The mysterious technology of Stanley Meyer
  • Originally posted by wolf234 View Post
    I used a rod of iron. tubes meď.na oxygen removal. enclose Kanarevo reactor. much energy is needed whether that means worse than the previous ones your
    Simply we are in presence of an reduction reaction. CO2 is reduced to Carbon on the metal catalyst and the carbon react at high temperature with CO2 and WATER VAPOUR creating the COH2 synthetic gas. The high temperature is the main catalyst of the reaction without these conditions the reaction isn't possible.
    Why PANTONE GEET can't work correctly? Because don't have an enough energy source for reach and maintain in the time the correct temperature for process these molecules.
    That's all!!
    • Without temperature also Baziev reaction can't work. The temperature is the main catalyst for obtain the properly reaction.
      Why the hydrocarbons are added inside the mixture of exaust gas and water?
      What is the effective work of hydrocarbons?
      No one has noted that into PMC diagram, and NOT into PANTONE GEET diagram, the air is pre-mixed with the mixture of exaust gas, water and oil?
      What happens if you mix the air and oil to the temperature of autoignition??
      Do you have the answer??
      No one have the answer??
        - Sorry, I mistyped in my earlier response - I was referring to Andreev (Autothermia process). You are correct there are two parts - the first stage of processing the Air(catalyst and magnetic field) and the second stage reaction chamber that is entirely a thermal process (along with Catalyst). I am guessing something like a nitrous monopropellant engine.
        This is the carbon source
        You have ignition/reaction - Temperature increase - as shown by temperature profile in the reaction chamber.
        May or may not be correct, but my thoughts anyway
        Best regard, Wireguy
        • Could not upload file too large.
          http://www.dtic.mil/dtic/tr/fulltext/u2/665121.pdf
          This file may have some interesting information. From page 14 on it seemed relavent.
          • Originally posted by adam_mizer View Post
            This is the only way for use water as fuel.. using CO2 as carbon source is great idea and in this way some emissions in atmosphere are reduced saving also some moneys.
