Have not experimentally confirmed but has occurred to me and is obvious. First to define the issue with behaviour change of batteries when charged radiantly; many on this forum have attested that when charged radiantly, batteries no longer easily accept a conventional charge, this experimenter will also attest to this. I do not have a clear understanding of why this happens but have a conceptual framework that I suspect is useful and not far off the truth. The first important point is in the SSG there is half wave rectification, this situation cannot be rectified by a full wave bridge rectifier. That is to say the coil charges and there is a magnetic flux in one direction, this flux cannot be captured as such a diode would short the power source. The coil collapses and this reverse magnetic flux, yielding a reverse current, may be expeditiously captured as has been amply demonstrated. One only captures the collapsing, not the rising magnetic field, hence there is half wave rectification. 2) The energy in a battery is potential energy resulting from the conversion of electrical energy, the inductive spike, into chemical energy. As we all recall from H.S. chemistry chemical equations must be stoichimetrically balanced. In some way that I don't understand, perhaps it is an issue of relativity with regard to potential, the half wave rectification only drives one half of the equation and in so doing consumes all available charges to drive the other half. When you go to charge conventionally, the chemistry of the battery is imbalanced such that you can not easily achieve stoichiometric equivalence, this would also explain why a full chemical discharge allows the battery to again charge conventionally. I may be wrong, I am open to a better explanation.
Why does the Bedini Coil circuit get rid of this problem? So I took this afternoon and picked up a 3 Volt DC hobby motor from the toy store, man I love that store! The goal was could I rectify the changing magnetic field off a DC motor. Yes, I was able! Just place a BR across the positive and negative and you can rectify the dc motor's magnetic flux. Running at three volts, there is no change in amp draw, no change in rpms and the captured power was about 2 volts with a small but not negligible current. Astonishing. If not terribly useful. It did however occur to me this is the conventional path from AC power to DC output where batteries do not show behavioural changes. What's the inverse of an inverter, an alternator or is it something alternate? When batteries are conventionally charged the coil is going from one polarity to another and back again with that flux being rectified. The Bedini Cole commutator of course is doing the same, powering the coil with current in one direction, then reversing it. Of course a small coil 3 volt hobby motor where the BR diodes consume 1.6 volts and the coil is saturated the majority of the time is not ideal for generating a maximal inductive spike, but after seeing this it did occur to me to mention the inisght.
How is this useful? Well, many people have worked on Solid State battery chargers and are unable to rotate the batteries despite an apparent surfeit in power. With a bipolar commutator circuit you are now able to rotate the batteries. Additionally, any motive force motor that flips coil polarity with said circuit such as the Bednini Cole Window motor, should also be fine charging batteries which will then behave in a conventional manner.
