What Cracks Water?
  • #31
    Interesting. I am aware that flames are in essence a plasma, but most forms of plasma do not exist in the state of ignite gases but excited gases. In fact a bolt of lightning lands us with a net amount of hydrogen as atmospheric water is split. It is this splitting that supplies ozone with it's extra oxygen the remainder of the oxygen is taken up by Nitrogen dioxide formation.
    • #32
      The combustion must be revised and studied in that direction
      From plasma no brown nitrogen dioxide gas but N2O and O3 as exaust gas !!!
      This is the reason because Meyer recycles the exaust gas
      • #33
        A thought has just occurred to me! A thought experiment:Imagine if you will, a cylinder and piston. The cylinder however has no ports whatsoever; it is totally sealed and ultra gas tight. The cylinder contains a thermally but non combustible reactive gas. As the engine is turned over the gas is compressed at TDC, at this point an extremely high charge is applied to the piston arcing through the gas to a cathode or cathodes cast or machined into the cylinder. The gas is rapidly ionised as a plasma and expands pushing the cylinder down. At BDC the electrical charge is grounded via an earth link, the gas rapidly contracts allowing the flywheel on the crank to re-compress it again.
        A possibility or futility?
        • #34
          It's futility.
          You must think simply as the nature.
          Air and water can be all you need for obtain thermal energy need just to process correctly but believe in me you don't need complicate mechanical parts or special electronics circuits for obtain that condition!
          • #35
            Originally posted by tutanka View Post
            It's futility.
            Air and water can be all you need for obtain thermal energy need just to process correctly but believe in me you don't need complicate mechanical parts or circuits for obtain that condition!
            I agree that water and air can supply an abundance of energy, but what do you expect that Mayer would use some of his hydrogen for? Internal combustion engines, gas turbines for the production of electricity and aircraft or even rockets! Mechanical parts are essential to our daily lives as are circuits, I assume you are posting here via electronic circuitry?
            • #36
              I don't want sell electronic circuits! My project is burn PLASMA AIR !!!
              I have just informed some time ago that I have build specific circuit for hho dry cells for save some power and with some features inside..
              Believe me if I told you that you do not need electronic circuits to burn the air?
              Need just that you apply these steps:
              1) Clean your minds from all information on standard combustion
              2) Study better the electrino theory of scientist D.H. Baziev
              3) Build some prototypes for test .. as Leonardo da Vinci wrote " The experience is the mother of all certainty"
              • #37
                I have just informed some time ago that I have build new circuit for hho dry cells for save some power and with some features inside..
                I will certainly read up on the work of Baziev with an open mind, but I must state that my engine has nothing to do with "standard combustion" as no gases are burned or consumed, they are only superheated to a Plasma en vacuo,expand, push the piston then condense back to normal state with no by-products! To use air in such a Plasma engine would produce Ozone, Water, Nitric acid and numerous other toxic compounds ! You must be aware that Nitric acid is produced by passing a plasma discharge through air?
                • #38
                  Your engine is real or just in development?
                  Please share video link or sent image like me.
                  About plasma air.. I don't use high voltage or capacitor discharge for plasma air creation.
                  As exaust gas I have N2O and O3 like Stanley Meyer
                  I have two patents on this process and third patent is ready in the next month.
                  • #39
                    A patent is awaiting the venerable and much feared European Examining Division of the EPC. A prototype will be built following approval.
                    I notice that your engine produces both N2O & O3! How come the N2O doesn't strip the O3? Are you also aware that N2O is to be eliminated from exhaust emissions by 2021 in EU member states?
                    • #40
                      http://ec.europa.eu/environment/enve..._emissions.pdf
                      I know... also on O3 GAS the same problem BUT NO problems for me ..
                      I admin plasma without poroblems, maybe I can recycle exaust gas like Meyer or add another plasma stage.
                      About your patent if is been registered you can share images, videos or technique used without problems.
                      If you use plasma inside your engine I suppose that you are using capacitor discharge for plasma creation.
                      As you know similar engines are been patented and some peoples are working on and also is too many dangerous use capacitor discharge..
                      And can be very complicated for you obtain certifications from organization like IMQ or similarry.
                      • #41
                        Originally posted by wrtner View Post
                        Everyone's suggestions are pretty hard work.
                        I favour John Worrell Keely.
                        He slammed water with 42.8khz (sound) and the water "dissociated".
                        What is interesting is that Visaton has a high frequency sound driver, an
                        HF horn, which has a response from 3khz - 40khz. When the driver
                        gets to 42.8khz, the graph will have dropped a fair amount, but
                        there should be sufficient power for our purposes.
                        Of course, the legendary Bob Boyce uses 42.8 (along with 21.4 and 10.7)
                        electrically in his 101 plate electrolyser.
                        Paul-R
                        Is it likely that we could get into it and alter the running frequency from 40khz to 42.8Khz?
                        If so, stuff may happen.
                        • #42
                          Here are the details:
                          • #43
                            The cracking type H2 generators tend to need trick stuff to work and a bunch of stages.
                            A solar ultrasonic and UV type might work.
                            The present disclosure provides a system and method to dissociate water molecules into H 2 and O 2 and includes a reaction vessel having at least one radiolysis apparatus, at least one photolysis apparatus, at least one catalyst apparatus, and at least one electromagnetic fielding apparatus. The reaction vessel has a body, a first end and a second end defining an interior reaction chamber, an inlet for receiving water vapor and at least two outlets. A plurality of windings of a contiguous electrical conductor are wound in a first direction adjacent the first outlet and plurality of windings of a contiguous electrical conductor wound in a second direction adjacent the second outlet such that the first direction is opposite the second direction. When a current is applied to the conductor, an electromagnetic field is generated to migrate the disassociated H 2 and O 2 molecules toward the respective first outlet or second outlet.
                            • #44
                              I don't reckon these links relate to Keely's work. He was running down a completely different path.
                              • #45
                                The chart tells you that other resonance types do not work efficiently.
                                So what resonance effect is valid ?
                                What cracks water ? What resonance effect works efficiently ?
                                Other resonance effects are NOT invalid because of ultrasonic alone. Inventors have called
                                them resonance devices. patent reading skills...
