Peter, whatever happened with Eric P. Dollard?
This topic is closed.
This is a sticky topic.
  • @Pinwheel
    It was our own design, based strictly on finding the most convenient method to alter inductance synchronously.
    The first major revelation was that it took a *decrease* in inductance to cause an *increase* in current. Many had stated that it was an *increase* of inductance for an *increase* in current. Of course for a given amount of energy, that is exactly what you would expect...current must go up if inductance goes down. Obviously there must be some gain there, or the system would not ramp up to high power levels.
    The second major revelation was that mechanically reducing inductance takes work, and work isn't your friend. From what we could tell, we were heading toward unity at best.
    I had actually dug through the Russian document at the time and had already concluded that their motor was loading like ours. They were not using a ferrous core, so my guess is the parameter change mechanism is a magnetic field in the rotor created by eddy currents. Aluminum simply wouldn't provide enough of a permeability change to alter the inductance much. The aluminum would be very happy to oppose the magnetic field in the inductors via it's own field though. I don't have proof of that, but their statement that they were unable to go to higher current due to the motor limitation was a big clue. Magnetic damping gets bad fast.
    It's clear that synchronous parameter change can be used to produce energy, and it may even be possible to do it without an offsetting bit of mechanical work...however...I suspect that it will require parameter change in some kind of light speed scenario. Meaning that the real answer to power synthesis is not directly in parameter change, but is in some kind of quadrant manipulation that shifts the action/reaction to 90 or 0 degrees instead of 180.
    Resonant solenoids are standing wave devices where the operating frequency is inherently related to speed of light (if correctly tuned), whereas LC resonances are not necessarily so. As such, I suspect that the answer will not be found in the simple LC, but in the coil. I feel that the C implicit in the coil is not symmetrical, and that the asymmetry manifests increasingly as the standing wave amplitude increases. That may provide the parameter change in a quadrant friendly way, and if that is true, the coil may exhibit gain by parameter change without any external intervention other than normal excitation. Since the coil would be gaining energy during a portion of the cycle, and giving it back during the other, it would have to be externally harnessed and would not have the potential for internal runaway. A dual coil arrangement would offer the possibility of a runaway, if it could be phased correctly.
    It is my hope that EPD is moving in the direction of eventually reducing the theory to 'when A, B, and C are true, reaction-less energy production D occurs'. My gut tells me the math will bear that out, but applications are our focus here, not theory.
    • Hi all,
      I managed to disprove Einstein's relativity theory once and for all:
      Tuks DrippingPedia : Ruins 96 Years Einstein Relativity
      Last week the newspapers were filled with the discovery of "impossible" particles traveling faster than the speed of light. A month ago an "impossible" star was discovered and earlier the Pioneer space probes also refused to adhere to the law. This way, the scientific establishment will slowly but surely be forced to return to reality, the reality of the existence of a real, physical ether with fluid-like properties. The inevitable result of that will be that Einstein's relativity theory will go down in the history books as one of the biggest fallacies ever brought forth by science. In the future they will look back to relativity with equal disbelief as to the "Earth is flat" concept. The relativity theory not only goes against common sense, as Tesla already said in 1932, a fundamental thinking error has been made by Maxwell in his equations. This eventually lead to the erroneous relativity theory, as is proven in this article. It is therefore no exaggeration to state that the scientific establishment is going to have a religious experience.
      This article has been published in Dutch on a few websites and an interview with me was published in a regional newspaper read by about 300.000 people about this.
      Of course I referred to Eric's work in the article and I refer to this forum as "peer review"
      Hopefully, the next stop will be the Keiser Report on RT:
      Twitter
      Keeping my fingers crossed...
      Update: Now also posted on BeforeItsNews:
      Before It's News - Electrical Engineer disproves Einsteins Relativity Theory
      Please don't hesitate to comment there and may be return a couple of times (or use the F5 button) to increase popularity
      • SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
        • Hi Eric
          Can you please suggest a simple experiment/device where we can build a free energy device to power our homes and cars? Around 10 kw power output?
          Cheers Mike
          • Originally posted by vrand View Post
            Hi Eric
            Cheers Mike
            Here is Eric's reply on his Yahoo egroup n6kph forum:
            n6kph : N6KPH
            Thank you Eric
            Cheers Mike
            Sent: Friday, September 30, 2011 1:55 PM
            To: n6kph@yahoogroups.com
            • link to video?
              /edit - is that the one Lindeman built?
              • No one yet on how many Plancks constitute a Watt-second-second. Where is
                an understandable quantity of this dimensional relation? Look at laser
                light on white surface, notice all the tiny little Plancks? Well?
                How many Plancks are in a Watt-second-second?
                Well, a Planck per second is a joule. And a watt second is a joule...
                Let me remind everybody that I would probably (likely) fail a high school math course if I were to take one... (not joking)
                so... I'm left with 1 per second. Q/sec.
                No?
                I didn't do the laser part.
                • So it sounds to me like Mr. Dollard likes poking the hornets nest. Great fun. I don't hear any actionable intel here though.
                  I guess I qualify as one the idiots Eric. I'm not terribly smart and most of the math goes over my head. However I am quite gifted at taking real technology and producing real products that solve real problems. Been doing that for about 20 years now and have built a very nice life for myself and my employees. When your theories have been distilled to actionable technologies, I'd love to have the discussion on how that can become a benefit to humankind and a poke in the eye to the establishment.
                  In the meantime, I wish you all great success in the lab. Back to lurking.
                  • I have a D.C. transmission line, the conductors are 2 inches in
                    diameter, spacing is 18 feet. How many ounces of force are developed
                    upon a 600 foot span of this line, for the following;
                    1. 1000 ampere line current.
                    2. For 1000 KV line potential?
                    I am waiting.
                    This must mean forces between the conductors(?) and not F = Work/Distance(?)
                    • Originally posted by Pinwheel View Post
                      link to video?
                      Here is the 1987 Santa Barbara Borderlands, 2 hrs long video:
                      Free Energy Research with Eric Dollard, Peter Lindemann and Thomas Brown on Vimeo
                      The 15 min. AC Faraday disk design starts at 45 min. into the video. That was a Worlds first AC Faraday disk design. Maybe with modern NIB magnets, the AC voltage output would be higher than the estimated 0.5 volts?
                      Peter Lindemann wrote a little about that AC Faraday Disk on this thread:
                      http://www.energeticforum.com/renewa...html#post88061
                      Cheers Mike
                      • Originally posted by LtBolo View Post
                        I hear your pain Bolo, I also have been there done that for +20 yrs.
                        Take a look at that unknown 1987 Borderlands video I posted above, as there are some real working devices that can not be explained away, that shows over unity energy output.
                        The one device that was super simple that caught my attention was the AC Faraday disk generator design that looked OU back then with low powered ferrite magnets. Just think what 4 or more Neodymium Magnet N50 2X2X1" magnets on that disk would generate in AC volts and amps.
                        N50*N52*N53 :: Neodymium*Magnets :: Industrial*Neodymium...
                        cPath_1_5 | Applied Magnets : Neodymium Block/Cube & Bar Magnets - discount wholesale prices.
                        Cheers Mike
                        • Hello everyone! While I have not read all the posts in this thread, and am still working on reading all the recommended books, I thought I would drop by and lend what help I can. Here are some references related to Eric's response at the Yahoo! Group:
                          I feel that it must always be kept in mind that the meaning of words is very dependent upon the context in which they arise. For example, one might come across many different definitions of the word "Radiant Matter/Energy" in their studies, much the same way as with the term "Aether". Some of these may be a sort of "catch-all" (much like how Eric pointed out with the word "Energy"), while others are defined as having very particular properties.
                          In regards to the idea of the term "Scalar" being inappropriate for what is essentially a longitudinal wave, I am in agreement that the name is potentially misleading as it usually describes only a magnitude with no direction. However, at the same time, I think some (e.g.: Dewey Larson) use it as a general description for an omnidirectional motion (much like a spherical, longitudinal wave).
                          Anyway, to continue on the works of Crookes, I have found this quote in a section on Caroline Thompson's Phi Wave Aether Theory website that might be of interest:
                          I have been wanting to know more about Crookes for quite some time; I will seek out more of his work, and share it here when I can...This section of the website above has some other interesting bits of "Forgotten History" that many here would probably want to peruse as well.
                          To continue on, here is an article by Mendeleev on the constitution of the Aether:
                          An Attempt Towards A Chemical Conception Of The Ether
                          From what I gather after a quick skim of it, the Aether is postulated to be an element coming before Hydrogen and with inert gas-like properties. I find this particularly fascinating for many reasons, but some include the consideration of other model's I've come across:
                          *Aethro-Kinematics by Steven Rado
                          Chapter Twelve re-establishes Faraday's and Maxwell's initial aether concepts of lines, tubes and fields of forces in the ideal gas model of the Aether and introduces a kinematical understanding of electricity and magnetism without the action at a distance attraction and repulsion between elementary charges.
                          and
                          Chapter Fourteen uncovers the fundamental hidden ambiguity of the classical mechanical wave theory, which ultimately led to the theory of the uniquely transverse nature of electromagnetic waves. This condition of the transverse oscillation was imposed on the undulatory theory of light by the allegedly otherwise unexplainable phenomenon of polarization. In turn, the restoring force required for the transverse oscillation of light made all feasible mechanical model, including the ideal gas model of the Aether, physically impossible. After uncovering the misconceptions of the over-simplified mechanics of the transverse waves on a string that affected all subsequent wave theories, a new kinematical theory of wave-motion is presented. Based purely on the kinetic theory of periodical compression pulses, this hypothesis offers a kinematical solution for all optical phenomena, including double refraction and polarization without the imposed assumption of the uniquely transverse nature of electromagnetic radiation. With this, the seemingly impenetrable theoretical barrier, that has blocked the ideal gas model of the Aether for two centuries, has been removed.
                          *The work of Walter & Lao Russellresonance is the principle at the core of unlocking the potential of many devices (including the human body and the experience we manifest), be sure to exercise a healthy sense of caution. It is unwise to couple to "energies" one cannot handle and/or will act like a leech upon (to ill effect upon oneself and others).
                          Also, I feel that the use of Cymatics to elucidate patterns in regards to the Aether is not necessarily a logical fallacy, but a potentially useful analogy. Sound waves are also longitudinal. Further, I have no hesitancy whatsoever in saying that ALL things are Music.
                          Please forgive the length of my post.
                          May we know all Love and Wisdom.
                          • Thanks PureConst & TRex for the references. v-helpful.
                            Guys it's not the homopolar motor, look for the variable reluctance device... It'll be the one made from dielectric, with a whole heap of meters connected to it! Pay attention to the descriptions of the "load" side of the demonstration, it turns out the load >is< tuned. Repeat it is not the homopolar device, where these calculations are made. (although an interesting device in it'self.)
                            • Originally posted by jarvamundo View Post
                              In the 1987 Santa Barbara video, 45 min's into it shows a PM Faraday AC disk device. Here are some a snap shots:
                              - Diagram showing a metal Disk with N-S-N-S magnets.
                              - The 2 arrows are the typical carbon brush electical connections in a Faraday Disk on the outer edges of the disk.
                              - The 2 Red Dots brush locations on the rotor shaft (9 & 12 positions) shows one of the breakthroughs in this design.
                              - Photos of PM Disk with DC motor on left and pillow block holding the 2 metal disks with PM between.
                              - The brush electrical connections are held by a C-clap for the outer disk edge and the other electrical location is on the rotor shaft.
                              - AC Waveform on Scope:
                              Carbon Brushes with torroidal Current Transformer used on the rotor shaft takeoff position, to measure the 100 amps AC output current:
                              Cheers Mike
                              • I'm actually surprised that nobody takes into account the motion/velocity of the earth relative to the aether when mesmerized by cymatics. I still think it's because nobody really thinks of the aether when considering cymatics - postulating that cymatics is somehow responsible for behavior of the aether (or some other vagueness like that) rather than the aether being responsible for the phenomenon observed in cymatics.
                                If the earth is travelling at ludicrous speed (Spaceballs) through the aether (the earth having it's own magnetic and electric and gravity fields), and you take a metal (notice they don't use wood or plastic) plate and oscillate the fk out of it with soundwaves, maybe all that extra (kinetic) energy added to the plate in tiny high energy oscillations causes it to interact with the aether differently then when at "rest" (ludicrous speed). The plate being manipulated in and out of a type of phase with the relative motion of the aether at high velocity (that velocity is still probably slower then the 'at rest' motion of the earth) receives energy from the aether at different rates causing it to form complex standing waves within it's own structure. Then we can detect those waves with a fluid medium, the plate or tub or whatever transferring some of it's energy to the fluid.
                                Not "sound waves create matter out of nothing" (and related vagueness-es), like in the introductory part of those videos that lamare posted. It's just another version of mystical bla bla bla same as any religious origin of life thesis. It's all the same thesis just different characters.
                                /edit: The idea being that the aether is naturally trying to re-impose upon the plate the 'at rest' momentum of the mass and matter, but the additional soundwaves don't allow it to. This results in complex looking standing waves that we can visually observe - due to the material being used to demonstrate the effect.
