The following transmission will be broken into four parts due to a restriction in number of pictures per post.
Peter, whatever happened with Eric P. Dollard?
This topic is closed.
This is a sticky topic.
Last edited by t-rex; 12-13-2011, 06:56 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
(8)
(8)
Hence
(9)
Or
(7)(10)
Equations (7) and (10) give the same dimensional relation for magnetic and dielectric force.Last edited by t-rex; 12-13-2011, 06:57 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Mechanical and Electrical Forces Part 3 of 4
The force cancellation is given by,
(33)
, Ohm
For equal and opposite forces.
Next consider the A.C. relations for equal and opposite forces,
, or Last edited by t-rex; 12-13-2011, 06:58 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Mechanical and Electrical Forces Part 4 of 4
This is not the result expected which would be thought to be
(46)
Ohm
What of this discrepancy? Is the previous line of reasoning invalid? Only concrete Physical Experiment can give the facts. Math can lead you down many paths, images of its own expression.
Returning to equation (34), and substituting the relation
Planck per Second, or Joule,
It isAnd
Dielectric field for equal and opposite voltage plus or minus 500KV,
And for,Equal voltage on both lines of plus 1000KV
Likewise, for the magnetic fieldEqual and opposite current in both lines plus or minus 1000 amp.
And forEqual current in both lines of plus 1000 amp.Last edited by t-rex; 12-13-2011, 06:58 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Make Your Own Tesla Telluric Transmission System
This post is in response to Kokomojo post #646
A good coil to use is the flat spiral shown on the "Tesla Longitudinal Electricity" video. It's on the 160 meter HAM band. Remember that you must have a government license to transmit R.F. energy.
The "primary" coil is the magnetizing coil. It connects with a constant potential, thus the few turns the better, one is best. Surface area is equal on all windings and also equal to the surface areaa on the condenser. Basically all component coilsand the condenser should be the same weight. Max magneto motive force (m.m.f.) is what we want here in the primary. The "extra" coil is the constant current, maximum potential is what we want here, on the sphere, sphere capacity small.
It is important to note these coils are no longer to be thought of as just reactance coils, now they are transmission lines, and operate by the laws of transmission lines.
Hence given is the constant potential primary, a lumped LC circuit of very large b to a ratio ( a is the power factor and b is the induction factor- see Heaviside equation) , also there is the constant current extra coil, a distributed transmission structure in the form of a coil. Copper weight is the same. Also note b/a is the magnification factor of the circuit.
Hereby, the "secondary coil" is a transmission structure connecting the constant current extra coil to the constant potential primary coil. Hence the "Secondary coil" has an impedance and is a quarter wave resonant so as to match the constant current coil to the constant potential coil. That is the radio engineers description of a Tesla Magnifying Transmitter. No new theories or mystical unknowns, a basic transmission line calculation only. Simple. But, you better have an A.M. braodcast station ground for this system to operate.
So let's use an A.M. station as an example. 1600 on your A.M. dial. It has a quarter wave tower, a star ground plane consisting of 120 radial wires each a quarter wave long. A matching unit connects this to a 5 kw transmitter, the "alternator" of 1.6 megacycles AC.
Now lets shorten the tower, a "loading coil" must now go in series and resonate with the shortened tower. The ground current has increased. We keep doing this, shorter tower, bigger coil. Finally no tower, giant coil, high ground current. The coil is now resonant to it's own internal electro-static capacity. The price to pay for the high ground current is an extreme potential, e, at the open end of the coil. This is why the "mushroom" hood, or just a sphere. This extreme potential energizes the Resla "Ray" Tube for atomic work, not radio work. The ground end of out "Loading Coil" is the output NOT the mushroom cap. No one gets this. So we have converted 1600 on your AM dial to a Tesla Telluric Broadcast. No hidden secrets, no profound mysteries, just simple A.C. Ohms Law and a HAM radio license. "Theory of Wireless Power" gives all the coil calculations for impedance and propagation time. but the "tables" have errors. The basic formula is ok. "Condensed Intro to Tesla Tesla Transformer" gives a more specific theoretical description of the Tesla Transmission structures, including impulse modes. This paper is more for the radio engineer. Tesla gives a complete description, with photos and calculations, of his system in "Colorado SpringsNotes." Also the unit at my RCA laboratory is on the cover of "Condensed Intro to Tesla Transformers." No shortage of experimentally confirmed information on this topic, even by Tesla himself.Last edited by t-rex; 12-13-2011, 06:59 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Awesome, thank you!
If this is not redundant as I will need to give everything you said a good think through, (several times), I have another question, you may have answered it I am not sure at this point.
My main interest is in building the Magnifying transmitter and reciever and doing tests on it to confirm or deny the claim that it takes in extra energy. That is my main goal, however I may now have 2!
It would be great fun to be able to measure more power coming out than put in. I believe to do that one must ideally completely null the TEM side.
That said what I am really looking for in the final analysis is tips on how to remove all tem transmission completely from the system and only transmit LMD. Maybe you have given me enough information that I should have picked up on it already and fail to see it at this point, if so please simply ignore this.
T-Rex,Originally posted by T-rex View PostThis post is in response to Kokomojo post #646
Tesla used litz wire in many instances. One reason is due to skin effect. Might not the other reason be that the multiple stranded dielectric insulated litz wire increases the inter-winding capacitance giving the ability to shorten the length to width ratio and create self-resonant conditions?
OrionLast edited by OrionLightShip; 12-12-2011, 10:58 PM.
Attempting to resolve Dimensional Inhomogenities
NOTE: In attempting to understand the new material presented, I backed up (as one person suggested) and read all the posts from the beginning of the thread and have carefully collated some equations as they are serially presented. There are important questions to be addressed, in attempting to satisfy Fourier's principle of dimensional homogenity for the equations and qualities presented.
Furthermore, I just now found out that new posts have arrived, before this post could be presented, I don't know what to do about that, as it is frustrating to establish a serial thread here.
Heaviside Equation:
(1) (R*G + X*B) + i*(X*G - R*B) = propagation constant^2
Note: This is a complex product of (R+iX)*(G-iB) or (X-iR)*(B+iG)
Physical Quality Dimensional Units
R = Resistance in Ohms ?
G = Conductance in Siemans 1/?
X = Reactances Henrys/second ?/sec
B = Susceptance Farads/second ?/sec
R*G is scalar or DC component (dimensional units in R and G are reciprocal)
X*B is longitudinal or AC component
X*G is transverse or OC component (forward moving)
R*B is transverse or OC component (backward moving)
A post says that male is dielectric field in counterspace (/cm) and female is magnetic field (cm^2)
(we have mismatch of units, one is /cm the other cm^2, so which is in error?)
(2) Dielectricity * Magnetism = Total Electricity Q
What is the product * mean here? dot product? cross product? complex product? as it is not yet well defined in the dimensions.
A post defines Q as Planck as watt*sec^2 not as NIST (conventional) joule-sec.
Energy is the usage of Q/second = watt*sec which is our standard understanding
(3) E = dQ/dt in conventional terms where Q is total electricity (not charge!)
1 Planck/sec = 1 watt-sec (answering the question of how many Plancks/sec are in a watt-sec)
The dielectric field density must equalize the magnetic field density to equalize forces.
But forces is a term introduced but not defined, nor is its relationship to either field density shown, just implied.
Is this a physical force? field force? measured by weight units? Ambiguous and undefined at the moment.
Important idea: Counterspace or Reciprocal Space (fractal space) 1/n
i.e. 1/cm is less counterspace than 1/nanometer per unit length
A post supplies a familiar analogy, stopping a car with F = m*a and it specifically says that a is dV/dt (which it is)
(4) F = m*a = m * dV/dt (where F is force, m is mass, and a is acceleration)
Then the analogy is presented that dQ/dt = W (energy)
(5) W = dQ/dt (but what happened to mass or space?, by analogy to (4) )
We appear to have something missing in (5) in regard to space being acted upon by the change in total electricity during a time interval. What is it?
A post criticizes the time integral of W dt = Q.
The neglecting of C (the constant of Integration) is problematic here, perhaps detrimentally so, because C might well be some amount of total electricity. Furthermore integration is totally unable to say anything about the original quantities to start with, so it appears valid to differentiate, not integrate, in order to not lose anything valuable under consideration.
A post states that it only takes 2 quantities to specify the volume of a cylinder: height and circumference.
Was diameter or radius meant here, not circumference?
Mathematicians note that the formula is
(6) Volume of a cylinder = height * area = height * Pi * radius^2
This has dimensions of length^3, since height is length and radius^2 = length^2, so we cannot escape 3 dimensions.
A post then states that:
(6) Psi (dielectric induction) * Phi (magnetic induction) = Q (Planck) watt-sec^2
(we still need to define * operator here, and formalize the units for Psi and Phi)
A post argues 4 basic units for Electrical Engineering:
1. Time t dimensions:1
2. Space s dimenions:3
3. Dielectricity Psi dimensions:? 1/length
4. Magnetism Phi dimensions:? length^2
We need to resolve ambiguity on 3. and 4. for length so they mutually cancel on their product (whatever that is)
(7a) d(Psi)/dt = I (amperes) displacement current flow (not conduction current)
(7b) d(Phi)/dt = V (volts) electromotive conduction volts (not electrostatic)
It is stated:
(8) Phi/Psi = Z (impedance) in Ohms (E/I = Z)
and Inversely
(9) Psi/Phi = Y (admittance) in Siemans (I/E = Y)
Two distinct I currents and two distinct V voltages are mentioned.
Important Question:
Define I displacement current and I conduction current?
Define V electrostatic field and V electromotive difference?
I believe that it is very important to properly define these two types of physical qualities. Can this be done at this time?
It is restated:
1 Psi * 1 Phi = 1 Q Plank watt-sec^2
What are the dimensional units for Psi and Phi ?? Do they have dimensionality of watt^(1/2)*second ?
And again, in regard to watts, that it is
W = dQ/dt (joule or energy)
We need relationship of watt to joule defined. Later on we find watts cannot be = joules as the dimensions do not match. NIST defines watt as joules/sec so watt-sec^2 = joules*seconds
Does Planck have dimensions of joules*seconds? There appears to be ambiguity in using the term joules and watt-sec^2. Can this be resolved for everyones' understanding?
A post defines:
Coulomb (charge) Psi = Q/Phi
Weber (induction) Phi = Q/Psi
What are our units here?
Can we mathematically say that
dQ/d(Phi) = Psi (instantaneously)
dQ/d(Psi) = Phi (instantaneously)
so that
E = d(Phi)/dt (as above) unit: volt
I = d(Psi)/dt (as above) unit: ampere
However the two types of voltage and current are still ideas, not formally defined.
A post resummarizes:
Group 1 (primary)
Q Planck (watt-sec^2)
Psi Coulombs ( ?/sec )
Phi Webers ( ?/sec )
W joules (joules ?? watts? ) (This has to be watts, not joules)
Group 2 (derived)
E Volts ( ??/sec ) or d(Phi)/dt
I Amperes ( ??/sec ) or d(Psi/)dt
What about the two types of E and the two types of I ?? Can we
define them properly?
(This seems to be hinting that we need complex numbers to adequately
describe what is going on)
joules/sec = watts (so there is a mistake equating joules = watts above)
It is pointed out that humans overlay space with dimensions. (usually 3)
Positive Space
length = cm^1
area = cm^2
volume = cm^3
hypervolume = cm^4
N-volume = cm^N
Reciprocal (Counter) Space
span = cm^(-1)
density = cm^(-2) (density is usually thought as volumetric)
concentration = cm^(-3)
diffusivity ? = cm^(-4)
N-diffusivity ? = cm^(-N)
A post gives:
l^3 * Q = Planck cm^3
l^2 * Psi = Coulomb / cm^2 (so l^2 cannot be right, it has to be l^(-2) )
I stopped at September 30, 2011 12:19 pm posting, as there are questions that I have above that need to be addressed, because of the confusion in dimensional homogenity. Can they be addressed?
Later on I suppose a discussion of mass (kg or grams) might be brought in, but it is okay to ignore mass for now, since none of the material above, except for implied force right after equation (3) above is mentioned.
NIST carries the base units (qualities):
1. length (m/cm)
2. mass (kg,gm)
3. time (sec)
4. electric current (Ampere)
5. temperature (K deg)
6. amount of substance (moles)
7. light intensity (candelas)
For now, I will leave discussion of mass aside, and we notice already that item 4. electric current is in trouble, because it avoids the discussion of what type of flow it is, displacement current, or conduction current, which are totally dissimilar.
We probably don't need to talk about temperature, nor Avogadro's constant, and light intensity is probably energy projected onto an area, so it probably is not as base unit and should be removed. After all, we do have materials absorbing energy in other frequency bands than light.
- Randall
Generally you do not want to create inter-winding capacitance, that lowers the impedance and lowers the voltage and in some cases lowers the magnification factor. In the extra coil you want the lowest capacity possible. That's why Tesla used coils of equal width and height. If anything litz wire decrease capacitance. It creates less flat plate area.Originally posted by OrionLightShip View PostT-Rex,
OrionLast edited by t-rex; 12-14-2011, 11:54 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
You have just taken all the work I have done in deriving new dimensions and tried to convert them back to physics dimensions. You want to go back to physics. I just got done going through 40 papers to get physics out of this! Heaviside and Steinmetz didn't go through all this trouble to turn it all back around again. Are you sure you know what dielectricity and magnetism are? Physicists have no business in dealing with this sh**. I derived a system of units that stand by themselves. Use the units I have derived NOT physics units. Physicists have no idea what electricity is- they don't even believe in the Ether!Originally posted by Logical American View PostNOTE: In attempting to understand the new material presented, I backed up (as one person suggested) and read all the posts from the beginning of the thread and have carefully collated some equations as they are serially presented. There are important questions to be addressed, in attempting to satisfy Fourier's principle of dimensional homogenity for the equations and qualities presented.
Heaviside Equation:
It is stated:
and Inversely
Important Question:
It is restated:
A post defines:
so that
Group 1 (primary)
Group 2 (derived)
Positive Space
length = cm^1
area = cm^2
volume = cm^3
hypervolume = cm^4
N-volume = cm^N
span = cm^(-1)
A post gives:
1. length (m/cm)
2. mass (kg,gm)
3. time (sec)
- RandallLast edited by t-rex; 12-13-2011, 06:59 PM.SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Actually I was speaking about the secondary.
Orion
Originally posted by T-rex View PostGenerally you do not want to create inter-winding capacitance, that lowers the impedance and lowers the voltage and in some cases lowers the magnification factor. In the primary you want the lowest capacity possible. That's why Tesla used coils of equal width and height. If anything litz wire decrease capacitance. It creates less flat plate area.
Please point me to the exact point in Eric's posts where this is "restated".Originally posted by Logical American View PostNOTE: In attempting to understand the new material presented, I backed up (as one person suggested) and read all the posts from the beginning of the thread and have carefully collated some equations as they are serially presented.
It is restated:
Thank you
pt
back in 8/22/11Originally posted by pault View PostPlease point me to the exact point in Eric's posts where this is "restated".
Thank you
pt
Originally posted by TrexContinuing then it has been given that the total electrification Q is the union, or product, of the total dielectric induction Psi and the total magnetic induction Phi, Psi times Phi equals Q. In other words, the dimensional relationship Q, the total electrification, is the product of the dimension of total dielectric induction Psi, and the dimension of total magnetic induction Phi....
Originally posted by OrionLightShip View PostActually I was speaking about the secondary.
Orion
I had to read that a couple times myself.
I think he is talking about each?
Originally posted by T-rex View PostGenerally you do not want to create inter-winding capacitance, that lowers the impedance and lowers the voltage and in some cases lowers the magnification factor. (end)
Secondary
In the primary you want the lowest capacity possible. (end)
Primary
That's why Tesla used coils of equal width and height. (end)
Both
Can we think of that as similar to the flat wound amature transmitter coils?
does any of that sound right?
So do I read it correctly that we want Hi Z, Low inter-winding C, because that will result in higher magnification?
I am still plugging away on a couple things in his response to me too.
So I presume that fence is a huge primary magnetizing coil, the one he is siitting under is the secondary, and the center which is that same height as the secondary I presume is the extra "tesla" coil with the sphere on top?
@Eric
is the secondary wire spacing that gets wider toward the top because of poor insulation and high voltage or is that some kind of tuning? both? From what you are saying it sounds like we would want that secondary to be close wound and also the extra tesla coil with the sphere on top to be close wound? The primary I remember you mentioned using strap bronze for good impulse response.
Maybe I should be asking what we are all looking at in that pic
That sphere almost looks out of place? and the center does not look like coil but a pipe. Like the center of a transmission line?
