First of all i'm not here to raise interest in my project.
I'm here only to try making you think!
You keep running away from my questions. I will answer yours anyway.
Bmw used compressed h2 in a car and it works as perfect as gasoline. So my hydrogen is going to work like a charm in any engine. You just need to understand that hydrogen must be injected using like direct injection (like diesel) common rail...
Sebosfato.. your answer is finally clear and from that I understand that you don't have experience of endothermic engine.
You know that BMW have abandoned tests on hydrogen??
Also because you can INJECT ONLY hydrogen inside cylinder but in that way you lost some HP power, why? Compression of mixture burnable increse HP inside your engine. But you cannot aspire hydrogen inside your engine because exits everywhere. You can try how I ask using little H2 tank and an little engine.. However you are trying to produce on car a lot hydrogen and use directly inside engine..right? FOR SECURITY USAGE .. any government authorize you to distribute your system because is very very dangerous .. and.. as you know hydrogen use cryogenic tank and high pressure inside car but also with that car have limited autonomy because you need a lot of hydrogen for obtain same power of gasoline.
IN THAT WAY YOU CAN'T USE DIRECT HYDROGEN WAY ON AN CAR AND THE SAME FOR HOME USAGE.. VERY DANGEROUS FOR USERS!! NITROGEN is the key for more things and as final result you obtain new molecules with correct atom mass.. also bipolar voltage of air processor is important.. because not only N(OH)2 is created with the process..
Sucayo read your answers and think to your self if you have being enough specific as i'm requiring.
Aron Yes i have youtube channel is YouTube - sebosfato's Channel
You will find info on my concept and my first prototypes that allowed me to discover everything.
tutanka i guess i answered your question. Now please answer mine questions.
Sebosfato.. your answer is finally clear and from that I understand that you don't have experience of endothermic engine.You know that BMW have abandoned tests on hydrogen??
but you can also inject more gas if you want to have a very similar burning. There are endless possibilities with enough gas in hand. And is clean and free.
and you don't want radioactivity mixed with water. And you may want the water to reform. so
My air processor used special circuit double HV output 30+30Kv, the main output is AC, the other (grid) negative DC. With that I obtain positive/negative ions..
