Originally posted by Raui
Kokomoj0,
I'm not saying your wrong, a high resistance is a low conductance and visa versa but I fear that is a reductionist way of looking at things. Eric has stressed since the start that what he is trying to convey is more along the ideas of Goethe than conventional science, which should be attributed to Newton, as is shown in the following quote;
and here;
So with that in mind let's look at our disagreement on using conductance and resistance interchangeably instead of low resistance/high resistance. It actually has striking similarity to the battle waged between Goethe and Newton as to a theory of colours. Goethe believed that colour was an interaction between two polar opposites, being light and dark. Newton refuted Goethe's arguments claiming that darkness was only the absence of light and so colours could not possibly be an interaction between light and dark. It is interesting that the Heaviside equation (Off the top of my head it is (RG+XB)+j(RB-XG)), which Eric states is the most fundamental equation in electrical engineering, can be reduced to ZY. This implies that electricity is the interaction of two polar opposite quantities being impedence and admittance in the same way that Goethe said colour arose from the interaction of Light and Dark.
So let's contrast this with our current discussion- Your saying that I am wrong/misinformed because conductance is just a lack of/low resistance, in the same way Newton argued that darkness is an absence of light. Since we are learning Eric's theory we shouldn't try and bring in Newtonian scientific concepts into a concept which has been stressed, repeatedly, that it is Goethean. I am not saying that the Newtonian concepts aren't without their worth but we are moving beyond Newton into a different way of doing science. I feel you might be trying to force the square to be a triangle. Another T-Rex quote. (Yes I know we aren't necessarily talking dimensions here but I feel he'd say a very similar thing to this in response to what we're currently discussing)
Now as for the consumption/production problem. Yes I am aware that to a scientist/engineer trained under conventional theory thinking of the 'consumption' of electricity is a misleading term but again we aren't learning conventional theory we are learning an entirely different theory based on an entirely foreign method of scientific investigation. When a physicist here's the term 'consumption of electricity' they think that one is talking about the consumption of moving electrons which IS a wrong concept, however Eric is moving away from an electron based electricity.
When I say consumption and production I am talking about field lines issuing from the metallic-dielectric confines which seem to just appear out of the geometry with no apparent source (production) and disappear in the same fashion (consumption), what other words should I use? It's interesting to note that to a conventional physicist field lines are just useful analogies to teach students but to the people Eric is references (Heaviside, Thompson, Steinmetz) field lines have a concrete reality. Would you be happier if I used the term 'convert' instead of produce and consume? To me there is no difference between saying convert and saying something consumes one quantity whilst simultaneously producing another quantity and I'd say the answer you prefer would be a matter of philosophy. The other major reason I use the two terms is that Eric uses consume and produce to illustrate these concepts and so I have used these terms as not to further confuse people on an already confusing subject.
If you've never heard of Goethe here is some reading;
Light and Electricity by Tom Brown
Man or Matter by Ernst Lehrs
Garret,
Thanks for your response
It's given me some things to think about, I will form a reply a little later.
Raui
and here;
Garret,
It's given me some things to think about, I will form a reply a little later.Raui
I do not have a word off the top of my head, I would have to give that some thought. I do not want to turn this thread into an argue fest, so we will agree to disagree.
That means I'll need to lay out a star radial ground terminal system. Probably 16 x 75-foot runs of copper wire, tied to a central ground stake and to stakes at the end of each radial. In the vicinity where I want to put this, I have a buried shipping container used as a root cellar, so I have a large buried body of steel that I will likely tie into.
