Help with bedini circuit, with pics and labeled
  • Help with bedini circuit, with pics and labeled
    Ok guys, im having problem with this circuit. I tested each diode and resistor with my multimeter on diode test mode, I also tested my transistor and everything works correctly.
    When I disconnect everything from the circuit and connect the power coil start to the battery + and the power coil - to the battery negative, my coil heats up and creates an electromagnet which then repels my mangets. But when its hooked up to the circuit I get no electromagnet effect or oscilliation.
    I have tried different resistances on he variable resistor from 100ohm to 5-10k ohm, nothing works.
    I also tested the voltage through the power coil when the circuit is setup and im getting the correct voltage through the coil while using the circuit, so it appears the negative isnt going through the coil and creating the electromagnet effect.
    Here is a pic of my circuit.
    Any ideas?
    Here is the circuit schematic im using.
      Hi adamo21
      You have tried to reverse the connections of the Trigger coil?
      http://Cacharreo.com.es/foro
        Tropex I have tried reversing both the power coil and the trigger coil but not just one or the other. I will give that a try and report back.
          that neon is in the wrong place. Should be connected before the diode.
          Disconnect your coil and place it under the rotor.
          Pick power winding and connect directly to a battery. If polarity is correct (on the electro magnet AND the rotor magnets) it should push the rotor away. If it sucks it in (attraction mode) you need to reverse the connections.
          Once you have correct polarity keep the power coil connected to the positive of the battery, the other end (which you were briefly connecting to the negative) goes to the collector.
          The same end of the trigger wire goes to the EMITTER, the other end will go through the resistance to the base. If you cant get it to work with 100 ohms on the base its one (all) of 4 things.
          A) Not enough turns on the coil to turn the trigger on.
          B) Not enough induced current from the passing magnet (either not strong enough or too far away from the coil)
          C) Transistor/resistor/diode faulty
          D) Faulty connection (cold solder joints or such).
            FINALLLY!!!!
            I finally got it! The problem was I had the neon bulb disconnected so the neg from the battery wasn't connected to the diode #2, once it was connected the electromagnet became fully functional and repelled the magnet...
            Thanks for the help ren and torpex!! Much appreciated. This was my first circuit ever built and it took me like a week to figure all of this out. Now I can actually read a schematic and have an understanding of how it works, huge learning experience. Thanks guys.
              Transistor Circuits
