Flat coils and how to build them.
  • Flat coils and how to build them.
    I am planning on building several types of experimental setups within a year.
    If I buy Eric's book about the Cosmic Inductance, would there be detailed descriptions on how to build the coils and replicate the experiment?
    Are there fancy excel spreadsheets to calculate the proportions of the device?
    Do I have to use the expensive silver coaxial cable that is coated in Teflon?
    I want to research as much as I can so I wouldn't waste money and time as I prepare my experiments.
    Thank you.
    Eric Dollard built this controversial experiment that I want to replicate.
    In the world of science if we forget about all the corruption and academic mafia that governs it, a controversial experiment is usually described in detail so it is easier to replicate.
    As I understand, that Eric uses two flat coils that are wound in the same direction for communication through the earth and uses coils wound in the opposite direction for the cosmic inductance.
    So I need to build three coils to repeat both experiments?
    I haven't found much about how to build those coils through google.
    I found how to build wooden frames for them.
    What information have you seen on the subject? If I buy Eric's book, what book should I buy?
    Thank you.
      User "spokane1" I think has posted the dimensions of his replication on the forum somewhere. It should be in the Eric Dollard thread. But it's not necessary to make different types of coils because they all basically do the same thing as far as the end application is concerned, and it's not necessary to make a 100% identical replica because a coil is a coil, within certain limits, and it will still work anyway even if it's not perfectly copied.
      The same two coils are always used, opposite wound. None are wound in the same direction.
        Not to pick on anybody, but it is so sad that so many people discuss the experiment, while so few had actually replicated it.
        This is how "free energy" "community" generates new myths and perpetuates them. Perpetual motion of myths about "free energy" that is.
        I want to 1)replicate Eric's work 2) make a science kit that will be like a plywood dinosaur skeleton.
        I want to cut plywood with lasers, make a fancy frame and adjustable parts to this whole system. I even wrote a paper letter to Eric himself to get more specifics, but got no reply so far. I would pay him royalties if I sell anything.
        But for now it is just a dream to give armchair philosophers cheap toys to play with and witness the magic.
