I did try this with the glue cell and the current did rise. The effect was not as dramatic as the Alum cell. The meter topped out at 6.3ma and is now dropping. Current reading is back to 5.9ma after about 20 minutes.
Bedini Earth Light
A videos of the glue cells powering a LED and LCD clock. These glues cells can be shorted out and given a load and left to sit and will recharge themselves back to the original voltage. When these glue cells are made they reject water and push it out of the cell and dry hard and show crystals. These cells don't seem to be galvanic but instead something different. No corrosion shows up even on cells that been shorted out for months and the glue cell continues to recharge itself even after long periods of shorting out. The one cell that powers the LCD clock will fluxuate during the day in and out of brightness as if its looses its power than gets it back and then looses it again, as if it is cycling its power. This same effect is also seen in resistors too, where the cell seems to cycle between being charged and not charged.
Here is the two latest videos on the glue cells using copper and magnesium powering things.
The Much Stronger Glue cell - YouTube
Glue Cell Powering White LED - YouTubeAll truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
Bedini Earth Light/ crystal cell
Ibpointless2,
That Glue cell is working better and better. Copper and magnesium work the best of all. Have you tried carbon magnesium in the cell?
Please do not think I'm paying attention because I am. That is really good work getting this developed. See if you can get the electrodes close and bigger, what amount of current have you seen.
John BJohn Bedini
www.johnbedini.net
@ibpointless2;
Your glue cells are outperforming mine. I noticed in your latest video that our Elmer's Glue is different. Mine is Elmer's School Glue - nontoxic - safe for children. Apparently children can eat my glue and only suffer mild constipation.
I have wood glue that is polyvinyl acetate that I will try and see if I can match your cells. Otherwise, off to the store to find the same glue you are using. Congrats - your video's really do show the power packed in this ultra simple cell. I still believe the mystery is hidden in this build.
Brad S
@Voire,
The recipe you post seems to be interesting. Why did Hutchison send you this recipe? Have you tried it yourself?
How many Volts and how many amps can this cell give out?
I have been making the Bedini alum cells, but the copper keeps becoming greenish and the current drops dramatically. They cannot give out more than a few microamps. I use Carbon, Aluminium foil and copper as electrodes in my cells.
aaron5120
Bedini Earth Light/ Crystal Cell
@ Aaron5120 and Voire
To let you both know I'm not waiting for anything. I think I will pass on this one as I see this as trouble.
@Aaron The metals you are using I have never used like aluminum foil the only way it could turn green is salt or acid. so what you have written makes no sense at all.
Have a good day
JohnJohn Bedini
www.johnbedini.net
I fell off my chair laughing so hard, that was funny.Originally posted by b_rads View Post@ibpointless2;
Brad S
If it helps I get my Elmer's glue at Lowe's, its the "new stronger formula" stuff.
I made a graphite and magnesium cell and its producing 1.70 volts, but it doesn't hold their and it drops quick. The cell does charge back up to 1.70 volts over time but hook a meter to it and it drops to 1.6 very quick. How I made it was very simple, just took a pencil and colored me a electrode on one side of the paper and put the mix on top and stuck my magnesium in it. It seems the stronger the potential the weaker the holding power becomes, this could be a bad thing or a good thing or even me making a mistake somewhere.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
John BAll truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
Update:Originally posted by b_rads View PostIf anyone can replicate an experiment I just tried, I would be very interested to hear your results. The two encased cells using semiconductor copper, magnesium, and Alum were just placed in an ultrasonic jewelry cleaner operating at 42khz. The cells were connected parallel and initial meter reading showed 2.6ma. After 2 minutes in the cleaner (no water in the cleaner) the meter showed 5.2ma. No change in voltage. This to me is very exciting. This is double the current and the meter was still rising when I turned the cleaner off. It has only been a few minutes but the cells are holding the current. I will continue to monitor.
Brad S
After about 3 hours, these cells dropped back to the original 2.6ma. After letting them sit at that level for an hour, I performed the test again. This time, after 2 minutes the current gained to 3.2ma and was at 3.6ma a few minutes later when I shut it down for the evening. This morning the current has dropped to 1.8ma. The ultrasonic seems to have a destructive force at 42khz on these cells. Not certain how to interpret this information or if the result was piezo or something else.
Brad S
I've found the reason that the cement cells as well as other cells lose their output over time. It is not the lack of water, or the green oxide that forms. The reason is that the copper wire or tube inside of the cement will turn black and that black oxide layer will totally inhibit the flow of current, by 100%. It is not the green scum that forms, it is the black oxide. So, does anyone have any suggestions as to what can be done about that?
Bedini Earth Light / Crystal Cell
To all,
Again I will say if you are looking for big currents with the Crystal Cells your making a big mistake. I have run the graphs on the mixture he gave I do not see anything special. I wont argue with anybody about what it is. I do not see the Casimir effect working with this at all, I do not see it scaving any energy, The Rochelle salts has been known for a long time as being piezoelectric in nature. What I see is an Electret with some power in Milliamp 7 to 150 max.
The Epsom salts generates electron flow between metal plates. I think that I will do a few more experiments with this reverse detector and see what I get. The Casimir effect takes place between anything, but the effect is to small. I have not tried silver electrodes yet but I will, I will even grow the crystals. I suggest you all read T T Brown, Then read all about Marcus Reid. That is a real mixture as I posted before, I have done that test and it works like he said. As for collecting Zero Point Energy have it proven to you. Barium Ferrite, yes does generate energy and does give small amounts that can and does power things, quarts plated glass does the same thing.
When talking to Tom Bearden about all of this He said he never said anything about a plating process to anybody and I believe him. If your going to play with low power Crystals then expect to make low power circuits. It's not going to run your house, it might give a desk lamp and that is it.
If you do not know what the real electrodes are you cant duplicate anything. The other thing here, if this was the answer to the energy crisis you would have had it by now as many people have been working on all of this. The battery industry would have this first and they would build it to fail so you would have to buy another one and would not know the difference. I'm sure the black government projects have this and even better, you will never see it from them.
Someone telling you to twist coils and put it in the mix must prove that, I don't see any proof. If you buy a small solar motor and run it with this mix it does work for some time. As I said the impedance of these cells is very high 1 meg ohm so how much power can you get through that?
More later
John BJohn Bedini
www.johnbedini.net
John Bedini,
Have you made a glue cell? I would Like to hear your input on it.
I have made a glue cell with just Epsom salts but it never was as powerful as the salt subititute and Epsom salt cells. I do agree these types of cells are not that powerful and act like Electrets but the project is fun. I went from 300mV to 1.70Volts now and I consider that a big improvement. There is something about Elmer's glue, salt subititute and Epsom Salts that is very interesting. Its the effect that i'm studying now, me not powering anything has made many people upset but all i care about is the effects and how to advance them. I only post videos of me powering things like LED's just to keep people happy and show them these cells can do things.
I have seen the test done on the Marcus Reid cells, they're very much like ours but not quite the same. His cells only gave a few milliamps too and show the little green tarnish like ours. Marcus Reid was the one to really get me interested in making these types of cells and even though my cells are not his I do take great pride in my creation.
John H. cell shows water
In this video John Bedini shows that this cell ended up with more water then it started with. The other cell had the copper heated the next day and dryed. but this cell seemed to pull moisture from the air. This may be the water glass or the salts or both...
Results of hutchison cell with water glass 081111.wmv - YouTube
In this video I show the testing of the Crystal Battery that John H released.
The Cell was made a little different first the outer shell or case is magnesium inner electrode is oxygen free copper tube. The doping mix was Rochelle salts, Epsom Salt, Selenium. The applied voltage to set the cell was 12 volts for 3 seconds. This cell has been running for 1 and 1/2 days on a computer graph. The load being a SG oscillator circuit, The oscillator can be tuned for current. The cell started at 2 and 1/4 Ma. After one day the cell has stabilized to .765 volts at less then 1Ma. This seems to be the working range of this cell. I will be posting more on this cell as the load continues. We have made one more Cell using in the doping mix Selenium and Alum and changed the electrode to the star pattern suggested by Marcus Reid in one of his posted e-mails. More to come.
You Tube Link
John Bedini Testing John H Crystal Cell for power. - YouTube
One other thing I might add The Alum Mixture and the doping makes a very big difference.
The Next thing is the temperature the crystals are cooked at makes a very big difference.
The oven must be very well controlled and it just takes a matter of seconds to spoil the mix.
I'm working out the exact doping right now, but the testing of the new cell in the video is holding a flat line in power. More later.
John BJohn Bedini
www.johnbedini.net
