Eric Dollard Style Tesla Coil Verses Standard Tesla Coil
  • Eric Dollard Style Tesla Coil Verses Standard Tesla Coil
    I'm not an expert, but the answer is probably something along the lines of "these coils don't obey traditional electromagnetic physics, that's the whole point of building them after all, so calculation tools that rely on traditional electromagnetic models naturally won't work!"
      Originally posted by speakerbox View Post
      According to JavaTC and my own experience building coils the coil will work poorly using these plans.
      How do you define working well?
      So my question is: what causes these figures to be so different than they should be?
      Originally posted by T-rex
      There should not be much left unanswered, it is all in the "Theory of Wireless Power" and "Impulses, Waves and Discharges." But all of this pre-supposes a working knowledge of radio frequency lines and antennae.
      Velocity depends on aspect ratio. If Secondary ratio is 18%, velocity is luminal, this only at 18%. So make the coil 20% and the velocity is a bit faster than luminal. The reason, to compensate for the slowing caused by insulation.
      The secondary is coupled to other coils and capacitance. This lowers the velocity greatly. Thus to compensate the coil wire is shortened by 2/pi=0.63662=63.7% to bring the frequency back up to the proper value.
      As for the extra coil; for a coil aspect ratio of 100% the coil effective velocity is 187% that of luminal velocity (along the coil wire). This coil is burdened down by insulation and gradient rings as well as what little coupling Exists. Thus the coil Wire is lengthened to 157% velocity factor. This is to say, rather than calculating the extra coil on a velocity of 187% that of light along the coil wire to figure the quarter wave, we now instead, in order to compensate for the burden, use a velocity of 157% that of light along the coil wire to figure quarter wave. 157% is equal to pi/2.
      Therefore, secondary 2/pi, extra coil pi/2.
      (Longer Extra)/(Shorter Sec.) = (pi/2)/(2/pi)=pi^2/4=2.465
      Where pi is a correction factor, not an intrinsic mathematical relation. But it may be that by using pi some "magic" resonance may take form. (Experiment and see).
      As the primary will oscillate at 1mhz the secondary at 1.4mhz will be 40% detuned.
      Pancake coils will produce fractals so what is the advantage of trying to build the CIG?
      The CIG is a particular configuration and application of the coils, like a pizza is a particular configuration and application of the ingredients. A lone tomato is not a pizza, and likewise a single coil (or two) not connected appropriately is not a CIG.
      Also why must the coils be the same diameter. It makes calculation complicated and seems impractical.
      Eric's design is based on Tesla's Colorado Springs design. The only way I imagine that it could be complicated is because you have other JavaTC nonsense on your mind. Forget that and use basic calculations.
        Dear dr-Green,
        Thank you for taking the time out to answer my questions.
        I define working well as either a very strong E field or sparks equal or double the diametre of the coil.
        The reason why nobody builds Tesla coils with so few turns is they need to be physically large to have a low enough frequency.
        I made a all wood coil form 600mm by 600mm yesterday.
        I will not be able to fit the following guidlines:
        1. 20% of width for height
        2. Conductor diameter
        3. Flat strip secondary 18% width of diametre
        4. Same weight for capacitors and secondary coils
        I will build an Armstron oscillator and see what frequency it performs the best at. Seems as the turns ratio is fixed it will be hard to tune as I can only adjust capacitance in the tank circuit. I will be using Vacuum Capacitors.
        If that fails I will use a spark gap system.
        I will use a 50% aspect ratio and 62% spacing and the frequency will be 1250 kc using a 20 turn secondary.
        Looking forward to seeing the results.
        speakerbox
          Hi speakerbox.
          Good that you are building stuff.
          If you ground your telluric output to the primary coil ground / common ground you will obtain more sparks off the termination. If you are after sparks then it is not the length of the spark it is the quality of the spark! Ideally it would look something like this: Although to produce sparks like in this picture, the CW power would be in-excess of the legal limits! (At least in my country).
          This is one of the reasons why Eric designs for certain ham bands where the frequency is ~2Mhz range and up. (160m, 80m bands).
            Dear Sputins,
            Thank you for your reply.
            I was lead to believe Tesla Coils don't emit much RF.
            As for your concerns about interference I am not worried. I live 30km from the nearest transmitter. I may use a seperate ground so I don't fry my household electronics though.
            I will probably be looking at 2kw up in power. GU 81ms can handle that for short runs.
            I will post when I am successful.
            -Wil
              Dear dr-Green,
              speakerbox
                Dear dR-Green,
                I made a quick spreadsheet to calculate all dimensions of the CIG.
                I copied the extra coil part from the secondary coil calculations as Eric Dollard's "Tentative" calculations didn't make sense.
                All Yellow areas are user input. And it will convert between m, to cm to mm in separate columns. Coil frequency, primary turns, tank cap, secondary and extra coil ratio and spacing ratio are adjustable.
                We don't use inches in Australia so maybe you can add inches and feet etc.
                I added a very rough spiral coil inductance calculator and LC calculator to get a gestimation of the primary cap needed. Saves pounding away on the calculator all day.
                Plus you get to see what frequency is easiest to build to.
                Could you or someone with more experience than me check my calculations?
                If it proves useful maybe we could sticky it somewhere.
                Here it is: https://www.dropbox.com/s/i1kl6apy4e...ator.xlsx?dl=0
                -speakerbox
                  Dear All,
                  Here is my spreadsheet calculator's output for a 30 turn secondary CIG.
                  The figures match Eric Dollard's ones for a 1000 kc coil.
                  See: https://www.dropbox.com/s/0qyrf2co4y...lator.png?dl=0
                  -speakerbox
                    Dear All,
                    -speakerbox
                      Dear Sputins,
                      I live in Broome, WA.
                      As for the extra coil. I am attracted to this idea of a low turns Tesla Coil because it will allow me to use an extra coil. That's how Tesla got 112 feet long discharges. He got 50kv and increased it to 412kv or so with a Tesla Coil then the extra coil multiplied it by a factor of 30 or so.
                      With a coil of small diameter and great turns it is impractical.
                      I fired up my coil two days ago with a multigap spark gap. Very poor results as I don't have the capacitors needed to attain resonance. it was a 2 to 20 turn system. Got one inch discharges to ground.
                      I am rebuilding it to be 125khz now to utilise the caps I have. It will have 20 to 200 ratio with 0.25mm magnet wire.
                      This will not allow me to use an extra coil though. I need a few hundred metres of coax and a coil form of atleast 1m diameter.
                      Anyhow I will build this one and tune it and then build a larger coil form. I got the feedback system to work using a Armstrong oscillator so it's doable as a VTTC.
                      I mainly want to test whether Eric's calculation work and if it will tune at the frequency he calculates. But with a low frequency coil his calculations come closer to JavaTC (81khz verses 125khz).
                      I don't understand the criticism of solenoid coils. I have got 50cm discharges CW out of a secondary with a 19.5cm wound length.
                      Oh well I will put his system to the test.
                      -speakerbox
                        Size and frequency is not relevant (to that).
                        e = iZ
                        Or
                        V = IR
                        Z = square root of L/C
                        So once again, size and frequency is not relevant.
                        Eric's design is not an exact replica of Tesla's coil, it's slightly modified. If you want to scale that then you will have to refer to CS Notes or use Eric's analysis in the link above. LC ratios will scale, because it's a ratio. Keep it constant. 1:2 = 5:10
                          Dear Sputins,
                          -speakerbox
                          • #14
                            Dear Sputins,
                            Yes it is a beautiful spot!
                            I finished the coil last night at tuned it to 128khz and 80khz.
                            The JavaTC and Dollard calculated frequencies.
                            The output was very poor and I don't see much point in further building or experimenting.
                            From experience I see two problems:
                            1. magnetic flux density is too low and coupling too loose due to the size of the primary.
                            2. primary and secondary coupling is too low due to coil arrangements
                            3. design requirements are nonsensical and stringent
                            I am not a engineer, these are my personal opinions I give as explanation why I am discontinuing my efforts.
                            I will go back to tube coils and try a bipolar arrangement or two coils 180 degrees out of phase.
                            Anyhow I gave it a go and it's time to move on.
                            I didn't witness any strange phenomenon and cranked the power past 2kw. The rf was higher than a normal TC but the dielectric field was weak.
                            I have produced very powerful dielectric fields and fractal like gas discharges with a tube coil as seen here: crazy rf from tesla coil - YouTube
                            Good luck to all.
                            -Wil
                            • #15
                              Spreadsheet Version #1
                              I hope this set of Erics parameters show the clear minded design that Eric has given us. These sizes are whats been stated in all the pages presented so far.
                              I adapted this spreadsheet from my large coil project I did in 2012, the spreadsheet design worked great. I never needed to use any Tesla Coil program as I was not looking for a sparking coil based on RF, but a transmission coil based on non radiative principals(Tesla Longitudinal Wave). The unit I built worked as designed, I detuned the top load just enough to get 3ft streamers from a 1 kw power source, it also gave very nice glow with no discharges as I tuned it to finally give no sparks and only a slight glow indicating high efficiency. The reason to detune the top load was to see how much charge was being stored, thus a breakout would indicate this, where proper tuning would eliminate any such sparks, which is the CORRECT way of understanding the TMT Coil. The coil I made was not based on Eric design sizes but as you can see I used Erics directives to get the correct ratios and parameters. I will release the spreadsheet as soon as I finalize version #4. I hope this helps, regards Arto.
