r-charge / bedini - solar power charger
  • Sorry SeaMonkey, I have it wrong, my memory is dull. My circuit is more efficient with higher impedance load, less efficient without load.
    "I always notice that my efficiency increase with 3V compared to 12V" is wrong.
    "A circuit that its efficiency increase when the load impedance reduced" should be "A circuit that its efficiency increase with a load".
    Originally posted by SeaMonkey View Post
    Would it be possible for you to show your calculations and the values of Voltage, Current and Resistance? What are the
    characteristics of the "source" and the "destination?"
    I don't measure resistance, is it enough to show with and without load?
    Video on different experiment:
    YouTube - COP = 69% battery charging battery
    YouTube - Swap Charging front and back battery
    Are you saying that by reducing the impedance of your Load the efficiency of the power transfer increases?
    With load my circuit consume less power.
    YouTube - Input current reduce when there is load
    When you observe an increase in efficiency at 3 Volts instead of 12 Volts, what is the source and what is the load?
    Same source, same circuit different load. Sorry, I have it backward:
    old circuit, single:
    Source voltage is 11.5V.
    Input current without load = 1 Amp
    Input current with load = 2 Amp
    Current in the load (charging current) = 0.25 Amp
    Voltage in the load part:
    without load = 90V
    with load = 9.4V
    on battery = 2.72V
    on total load:
    Efficiency = (load voltage*load current)/(source voltage*source current)
    Efficiency = (9.4V * 0.25)/(11.5V * 2)
    Efficiency = (2.35 Watt)/(23 Watt)
    Efficiency = 0.1 ~ 10%
    on battery only:
    Efficiency = (2.72V * 0.25)/(11.5V * 2)
    Efficiency = (0.68 Watt)/(23 Watt)
    Efficiency = 0.029 ~ 3%
    new circuit, single.
    Performance data charging two 1.2V nicad (1000mAh):
    Input: 0.7A @ 10.4V = 7.28watt
    Output: 0.45A @ 3.2V = 1.44watt (at full battery)
    Efficiency: 19%
    Performance data charging one 12V gel SLA (7Ah/20hr):
    Input: 0.62A @ 10.5V = 6.51watt
    Output: 0.24A @ 13.1V = 3.14watt(initial voltage raising before going down)
    Efficiency: 48%
    How are you able to "short out the load" and
    measure 0 Amperes? Where is the Ammeter positioned within the circuit when it indicates 0 Amperes?
    amp meter is in series with source battery. My circuit that do this is modified joule thief and stingo. My circuit is unpredictable, sometime I need to wake it up / power it up with a touch of hand.
      Thank you for the clarification.
      There are some oscillator circuits which exhibit
      that sort of "anomalous" behavior; a current draw
      which "decreases" when a "load" is attached.
      And, often oscillator circuits on the bench are
      somewhat "unpredictable" and need a little
      "touch" to get them going.
      This is the nature of the Radio Frequency Blocking
      Oscillator (Joule Thief) circuit until it is "fine tuned"
      for stability. For best operation it must be mounted
      on a circuit board with soldered connections and very
      short wiring connections between the various parts.
      When a Radio Frequency Oscillator circuit is operated
      without a "Load" a radiated "standing wave" may develop
      in the wiring which will draw excessive current from the
      source; once a load is connected the standing wave is
      dissipated and the current demand from the source is
      decreased.
      It seems very odd and unusual but at Radio Frequencies
      strange things can happen!
      • "Radio Frequency Blocking Oscillator"
        Why is it called a "Radio Frequency Blocking Oscillator"?
        Yesterday I pulsed my boost converter with 300khz instead of the normal 3Khz and it blocked the FM radio standing 5 feet away. It went silent. Is that why it is called that?
          See! "Radiant Energy" is amazing stuff!
          Actually, the "Radiant Spike" is very rich in harmonics
          which can extend up into the high MHz. They're capable
          of "interfering" with radio reception as EMI/RFI which is
          why the electronics industry does its best to suppress
          their existence in consumer electronics devices.
          See attachments for details of Blocking Oscillator from
          an article which goes waaaay back. It's one of the
          simplest pulsing circuits - does the schematic diagram
          look familiar?
          • Originally posted by SeaMonkey View Post
            This is the nature of the Radio Frequency Blocking Oscillator (Joule Thief) circuit until it is "fine tuned" for stability. For best operation it must be mounted on a circuit board with soldered connections and very short wiring connections between the various parts.
            I think that unpredictability may also be natural behaviour of this kind of circuit.
            See video bellow, I intend to show how charging 1.5V nicad have less current consumption than charging 12V SLA, less than without load. Notice the current reading without load, it fluctuate between 330mA to 3A!
            YouTube - Stingo, reduced current consumption with lower load impedance
            So unstability may not be unwanted. Isn't conventional circuit dispose any sign of instability and kill free energy component along the way?
              If the base drive (in the case of a transistor) or the gate
              drive (for a MosFet) can be stabilized and isolated from
              loading effects then the current draw of the circuit should
              be minimal under load. Once a load is disconnected from
              the circuit unusual operation may result due to the surge
              in Radiant Spikes.
              It is possible to construct a circuit which has good stability
              yet produces abundant Radiant output. It never seems a
              good idea to run a Radiant Circuit without a load.
              Yes, in most electronics circuits the presence of Radiant
              is highly undesirable since it can produce difficult to
              control conditions as well as EMI/RFI. In consumer electronics
              the coincidental "radiation" must be nearly unmeasurable.
                If the base drive (in the case of a transistor) or the gate drive (for a MosFet) can be stabilized and isolated from loading effects then the current draw of the circuit should be minimal under load. Once a load is disconnected from the circuit unusual operation may result due to the surge in Radiant Spikes.
                Not sure about that. Can 555 controlled transistor / MOSFET reduce consumption with load? do you have reference video?
                  When a 555 Timer chip, or other pulse generator,
                  is used to drive a Radiant producing inductor it
                  will be possible to finely adjust the pulse width
                  in order to "charge" the inductor with maximum
                  energy. The pulse width will be just long enough
                  to take the inductor to the brink of saturation
                  so that the magnetic field strength will be
                  maximum.
                  Then when this magnetic energy is released as
                  a Radiant Impulse its energy content will be
                  maximum.
                  When this energy is released without being "loaded"
                  it can climb to several hundred volts which may
                  cause damage to the switching transistor or MosFet.
                  For maximum efficiency a fairly low voltage transistor
                  or MosFet would be desirable for the increased
                  conductivity (least resistance) when the device is
                  saturated.
                  In order to protect the transistor or MosFet from
                  damage it would be necessary to always have a "load"
                  connected to the circuit in order to safely dissipate
                  the Radiant Spike.
                  When such a circuit is operating into a "load" the
                  current draw from the source can be quite small.
                  Then, if the "load" is disconnected and the Radiant
                  Spike is permitted to assume dangerous proportions
                  the transistor or the MosFet would function erratically
                  and the current draw would increase until the device
                  destroys itself. This destruction may occur suddenly or
                  it may take several minutes during which time the
                  transistor or MosFet would get very hot.
                  That is why I do not advocate operating a Radiant circuit
                  without a load. Especially if the circuit has been "tuned"
                  to maximize magnetic field strength and hence, the
                  strength of the Radiant Spike.
                  • especially?
                    Have you posted any videos to show you have built anything that works
                    or demonstrates your working knowledge?
                    Seriously now. A circuit does NOT have to be "tuned" in any way to
                    maximize the magnetic field strength. You can run it very inefficiently,
                    "untuned", and the coil can still have maximum field strength
                    and the strength of the spike is not going to be any more stronger
                    than if the circuit was tuned.
                    The field strength concept you mention isn't where you're looking for
                    the maximum spike. It is allowing the coil to remain off just long enough
                    to get the full spike without turning the coil back on too quickly and
                    bucking against it, which would reduce the spike you're going to get.
                    If it is tuned, you just get the coil charged to the max with minimum
                    power and if it is not tuned, you get the coil charged by burning
                    up more than you need. In either case, there is nothing valid about
                    your "especially if the circuit has been tuned" in order to get maximum
                    field strength.
                    Why don't you post some videos of your experience with some of these
                    projects so people can see you're not just wasting their time. Based
                    on your post about tuning and field strength, it's looking suspicious,
                    because your post in completely inaccurate.
                    Run your circuits at 90% duty cycle, that will be horribly inefficient
                    but I can guarantee the field strength will be just as strong as it will
                    be if you were at the optimum on time just long enough to reach the
                    coils saturation and not one bit more.
                      field strength.
                      When driven by a Pulse Generator circuit, "tuning"
                      refers to adjustment of the Pulse Width such that
                      inductor charge current is permitted to flow just
                      long enough to approach magnetic saturation.
                      Pulse Width Tuning is not the same as Resonance
                      Tuning or Frequency Tuning; all that is being tuned is
                      the Pulse Width which determines the "ON Time" of
                      the MosFet switch.
                      This pulse width will then enable the inductor to
                      acquire maximum magnetic field strength and
                      maximum stored energy.
                      When this magnetic energy is "released" by
                      abrupt cessation of current flow the intense "Radiant"
                      spike is produced. Its magnitude is directly proportional
                      to the magnitude of the stored magnetic energy.
                      Immediately following the "Radiant" spike is a reduced
                      and prolonged current flow into the "load" which is
                      consistent with the inductance/load time constant.
                      Either "continuous" or "dis-continuous" pulsing will produce
                      that magnitude of "Radiant Spike" once the pulse width
                      is properly managed. With "continuous" pulsing the
                      "turn-off" point of the switching MosFet is determined
                      by Source Current monitor input to a comparator rather
                      than a fixed pulse width.
                      With dis-continuous pulsing each inductive discharge
                      cycle goes to completion. With continuous pulsing the
                      inductive discharge cycle does not go to completion;
                      the next "charge" pulse is initiated in the midst of
                      the inductive "discharge" before it is completed.
                      Discontinuous pulsing only requires a Pulse Generator
                      to drive the switch with fixed "ON" and "OFF" times.
                      Continuous pulsing requires another approach; Source
                      current is monitored and when its magnitude reaches
                      the pre-determined "saturation" point the switch is
                      switched "off" by a control comparator.
                      As you've pointed out, excessive "duty cycle" is wasteful.
                      That is the point of pulse width "tuning." Any current flow
                      beyond the "saturation" point of the inductor is non-productive.
                      By means of an oscilloscope it is a simple procedure to
                      "tune" pulse width for maximum Radiant Spike.
                      Or, as an alternative, a Peak Detecting Voltmeter can
                      be used to monitor Radiant Spike amplitude.
                      There are a great many instructional videos available, as
                      well as printed tutorials, which reinforce these basic
                      concepts. The printed Applications Notes are well
                      illustrated with diagrams and waveforms.
                      • eschew obfuscation!
                        Eschew obfuscation! lol
                        "Especially if the circuit has been "tuned"
                        The above sentence you posted does claim that
                        the tuning of the circuit allows for maximum field
                        strength and therefore a stronger radiant spike.
                        I pointed out a 90% duty cycle is not a tuned circuit
                        and IS maximizing magnetic field strength and
                        the spike isn't any more or less than if the circuit
                        was tuned.
                        Once the coil is saturated, it isn't going to get any
                        more saturated with tuning.
                        Perhaps there is a language barrier to what you're
                        trying to say but your statement was false and you
                        obfuscated that entire point in your response by
                        running everyone in a deviated trajectory away from
                        the key points. You talk in circles basically and you
                        did the same thing in the Tesla Switch thread, for
                        which you have absolutely no experience with -
                        none that you have ever proven.
                        Also, do you or do you not have any videos or
                        documentation of any of your experiments?
                        You have successfully derailed this thread away from
                        the Bedini chargers - get on topic or move to a
                        different thread.
                          was tuned.
                          different thread.
                          "Non-Productive Current" flow has been explained.
                          It is "waste." Excessively long duty cycle is
                          ineffective.
                          My own experimentation began in the days before
                          "video" was even a pipe-dream. Pre-transistor times
                          during the golden era of the vacuum tube.
                          In the days when we "peaked the grid" and "dipped
                          the plate" for maximum Radiant Output.
                          Transitioning to the Transistor and to the MosFet
                          has been without difficulty and fruitful.
                          Is there really any need to duplicate with "video"
                          what has already been done?
                          Yes, it is indeed possible to "tune" any circuit by a
                          variety of means (some unconventional) to obtain
                          a desired "output."
                          If you have found any "false" in the explanation it
                          has yet to be convincingly presented.
                          Educational resources are more abundant and accessible
                          today than ever before. Is there really any excuse for
                          "lack of understanding?"
                          • SeaMonkey, I doubt that timer driven radiant oscillator can reduce consumption with load. I tried and failed. Unless there is evidence that state otherwise I would say that timer driver radiant oscillator will always draw more current with load no matter what you do.
                            When this energy is released without being "loaded" it can climb to several hundred volts which may cause damage to the switching transistor or MosFet.
                            Mine produce 800V on DMM, >1000V on AMM and yet I only break transistor if I spark the output. It break at least 5 fan that use the same power source but only 2 transistor break.
                            When such a circuit is operating into a "load" the current draw from the source can be quite small. Then, if the "load" is disconnected and the Radiant Spike is permitted to assume dangerous proportions the transistor or the MosFet would function erratically and the current draw would increase until the device destroys itself.
                            I have never seens such circuit other then SSG or mine. What I have seen is higher current consumption with low impedance load.
                            My 555 version transistor die because of heat when there is load. And I think any other timer driver radiant circuit transistor will heat up more with load because it consume more power / current with load. More power = more waste = more heat.
                            You seems to think that what I show you on my posted video is the normal operation of a timer driver radiant circuit. It is not. Most of radiant circuit will consume more power with load. Your suggestion is false because my circuit proof that the same cheapskate transistor can operate differently just because it is used differently.
                            Give proof that the circuit you mention exists. Because that is what I am trying to achieve before I found stingo / MJT. You need to give proof because I never found such circuit exists.
                            I don't care if it is not your video.
                            • I doubt that timer driven radiant oscillator can reduce consumption with load. I tried and failed. Unless there is evidence that state otherwise I would say that timer driver radiant oscillator will always draw more current with load no matter what you do.
                              The goal of the timer driven radiant circuit is
                              not to be able to demonstrate more or less
                              current flow when loaded or unloaded; it is to
                              simply produce maximum radiant output in a
                              very predictable manner.
                              As for any circuit which will exhibit a change in
                              current flow with "loading" or "unloading"
                              it depends upon the type of circuit and how much
                              isolation exists between the source and the load.
                              Removing a "load" from a circuit to observe some
                              change in source current when dealing with a
                              self-resonant RF configuration can be very
                              unpredictable. Depending upon how well laid out
                              the circuit is; what sort of distributed inductance
                              and capacitance (stray) is present and the
                              frequency of operation. Standing Waves can
                              develop in the wiring which may result in very
                              unusual observations.
                              The susceptibility to "breakage" will be dependent upon the
                              voltage and current ratings of the device. For minimal
                              switching losses it is customary to use a device with the
                              lowest voltage ratings, consistent with circuit parameters,
                              in order to utilize a device with maximum conductivity.
                              I have never seen such circuit other then SSG or mine. What I have seen is higher current consumption with low impedance load.
                              That would be a normal situation it would seem; a lower
                              impedance would result in an increased current flow.
                              Would this be a case of "overload?" Is the load
                              causing more current to flow than the circuit
                              is capable of providing without overheating?
                              Is the transistor being adequately driven to
                              saturation for minimal switching losses?
                              Whether a circuit will consume more or less
                              power when "loaded" depends upon the nature
                              of the load and how it is coupled to the circuit
                              in question. In a laboratory setting where such
                              determinations are made great pains are gone to
                              in order to assure that the circuit operates without
                              any "anomolies" and that the "load" is seen as
                              purely "resistive" and is properly matched to rule
                              out the formation of "reflections" and "standing
                              waves."
                              A "breadboarded" circuit, or a "clipped" circuit may
                              have large amounts of distributed inductance and
                              capacitance (stray) which will cause very odd circuit
                              behavior.
                              Without knowing precisely what is taking place within
                              all of the wiring it will be very easy to come to erroneous
                              conclusions. Particularly when dealing with "Radiant"
                              energy and Radio Frequency waves.
                              I am a firm believer in using "cheapskate" transistors
                              by the way. Using the least expensive of devices is
                              good policy.
                              The most common type of circuit which will demonstrate
                              excessive current flow when "unloaded" or when "mis-
                              matched" to the load is a Radio Frequency Amplifier
                              and its associated Antenna.
                              When a "mis-match" exists between the Amplifier and
                              the Antenna a large standing wave develops which
                              will cause excessive current flow in the Amplifier.
                              Once the Antenna is "tuned" to present a proper
                              impedance to the Amplifier and the Standing Wave
                              dissipates, the Amplifier current flow is minimal.
                              If you've ever dealt with a Radio Transmitter and
                              its Antenna Coupler then you've already seen that
                              kind of circuit.
                                different thread.
                                Aaron has requested that all discussion not directly
                                related to the topic be carried on in other locations.
