Originally posted by jstadwater
I didn't explore the upper limit of rpm on my circuit. I very rarely go over 5000 rpm (2500 rpm distributor equivalent) when driving, unless alcohol was involved. Do you have an application for > 5000 rpm ?
Timm
My max rpm on the V-8 distributor, drill spun, is 2,300 rpm as previous. Voltage doubler is set up as follows: A pair of 120uf 330V flash caps and a pair of 1N5408 diodes. The measurable DC voltage out is 326 volts, I think the caps need to be rated for 400V instead, I just had these laying around. The discharge cap is a MW oil filled 1.06uf rated for 1,750V. NO misfires at 2,300 rpm, nice crisp sparks and no cap heating detected.
Most important I guess, is that it DOES work, right?
I am charging at 326V, no "storage" cap (I will add one later), 1.06uf MW cap for discharge (will change to four 4.7uf caps, 2 ea. wired series then paralleled together), and a 100 watt light bulb as the resistor (only thing I have on hand). One 12KV microwave diode per spark plug. I ran the test for a few minutes, way longer than my other tests, and there was NO detectable heat anywhere throughout the components!!
Well, I'm off to set up the video, see yall in a few.....................................Mike
