I've been digging around the net and have found just enough info on this to be curious. Has anyone here ever tried it. If it works it sounds easier than trying to replicate an electronic circuit. Any information that you may pass along would be appreciated.
Nitrogen Hydroxide ?
Nitrogen Hydroxide
Nitrogen Hydroxide - valid?
Positive charged air + HHO/HOH enters vacuum during intake and possibly
makes nitrogen hydroxide?Sincerely,
hope hope
Would be nice
lol
I'm still going to do the experiment even if I don't understand it.Sincerely,
Nitrogen Hydroxide
"nitrogen hydroxide" - Google Search
Wiley InterScience :: Session Cookies
H2NO3
H2O + ONO + ion = N2NO3
That has a lot of claims about nitrogen hydroxide. I don't want to put
all this in the Ionization & Water Fuel thread if it is off track and I
don't want to clutter that thread with this if not relevant.
Alternative Science and Technology Research Organisation
NEMO ALERT: Australian Fuel System Alternate-Energy
(N(OH)2O) or N(oh)2 or NH4OH or
water fuel systems
Operating Unit
Untitled Document
YouTube - Nitrogen Hydrogen Booster- WFC
OUPower.com :: View topic - mrgalleria, can you test the Nickel again?
AHANW Forums - Dingel's Magic Car and How It Could Save the World
Self-consistent-field calculation of nitrosyl hydride and nitrogen hydroxide - Inorganic Chemistry (ACS Publications)
HHO
HHO Cell Kit
The Water Engine - The water engines!
Water-Fuel Generator Kit by inventor Carl Cella
Journal of the Society of Chemical ... - Google Books
There are other links, just wanted to get the ball rolling.
Anyway, it's a real live molecule verified by spectrum analysis
it appears.
Abstract from first link at top:
Cover Picture: Experimental Detection of the H2NO3 Radical (ChemPhysChem 10/2003)Fulvio Cacace, Prof. Dr. *, Giulia de Petris, Prof. Dr. *Italy, Fax: (+39)06-49-913-602
email: Fulvio Cacace (fulvio.cacace@uniroma1.it)**KeywordsAbstractThe cover pictures showsDigital Object Identifier (DOI)
10.1002/cphc.200390107 About DOISincerely,
There is a story behind Nitrogen Hydroxide. It might be in all those links, but I am not going to read all of them to find out but I will relay it to you guys.There are other links, just wanted to get the ball rolling.
it appears.
At the close of WW II, when the Russians and the US were closing in on Hitler and chasing him all over Germany, there was a discovery made.
If I am not mistaken, The Americans and Russians both converged on a compound that housed allot of Hitlers experimental research.
Among these various gadgets was the HHO cell. The thing was probably on a few military cars and trucks, but during the heat of battle no one really popped the hood to admire the engine.
Since Hitlers fuel supply was dwindling, his scientists came up with the fuel cell.
I believe that there was a soldier that actually understood what he saw and brought the invention back to Australia.
The device is similar to the Joe Cell but only has one tube inside the other.
Supposedly, it uses the engines vacuum along with very low voltage to help pull apart the H20 molecule and make nitrogen hydroxide.
This process is suppose to be the missing link on processing the atomic O1 and sticking a N1 in there and creating fuel on demand.
Aaron mentioned copper in the air ionization thread. I believe copper intake tubes along with heat, helps this process to take place as the water inside the cell is heated.
Anyways, it is a good story whether it's true or not, it's anyones guess
regards,
Murlin
Well that is what is suppose to happen.Nitrogen hydroxide is supposed to be created and burned in the engine with only a very small amount of fossil fuel used.
I don't think it is as complicated a process as many believe. It just requires a tad of vacuum, some copper, water and heat and a battery....
I have done my own experiments but failed to finish the project due to getting side tracked on the TS.
I did not like the by product of Chromium I was producing by the electrolysis in the cell.
regards,
Murlin
nitrogen hydroxide
Very interesting story and I wouldn't be surprised if true. A lot of
technology came from that area during that time.
The copper I mentioned was from something Tutanka posted in regards
to something can be done with a copper tube or something. I guess it
could be part of an ionization chamber.
The vacuum helps to pull apart of the gases in the cell and this has been
said quite a bit in the threads relating to nitrogen hydroxide. When the
"mixture" enters the combustion chamber, the vacuum there may help to
further dissociate the HHO.Sincerely,
Most of the HH0 cells out there today have plastic tubes running to the intake so the gas mixture exits the magnetic field before entering the combustion chamber. I have always believed that the fracturing of the H2O with brute force was going in the wrong direction. EDIT BY Brute force I mean throwing more amps at the problem to create more HHO.
I believe the copper tubing may help keep the field around the mixture all the way to the chamber..
At least that is the theory I was subscribing to when I stopped working on my HHO project.
The current race to Hydrogen power made me realize that the atomic H was not important. It was the Atomic O.......
Cars running on Hydrogen would require total re-engineering, while everyone with half a brain knows that N20 and gasoline go great together with the ICE just they way it is...
The older engines were big enough to steal some of the HP to turn it into a vacuum pump-IEC...the newer less powerful computerized engines are useless for that...
And not many want to drive a 70 model car for various reasons.
Like I have said before, they are always one step ahead....
My 002...
regards,
Murlin
How to Make Nitrogen Hydroxide
Here is a 3 page compilation of this thread. I condensed it into a couple
categories. It is short and sweet. It is INCOMPLETE. There are a few
things that need to be added that may or may not be apparent to get
a full working motor. But it will give the Nitrogen Hydroxide story and more.
How to Make Nitrogen HydroxideSincerely,
disassociation
This goes a bit off topic of ionization so I post it here.
We all know the ICE is an extremely inefficient power plant.
However it is the only thing that millions of DIY's have to work with.
What Meyers did took a huge amount of special engineering to get his dune buggy to run on water.
The standard ICE will not run to long on Hydrogen and or water. It needs lubrication.
Hydrogen burns so clean that it will scour the cylinders from carbon.
Carbon is what lubes the ICE inside the combustion chamber. Not oil as one would think.
So a system that uses small amounts fossil fuels would be preferable for the average guy who wants to make his car get uber MPG.
In order to accomplish this task, one needs to come up with a system that uses the least amount of energy possible while keeping the entire unit as simple as possible.
Turbines sound great, but the average guy could not build one in his garage and convert it to run in his vehicle..
In nature, won't 2 molecules of water randomly disassociate into H30 and OH ?
Of course they recombine, but this special property of water could be exploited.
This means that perhaps there is another way to create and use the gasses needed by less complex means.
Resonance frequency could be used along with electromagnetism to stop recombination after the gasses leave the WFC and head towards the combustion chamber. This resonance frequency is determined by how far one puts the plates inside the cell.
Water vapor and N2 keep things cool and steam adds to help push the piston down. Small amounts of fossil fuel are burned in the mix for lubrication and starting the engine. The whole point would be to use the engine "as is" without modification, perhaps only changing the ignition timing and installing a plasma spark plug..
A simple cell consisting of 2 tubes will create the desired effect.
There are many unanswered questions about this system that I do not have the answer to, only more questions that I will have to put to the test. But for the moment I can only speculate since I too am waiting for warmer weather to make experimentation more enjoyable and rewarding. But the ionization thread has rekindled my interests on this project. I find it very exciting...
Could one exploit the magnetic moment of copper to polarize the N2 that is already in the ambient air and combine it with the fractured OH(hydroxide) creating nitrogen hydroxide? A shielded copper intake would absorb heat from the engine while working to keep the mixture inside the field and help keep the magnets around it from degaussing..
Would the magnets and copper see the mixture as a solid since it has water vapor in it and induce a reaction?
Questions....questions...
The hydrogen would be the only thing that would be need to be ionized for extra power and the HHO cell already does that easily with low voltage. The nitrogen hydroxide would compliment the carbon fuel to increase joule output just like N20 does except have an added kick from hydrogen.
We need to come up with something that works with the current engineering that the ordinary person can use.
Anyway like I said earlier I am not a chemist so there are things I do not understand about the physics of it all....just thinking out loud here.....
regards,
Murlin
. Nitrogen hydroxide is supposed to be created and burned in the engine with only a very small amount of fossil fuel used.
