The airflow coming out the tube feels cold .....and if you are having a hangover from alcohol these negative ions make you sober in no time....(well, it feels like it do so)
Steve
At this time I don't have understand if you use ions for process water, only air or togheter??Originally posted by stevie1001 View PostThe question thats on my mind is which type of ions we need.
Tutanka? Others?
Steve
The proces is:Originally posted by tutanka View PostAt this time I don't have understand if you use ions for process water, only air or togheter??
HHO injection into intake manifolt
Ionized ambient air into the air intake.
The other option could be HHO and ambient air together thru ionizer and then into the engine.......
Steve
Steve,Originally posted by stevie1001 View PostThe proces is:
Steve
Your words don't have sense for me.. how you want obtain as result? What is your chemical formula? As I have previously written nothing is magic.. Regards
I think we all read the theory. Creating a new kind of molecule which burns slower then the basic HHO.Originally posted by tutanka View PostSteve,
So, what are the options?
We have:
Ionized Nitrogen, oxygen, hydrogen.
I hope we can get some Ammonia at the end, to be honest.
Suc: Why you think we need + and - ions? The ionized atoms all want stability.
So, if they are missing electrons, they WILL steel it. They take free floating electrons or the seek a bond with other atoms...
I seek a way to let them combine into ammonia atoms, which is a better fuel for ICE then HHO.
Steve
