Other Observations
The above quoted research said that the arc fills the "whole gap" which would explain the increased performance of Firestorm spark plugs because the "area of the gap" is much greater. The increased area also minimizes the probability of misfire due to condensation of the electrodes (if even the smallest area is dry we will get the initial spark).
It also appears that we want the largest possible gap (possibly requiring a very strong ignition coil) This would enable the most water to be "in the path" of the arc and help prevent damage to the plug from high currents. Now if the FireStorm plugs really do fill the whole chamber with plasma then this detail might not matter, but I was assuming current would take the path of least resistance. We also witnessed that under pressure the size of the plasma ball grows dramatically.
I do not know how this latest "theory" explains the coolness of the electrodes after heavy usage, unless the heat generated by the current is absorbed by the water.
But it is clear with the latest VexUS circuit that what is going on with the WSP has nothing to do with the gray tube.
Am I completely off course here?
But it is clear with the latest VexUS circuit that what is going on with the WSP has nothing to do with the gray tube. Am I completely off course here?
. This thread is really some thing.
