The "real" injector and VIC coil 6-1
  • #16
    Stan's injectors
    Hello,
    I watched again that well known video, pointed out by Dankie here, on Stan presenting his injector, and I was shocked to see the real length of it, at second 46, at time to install the injector on the engine, we can clearly see that it's much longer than the hand of that guy ! It's like 8-10 inches long !
    video : Dailymotion - OIL VersuS WATER THE WATER FUEL INJECTOR, a video from HalfGasHalfWater. oil, versus, water, the, injector
    Commented picture:
    Congratulations Ashtweth for your hard work of compiling all the thousands pages of data from internet, forums, patents, exclusive disclosures and personal experiments, and to put it in easy to read pdf files !
    I know it's lots of hours you must spend daily on this staff, and all for free !
    So I just want to point out that it's VERY useful what you are doing, and that we all should try to do a little bit in that direction. If I had no time to give I would send you some money to develop further experimentation.
    I hope you can find donators for your research center project soon !
    Good luck all,
    MDG.
    • #17
      great vision
      Gauss- Dont be worried... keep this simple... this is very good for the enviroment...Stop with the physics and experiment...
      stephenfrater- Yes , the size is quite is quite big... almost as long as Stans hand , Stan was a big buy ... But it was more like 6-7 inches long...
      Anyways we can see that the whole injector is unnecessarely big compared to the end tip , only the end tip contains water so my guess is that it could have been much smaller if it was powered by an external power-source... Most likely that means there is an extra component in there...
      The coil can be made small as i said before , 1260 feet of .005 stainless is small but reaches 22,200 ohms like stan requires , 11,600 ohms on each coil...
      I am going in this direction.... and i have devised a plan to get donations...
      I am selling some very elusive and hard to get some already coated heavy polyamide-amide 220 degrees 36 awg 430FR high silicon "magnetic inductive" wire for the cheapest price on planet earth , guaranteed.
      • #18
        Regarding part 10 of the video : The nature of what Stan means by "opposing voltage"
        After Studying Stans work , i concluded that it it revolutionnary technology with many groundbreaking new electromagnetic concepts fused together in a specatular human engineering achievement . I concluded this after a result of elimination . It is a mix of Avrakenko's single wire reactance transmission , and a mix of "scalar net zero fields"
        This is indeed a net zero field that is meant here , knowing this , and going by the apparent lenght of the injector , i'd say this "scalar possibility" seems very plausible
        Knowing this , If the potential field (and here I mean the vector potential as it vibrates longitudinally) plays an important role in Meyer technology, then I think it works more as a "solvent" of the covalent bonding, weakening it. How? As the vector potential changes, so does the quantum phase of an electron, that much is known fact in physics (it's a variation of the Aharanov-Bohm effect). So the covalent electrons would be affected at their most fundamental level, which may change their relation to the hydrogen and oxygen nuclei enough to weaken then bonding. That last part is just my speculation.
        Its interresting to see tho , what Hutshison managed to do with solid metal and his tesla coil , he litterally made jelly out of solide metal , so why cant we "make jelly out of water" ... make it even more liduid that liduid state lol ....
        Once loosened, you then also need an actual DC electric field to pull the water molecule apart ( electrical polarization process). It would then pull apart easier than without the "solvent" action of the potential field. So the stainless steel tubes are still necessary and must be in contact with the water. The tubes would function as a longitudinal vector potential antenna on top of providing the DC field/current to tug on the water molecule. Wouldnt a net zero field be the same as our initial condition ?
        Let's say you hooked up the WFC as indicated. The voltage on both sides of the cell would then be equal since that is the nature of a single-wire transmission line. Therefore no voltage difference exists across the water gap, and no electric field, and thus no electron current either. However, the voltage, despite being equal across the gap, still changes over time due to the whole thing being powered by a tesla coil. Therefore the water would be exposed to a gradient-free time-varying scalar potential as I wrote in the post above. Perhaps this alone will not split the water. That's why Avramenko in that article said there was only a cold plasma, and no gas-generation. But -- if on top of this field, you added a small DC field (say from a 12 Volt supply), then you would be exerting a polarizing stress onto the water molecule that is already being exposed to this exotic Avramenko energy. That is what occurs in the Meyer VIC circuit if you hook up the bifilar coil with both coils in phase.
        That's why I suspected the two same high voltages were being applied to inner and outer tubes of the WFC so that without a voltage gradient between the two (except the one maintained by the blocking diode) there is no additional current flow through the water from the high voltage and thus water conductivity from impurities wasn't a factor.
        You could have a gradient-free scalar potential field that oscillates over time. What kind of work does this produce? Well, the Lorentz gauge shows that divergence of the vector potential is proportional to the time rate of change of scalar potential. Further, divergence of the vector potential is also proportional to charge density. Therefore if you have an oscillating voltage field, gradient-free, you would have oscillating charge density. This means the water molecule, being a dipole, would shrink and expand when exposed to such a field. The field would shrink and expand the electron shells too, perhaps switching off that covalent bonding electron pair and allowing the DC field maintained by the blocking diode to easily pull apart the water molecule.
        [For those of you unfamiliar with those terms, scalar potential is basically the 'voltage' field from which an electric field arises when there is a gradient in it, while vector potential, aka "A-vec", is the 'flux' field from which magnetism arises when there is circulation in it].
        If you notice in this montage from chapter 7/8 , Stan mentions a "non-voltage shift" , the "amp-inhibiting coil" is indeede balancing this to perfection so we end up with "total and perfect annihilation" of the two opposing waves
        • #19
          YouTube - New Energy - Colorado 1993 - 6
          This is the video where Stan talks about the VIC-coil
          • #20
            Now for part 10 of the video ....
            YouTube - New Energy - Colorado 1993 - 10
            • #21
              This is Stan's video . O GOD !!!
              • #22
                I think this is a good idea
                • #23
                  This has been fun , c you all later ...
                  • #24
                    injector/vic replications
                    Dankie,
                    I would love to see any replications you can show us.
                    • #25
                      Dankie,
                      Hmmm come to think of it, I have not seen this "person's" replication attempts posted here, only posts which are adverse to REAL experimenters, and info on how to purchase "ferritic wire"
                      seems fishy to me.
                      Wanna know the future? GOD Wins !!
                      • #26
                        I understand you are lacking education so you are hating on me.
                        But Aaron knows i am still in the planning stages and his comment was genuine.
                        There is indeed heavy necessity for this wire , You need to eliminate the "real world" amps and concentrate on voltage ... The reactance and coupling factor of this particular coil makes this possible .
                        Listen to the video closely... its not me thats telling you this , Its Stan ...
                        YouTube - New Energy - Colorado 1993 - 5
                        Now for some interresting quotes..
                        Inductance of the positive choke performs "Capacitance Charging Effect"; while, at the same time, Inductance of the negative choke restricts electron movement
                        negative choke locks onto Electrons Magnetic Field to block the movement of electron flow toward Positive Voltage Potential... thereby preventing and inhibiting electron-flow to pass through or arc-over water-capacitor gap, such electron blocking action is herein called "Electron Inhibiting Effect".
                        Electron Inhibiting Effect in direct relationship to Voltage Enhancement Effect is accomplished since stainless steel 430F/FR wire-material is "Electromagnetic Inductive" to incoming electromagnetic flux-lines without inductor-wire-coils becoming permanently magnetized... paralleling and performing the same electromagnetic characteristic of copper wire when it comes to magnetic field reformation that encourages, brings-on, and perform Voltage Inducement Process without amp "influxing" (inhibiting amp flow) between Positive Voltage Potential and Negative Voltage Potential electrically applied across Resonant Cavities."
                        In Retrospect, the use of Stainless Steel composite coil-wire (430FIFR) consists of both
                        inductance and resistive properties (typically .0048 ohms per foot) Huh?? which when combined together in
                        metallurgical form aids amp restriction beyond the singularly use of self-inductance magnet (Copper)
                        coil-wire having a lower resistive value. Stainless Steel bifiar Coil-Stage Assembly (is electrically placed
                        between Magnet Coil-Stage Assembly and Water Gap (Cp) to obtain optimum Voltage to Amp Differential Ratio
                        (V highest : A lowest ratio).
                        Together, Coil Stages added/stacked sequentially into a single overall coil-array assembly forms
                        Amp Inhibiting Network as to (970) of Figure (10-1) (hereinafter called VIC Multi-Coil Spool Assembly).
                        The magnet Coil-Wire is best suited for Voltage inducement while the inductance/capacitance/resistance
                        properties of Stainless Steel coil-wire is appropriately used to restrict electron movement beyond the self-inductance
                        of each energized coil when elevated voltage levels (up to beyond 40 kilovolts) are to be reached/obtained
                        without experiencing any appreciable amount of "Amp Influxing." Generally, magnet coil-wire length is longer
                        than the Stainless steel coil-wire length and magnet bifilar-coil is placed on top of Stainless Steel bifilar-coil
                        to maximize mutual inductance coil-field (Rp2) (adding Rp1+Rp2) of (690) of Figure (7_8) to cause coil
                        capacitance (Cda xxx Cdn) to help maintain and even increase pulse voltage amplitude (xxx Vn + Vn 1 + Vn2 + Vn .... etc.)
                        while the resistive value (Rs2) of SS Coil-Wire performs the work of further resisting the flow of amps not
                        inhibited by both self-Inductance fields (Rpl + Rp2), as so illustrated in (690) of Figure (7_8).
                        ImageShack - Image Hosting :: 4302ao9.jpg
                        ImageShack - Image Hosting :: 430or5.jpg
                        • #27
                          Phew
                          anyway, here is the tech data sheet for 430 (content copying is allowed by author)
                          • #28
                            It's time to investigate Meyer equations.
                            • #29
                              Yeah its time to investigate the Meyer Equations ...
                              And its time to build this coil .
                              Everybody buy some wire from me and lets all build together this holidays .
                              • #30
                                Is it not clear the chokes should be wound bifilar to inhibit amps and amplify Voltage? That is what I have learned.
