Heres a picture of the powder coating formed on my moejoe cell spheres. I was charging it with SSG for a hour 3 times a day for two days. The water (clean spring water) slowly turned yellowish and smelled like chlorine, like in swimming pools. So I decided to disassemble it. I think that the smell could be due to improper cleaning off the polishing paste remainings.:
WFC Tube Insulation & White Powder Coating
Chlorine smell usually occurs when you electrolyze water with NaCl. It seems that your water may be more saline than it appears.
Yes, I know that, but the water should be fine, I did not observe something like this before, when I was working with cylinder systems. Although I did not polish those tubes
Anyway, I cleaned those spheres with solvent and alcohol to remove any remaining polishing chemicals. Will see how it works. Then, if the chlorine smell appears again, I will try using distilled water, this will show if the problem is in the water
JetijsIt's better to wear off by working than to rust by doing nothing.
Use Isopropyl alcohol- it's a most excellent solvent for grease.
tube conditioning
I am using plaster of paris for my calcium mixture. You have to mix it up for quite some time so it doesn't set up in the jug on the bottom. I put two heaping tablespoons full in a gallon of tap water. The brown sludge decreases as the tubes get their coating.
Need a procedure on how to condition my tubes
Guys,
Been reading the forums for about a month now but have my 304L tubes ready for conditioning. I have been getting bits and pieces of what and how to do the conditioning process but nothing step by step.
Questions like:
Do I just use straight DC power or use a PWM?
What voltages?
Who long per cycle.
Tap water only ( I do like the idea of using some plaster paris )
Please provide as much as you can. Step by step would be helpful.
Brian
I case you can not tell I am a newbe but have been researching and playing with this for about 5 months now.
Hopefully I will have a lot more to post in the future we are planning on adding this technology to about 5,000 vehicles in our fleet. We are just getting started and I will have a lot of questions as well as being able to provide solutions in the future.
Hi,
The D14.pdf is embedded as page 10-117 thru page 10-134 in the chapter10.pdf from
h++p://www.free-energy-info.co.uk/
Ravi_cell.pdf can be found in.
h++p://www.panaceauniversity.org/
Not sure if live links are allowed, change ++ to tt
P.S. sent you PM but seems that you can not receive PMs.
Video of Conditioned Tubes with White Powder Coating
White coating on tubes and measurement of no
conductivity, which restricts current:
YouTube - Water Fuel Cell | Conditioned TubesSincerely,
Need help
Hi all. Im new on this. I was condition my wfc for 25 coplete cycle now. Im using lawton pwm. The brown muck already disappear when i conditioned the Wfc. But if i run it for over 2hours continuesly without any vic circuit the brown muck start build again. What happened to my Wfc. Im not yet coated the outside tube. Are my cell conditioned enough? I still get the outside tube foaming very little bubbles. I want to use clear coating for car paint as the outside tube coating. Can i do this. When i pulsing the Wfc its hum. The humming quite loud and i get better gas output when the cell humming. When i connected it with bifilar there's on different with gas production. What was wrong with my cell. Hope some one can help me on this.
