Re Weird thing.
I have noted that with the SSG, that if I leave the charging battery plugged in it will drain it. Also I have noticed that the higher the charge of the charging battery the less work there is on the primary battery.
I have started putting a capacitor on front with the supply battery and I have found this was of good benefit to the circuit. It seems to buffer the systems request for more energy, and put less stress on the primary battery.
I am thinking you are moving close to building the window motor in what you are doing.
Mart
Mart
The relay seems to work well, there is no arcing on the contacts if I don't let the voltages on the caps go higher than 17-18v. Now I am charging only one 7Ah battery on the output.
