Jibbguy - your post 974 is excellent, yet again.
The Fluke resolves this problem of how much is out/in through its DC coupled function. It computes the sum of the two waveforms. In other words - when you do a dump on the numbers you will see the volts are shown with either negative or positive vlaues in relation to zero. The sum of those samples over its sample range gives the actual voltage. That's a true measure of the voltage for power analysis.
Regarding the analysis of the power dissipated - this needs to factor in the inductance. The fluke does not do this. Therefore we confined a measure of the power dissipated to temperature analysis as shown in the paper.
However, having said this - the Fluke can display two functions simultaneously. It shows what it calls the DC function and a second ACrms function. If the probes are across a non-inductive shunt - with both functions displayed - it is very easy to gauge the optimised duty cycle by comparing those numbers, the DC display being less than the ACrms. We have also found that the rate of battery depletion is consistent with the measure of power from the supply based on energy calculations of that DC displayed voltage.
I cannot understand why it is that we never see the displays of either of these two numbers, let alone both simultaneously, in any of TK's videos. It seems to be a remarkable waste of some some very important features in that really expensive equipment. And I believe it is critical for analysis.
I would add that the Fluke function, as described above, is precisely the point where our accreditors were obliged to concede that the question needs to be addressed by academics. We've never yet sucessfully solicited comment from an academic based on this very evidence. Thus far - no academic opinion.
Jibbguy - thanks for all this. Please consider these comments. I hope I've made it clear. And please let us know what you think?
