Water Science, JoeCell, burning water and making oil
  • Water Science, JoeCell, burning water and making oil
    Making a JoeCell the olde fashioned way.
    Look carefully at the Cell in the Video making Oil and Burning it
    https://www.magneticwaterscience.com/?page_id=46https://www.ebay.com/itm/Ocean-White...s/173841889962
    I had the good fortune to speak with an inventor of the Joe cell.
    A true cell either had the applied method of a gentleman that dissapeared or as joe wasted cells to obtain a stage 4cell(which is expensive).
    You had to have stainless 316 or as little chromium content as possible x 2 minimum to anode cathode and strip the water of its molecules(remember if you have neutral plates in between, then you start halving your amps required, just as the cylinder pipe/cell.
    This had to remain sterile and lemon or other acid was used to prepare the plates in boiling water between stages or you would contaminate the water and never get past stage 2 or they will see a stage three momentarily that will leak energy rather than absorb and create impurities in the water and in the cell..
    The water shall become very alkaline and if your bubbles or foam is breathing with and without applied current.
    You can also light the water with flame and it also holds charge so you can light lights with the cell's anode cathode it becomes a capacitor this shows a stage 3. There is little known of the stage four only glimpses that have been removed or long forgotten ideals.
    Although one can drink it it would not be advisable in large amounts.
    After the water has been stripped and as they failed to see is it was not hho or brown gas water vapours and elecricity and or magnetism interacts with water and has a memory effect that has been proven to date, Tangent i will stay on track Every molecule has charge and it gets it's charge from it's spin, just as the voltage or pressure applied to the force it can be rising or falling and still be moving unless balanced or resonating.
    There has been many people that have worked on resonate states and shapes or Viktor Grebennikov is a gem. As if you look for the effect I am pointing you to the unseen makes the seen! back to the yawn.
    They have to be an open circuit as they are also anode cathode and neutral plates the more neutrals the less amperage required for brooding or preparing, just as the high frequency and hq is able to send thousands of volts in hair line wires.
    There were replications of this where I lived, Not near Joe. Thy called it a proton cell. Cars were run without fuel with some added lube in the unit that were used for air tools for the moving parts ect inline. Although the cells were mounted near the engine while blanked to the engine. Their take was that the protons were traveling to the engine after started with fuel as stated then would have a field effect. Levitation was also observed
    His unit seemed to interact with any combustion engine that it had a blanked or hard stemed metal connection.
    While the cars needed fuel to start or small engines after they used a thimble in the carby the stage four Joe cell would sustain the motor and give other effects, as we are combustion.
    My brother wanted me to work on this, as he is a tight ass farmer, that always want's an easier way,So I helped him I did all the work till the brooding as this is not something for me I have seen to many people exit.
    There is a guy named Ritalie that is on the youtube that has had success, I have seen a retired Ed Grimms from nasa selling boosters for earthmovers ect. As he said he builds em only to about 30% then your under the radar.
    As for the joe cell it will also emit a hf/r/f field that will be huge, Healing effect, Beneficial.
    An engineer came along and demystified the bubbles only the rest is still unexplained he dissapeared shortly before he was going to share the knowledge.
    Joe is a religious person, Ex mechanic, master of cracked fingers.
    He was told they would mail his family back to him if he was to continue his ventures.
    I was in contact on a weekly basis.
    He stopped.
    I stopped.
    https://www.youtube.com/watch?v=jKS2...l=JanuszLektor You can hear his wife getting up him 3:16 as he is using charged water, stage 3 or 4? no bubbles.
    I love the https://www.youtube.com/watch?v=cUvbXzcKMso This reminds me of Floyd Sweet and his speaker magnets that he would set to a certain frequency. I would know there is tape covering the magnets for reason and purpose as there is windings under both magnets for them to induce the same with the feild. Although a nice share 16+ volts from forcing fields with ferrite, as neo dymium magnets are not able unless the poles can interface with common ground such as with another ferrous material so the poles have the ability to flux the domain of right hand rule. I had not seen this effect until writing this article, so.... off I go again playing with magnets they truly are my favorite, ....Unseen energy. Although a theory must be tested if one cannot repeat what is the point? Worth a look.
    G.G.
