I played with the captret for a couple of months, not days, and every single battery discharged, on many different combinations of captrets. That is why I say that it does not work. I burnt over 50 leds, and bulged many capacitors. They are all rated higher than the voltage applied.
I also tried it with the cement cells of which I have many, and it did not work, either. As they don't have enough current for that, even if they could provide enough voltage.
It has been forgotten for a reason. I am not the only one saying this.
These cells do work, and are still working, but have little power, due to their high impedance levels, and break down of the metals. I'm hoping that we'll find a way to get past the mA output level, and are able to build long lasting cells.
The reason I bring up the Captret is because of the way that capacitors can also show some output voltage, similar to the way these cells work, but in a NON GALVANIC way. That was my point, and not to talk about captrets. But don't get me wrong, as capacitors do show some output, but not enough to maintain an led going. That is the reason why the captrets can't keep up with even a single led as a load, even when using oscillators, and a dozen 1000 mf 50 or higher volt capacitors. As it is hydrogen gas production that burst they cans, when connected that way, as they are sealed and can't vent, without busting their presure seals. It is this same hydrogen gas that ruins our cells, and forms water that further dissolves the metals. That is why I have my doubts about even the metals in the semiconductor cells, holding up to the water, if they are not sealed hermetically from the air. But, the problem is still that non galvanic cells have very little power, and won't run our normal 1.5 volt type of devices.
