My 4 Foot Bedini
  • My 4 Foot Bedini
    Hi this is WHY_ME
    4 foot bedini on youtube.
    @Aaron WHY_ME cannot seem to get on to this group other than by private
    message. Could you please correct this problem that WHY_ME has been
    having now for sometime. I told him to email you but that does not work.
    Either way some do have difficulty getting the site to function where they
    are, it did happen to me also.
    Thank You Aaron for all of your hard work to keep all of the people connected.
    Here it that Killer Bedini
    [VIDEO]https://www.youtube.com/watch?v=qU5oiTJG4kI[/VIDEO]
    Why_me
    WHY_ME's account looks fine and he should be able to post.
    What error messages if any is he getting?
      I am not sure, he can see this, so maybe he will email me again
      privately and I will relay to you. Or maybe he not use to the site.
      You got me Aaron, but as always you are as fast as the Minutemen were
      and will do your best to see why WHY_ME is not able to post anything.
      Maybe he is not responding to emails already of the forum, instead
      is trying to learn how to start his own thread? We will see.
      Are you there WHY_ME??? LET ME KNOW.
        24 volts?
        Can you run an eight circuit Bedini on 24 volts? Will the charge batteries need to be 24 volts? What about component upgrading, watts....etcetera.
          7 coilers run 8 transistors
          My first coil that I bought is a 7 coiler. I used 7 transistors on the circuit board. It holds eight. I bought another 7 coiler and used it in parallel with the first coil. Works great. Then I added the eighth transistor. I unhooked the first pair of wires at the first transistor, then used one wire each for the first and eighth transistor. Now my 7 coilers run an 8 circuit Bedini.
            I don't know on the circuit configurations.
            Nice solid Bedini. How many batteries can it keep charged up?
            I saw your video and it sounded like you were saying that you could
            take power off the battery while it was running. That is a powerful
            build. I will be interested to know what all of those magnets do.
              Parallel coils
              Each 8 transistor circuit board runs 2 coils in parallel. I use 4 circuits presently. The coils are side by side, touching at the plastic spool. When you stand in front of the wheel, looking through the magnets, you can see the coils side by side. This is just as wide as the magnets and causes more magnetic push pull of the magnetic field being generated by the coils in parallel.
                  Will be watching and waiting for more from you! Perhaps you would be so kind as to turn off the background sound so we can give you full attention in your next video?
                    Repulsion mode
                    I had to put one pair of coils in repulsion mode to make them magnetically in phase with the other 3 pair. It got a little faster. Just remember to switch the trigger coil(s) to their opposite placements and your repulsion mode circuit will run cool.
                      24 volts?
                      I hooked up the circuits to 24 volts and I use a 24 volt battery buffer. Two 12 volt batteries connected. The main source is 24 volts at 1000 amps, so the two 12 volt battery buffer is required. The circuits run a little bit warmer, but not much. The wheel spins a whole lot faster and the 24 volt charging causes the charge batteries, (12+12) to charge incredibly fast. This afternoon the charge batteries were down to 3.12 volts from 32 volts, I used fans and a spot light for that detail. I turned on the wheel, gave it a push and 45 minutes later I had a full charge of 32 volts. I then had to turn it off. My next step is for loading the wheel down with the generators and drive chain. If it holds, good, if not then I will add more coils and circuits until this happens. In the future I will replace all the MJL21194 transistors with FJL6920 transistors. I will also replace the diodes with 1N5408 and upgrade the resistors in wattage.
                      Here is an engineering note for TeslaGenX circuit boards, the primary negative has a circuit trace between the 2 post positions, use a thick, copper wire to physically connect the two spots on the board. It will help to do this if you plan on amping the circuitry.
                      The board is well designed and I offer this for future experimenters who might wish to follow this experiment.
                      Did I mention the board is well designed?
                        You can. Depending on the coils determine what best voltage to apply... as you go to higher inductance coils (ie. longer windings) you'll see a need to go higher in voltage to get the same sort of rpm back out of the rotored version...
                        If you go to fatter wires that are shorter, then you'll see a need to drop volts... otherwise the transistors burn up... I did a 3 x 14awg stator... and when I took it to 24vdc input it burned up the mjls. There does seem to be a curve that can be plotted for best input to output being realized...
                        one other tidbit regarding bedini... his inductive trigger tends to get his circuits to fire using 1/3rd of the first time constant as the total ON time... and it seems to be that effect that gets the best Collection into the charge batteries or the collector cap, whatevers synching the output. (that 1/3rd of the total time constant is as applied to the solenoids inductance measure thats being used in the circuit... its that L's single TC that has 1/3 of it used as the ON time... )
                        Cheers!
                        Gene
                          No new video yet. I feel the money crunch. I charge a 1000 amp hour bank in a day and there is no smelly gas to tell since the last three charge sessions. They are in good shape and I run the wheel on a bank of 8 batteries, 24 volts at around 50 aH. It lasts about 24 hours before recharging is needed. I plan solar recharging for that using amorphous panels if possible.
                          I will try more sharing later.
                          • #14
                            Solar coupled with the SSG can be a highly efficient scheme for
                            energizing batteries so 100 percent conversion may be possible.
                            Also I would like to stress for those who are willing to experiment
                            that John Bedini has publicly added that he uses magnetic
                            gates in his more advanced models. See the 2010 convention.
                            Also from the very beginning John Bedini used GENERATOR COILS
                            as the next step in the beginner designs. If the Generator coils
                            are done right these coils increase rotor torque even in a shorted
                            condition lowering input power for no explainable reason.
                            Most conventional thought keeps us thinking that the GENERATOR
                            COILS drag down the rotor and energy returning is less than the
                            input. That is incorrect. That is not how the GENERATOR COILS
                            should work.
                            We are after a delayed LENZ effect so 3-5 times longer GENERATOR
                            COILS store energy till after TDC when the energy is then released
                            to assist rotor action.
                            I know this is only a small entry but this is a mouth full, trust me.
                            Experiment with very long very thin wire gauge coils in a shorted
                            condition to prove out this idea. THANE HEINS also talks about
                            this delayed LENZ that JOHN BEDINI used, but THANE explained
                            what is going on much more clearly.
                            Little by little the answers will come. Enough GENERATOR COILS
                            added to an SSG can make it a self runner and much more but
                            not the way we all have been thinking. It is a trade secret.
                            If you have an SSG and desire it to self run, add a large coil
                            somewhere around the frame that is very very long and very thin
                            wire. Trial and error is one way to arrive at the optimum length.
                            Low RPM machines need very long windings.
                            Maybe wind it to long and also remember to wind it BIFILAR or
                            even TRIFILAR adding the end of one coil to the beginning
                            of the next to increase self capacitance.
                            More information is available.
                            • #15
                              This is what your battery bank hook up should resemble.
                              If you charge them with chargers, the cable clamps are indicated.
                              This is a 24 volt bank used for running the 4 foot Bedini.
                              It has to last at least 24 hours before recharging.
                              When used with solar charging, it would be necessary.
