Eric Dollard
This is a sticky topic.
Remember to think of the output between the two coils of the CIG as having both a magnetic and dielectric component.
Induction heaters may be of the magnetic type, or the dielectric type. The induction heater you are thinking of is the magnetic type. It operates by having an extremely strong alternating magnetic field inside a coil. Then, a material which has a high permeability (can contain/hold a lot of magnetism) is inserted into this rapidly changing magnetic field. The strong magnetic field repeatedly polarizes the molecules in the sample to be heated, then switches and polarizes it the other way. This rapid movement inside the sample heats the material. The lesson to take from this is only materials that have a high permeability will be able to be heated this way. Now think of what Eric says about conductors- that they are very good at REFLECTING magnetism, not containing it. Thus things like copper, silver, or gold are good at reflecting magnetism and probably wouldn't be heated as well in this way (but it can still be done). Things containing Iron are heated the best this way. Another way of heating through the changing magnetic field is by actually inducing internal currents in the sample material. Then, resistivity losses (i squared r) heat the material. This is why transformer laminations are thin - to reduce the available material to generate currents in (called eddy currents). With the gold particles being small, only very small eddy currents could be created.
A dielectric heater that I'm sure you are familiar with is the microwave. You put food in, and it is magically cooked. The way it heats is through dielectric induction - rapidly changing the dielectric field inside a material. Thus materials that have a high permittivity (can hold a lot of dielectricity) will best be heated in this manner. Not surprisingly, water, which is mostly what is heated in the microwave, has a very high relative permittivity. The microwave doesn't just have dielectric fields inside it though, it also has magnetic fields- which is why you don't put metal objects in a microwave!
Getting back to your example, if something is to be heated in rapidly changing dielectric fields it is the insulator, not the conductor. Either way, in this case the gold probably wouldn't be heated.
Through very preliminary testing, the CIG seems to produce a much stronger dielectric component than magnetic component. (Which is the goal- to create a plasma via strong dielectric fields between the coils)Last edited by jpolakow; 04-02-2014, 12:46 PM.Please help support my indiegogo campaign: Cosmic Induction Generator
I remember you mentioned those Egyptians before. In your videos the travelling patterns also seem to depend on what your hands are doing, have you tried it with the tube on a stick or something so it's away from your hands? I still haven't tried it yet but I think dangling it from a piece of string on each end would be the best way to support it because then each side would also be equal and with minimal contact to other objects. Even the duct tape I use to bind the 8W tube to the end of a stick affects how the tube lights, the tape seems to ground it a bit and cause it to light more than if the tape was not there, so I think dangling from string would be the most neutral method in terms of affecting what it does.Originally posted by Farmhand View PostWhat makes me think twice about the travelling dark spots in the fluro is that
they resemble the cables with bands/spots in the Dendera carvings in Egypt.
See attachment, in the actual carving the dark spots are still there but are more
difficult to see.
Considering I got those effects with 12 volt powered coils and less than 10 Watts.
That video with the sine type patterns in the tube was interesting, looks like a lightning storm in clouds in some parts.http://www.teslascientific.com/
Roadside Internet Transmission
1) The Polokowski dark spot in the florescent lamp is unique. It is not the conventional Crookes dark spot nor is it traveling striations. It represents a neutral plane or counterspace between the two coil fields.
2) The blue glow on the glass of power tubes is caused by electron bombardment by the electrons escaping the inter-electrode cavity. it its normal behavior.
3) if there is interest in photos of bush-life and things encountered I will provide more.
4) Tetnus is a physics shill, he is an interesting study to experiment with what really sets him off.
73 DE N6KPHSUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
Originally posted by jpolakow View PostRemember to think of the output between the two coils of the CIG as having both a magnetic and dielectric component.
Through very preliminary testing, the CIG seems to produce a much stronger dielectric component than magnetic component. (Which is the goal- to create a plasma via strong dielectric fields between the coils)Originally posted by T-rex View Post
73 DE N6KPH"Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
Tesla Cosmic Induction Generator Experiment #1
Hello Everyone ,
Here AstroNod , I have now 2 Tesla coils hooked them up in serries with the prim. coils .
The video is here Tesla Cosmic Induction Generator Experiment #1 - YouTube
Ok nice Coils from jpolakow and clear photo` s thanks .
Now we all look for those wonderfull effects plasma sphere`s `light` bulbs.
I buy one plasma sphere and try to see it if will give the special effects .
Highlikely smaller space between the coils and more RF power will be needed .
I will do also more experiments with high voltage DC static field between the coils 100 a 500 kVolts .
Plasma arc lights / and field experiments with grounding .
Study Tariel Kapanadze devices and upgrades .
I`ll make a new video where i show the power transfer from one coil to the other . i already did those experiments .
This month i be building the other TMT sec and prim i have one of already . and make more of those basic see if i can stack those coils in serries , and i work on the extra coil for in the TMT system .
Stay tuned
PD7Z worldwide and far beond .Last edited by AstroNod; 04-08-2014, 06:37 PM.
Interesting video, AstroNod. From my perspective it seems that the two coils are completely in phase, that is, they always have the same charge at any given time.
See, if the electrostatic field is lighting the flourescent bulbs, then it makes sense that there is a dark spot between the coils. The electrostatic lines of force repel each other, and so between the coils the field should be the weakest, if the coils are in phase.
However, if you tune the two coils correctly such that they are 90 degrees out of phase, then the dark spot shouldn't be there any more... Of if you slightly de-tune the coils then you should get blinking.
SO than this interpretation from Polokowski is right.Originally posted by T-rex View Post1) The Polokowski dark spot in the florescent lamp is unique. It is not the conventional Crookes dark spot nor is it traveling striations. It represents a neutral plane or counterspace between the two coil fields.
73 DE N6KPH
1. The interference pattern is actively sucking energy away from the tube in this area to prevent a plasma from forming.
I can not see another explanation too. This is weird! Energy is sucked into counterspace?
Tesla Cosmic Induction Generator Experiment #2
Hello All / Natusake ,
Thanks for the reply , yes indeed the phase seems to be ok .
Today i am Happy to show the new Sett Up Horizontal with the top end to each other .
The Basic video i made is here :Tesla Cosmic Induction Generator Experiment #2 - YouTube
There is Less E.M. field and less radio interference on the radio bands .
The Black Spots are strong . the field of counterspace looks flat between the coils .
Did bought one plasma sphere wait for the post to bring it here .
Seems the Tune cap is always at minium capacitance to get good tune .
more experimenting need to be done with connections and tune capacitor hook up to the coil .
The Power Transfer from one coil to the other is good i got about the same in and out from the other coil and a bit more with just basic experiments .
If You want to like me to try some experiment or specialy not
drop me a line .
All the best De PD7Z
Nice work Astronod.
I'd like to see more bush-life too!Originally posted by T-rex View Post3) if there is interest in photos of bush-life and things encountered I will provide more.http://www.teslascientific.com/
Tesla Cosmic Induction Generator Experiment #3
Hello All,
Thanks for the reply dr.green. Sure T-Rex The Last Sett of Photo`s where awesome , bit mystical Toyota and Wild Life hihi.
In test #3 in dipole mode there are no black spots to be found .
Tesla Cosmic Induction Generator Experiment #3 - YouTube
-->Sputins , yes i would like to see somehing happen between the 2 dielectric fields in the right phase mode .
I will make one HV supply 50 a 500KV to break down the dielectrics in the air and materials . and one or 2 tesla beam tubes .
T Rex mention Crookes Spots , nice to read something about them sure Tesla picked it up to make his own tubes like tesla beam tube and the cold cath. x ray tubes .
Crookes tube - Wikipedia, the free encyclopedia
Drop me a line if your materials melt of take off...
PD7Z
Tesla Cosmic Induction Generator Experiment #4
Hi All,
Made a nother Video . Tesla Cosmic Induction Generator Experiment #4 - YouTube
now i have even better phase and clear dark spots on both coils sides .
yesterday it showed a little more to one side than the other .
Feels a bit strange when hold the CFL between the center of the 2 coils like if there is energy slipping away energetic wise .
Made the wire s better and the strip straight , i got almost no relection back to the transceiver thats very good .
Seems to radiate a bit EMF when i hear my self back on the web sdr receivers .
Looking good tom. i have the plasma sphere high likely so than i make a nother video !
Greetings from a mild spring like Netherlands west coast .
Tesla Cosmic Induction Generator Experiment #5
HI All,
Here Astronod , Well i made a new Video with the Plasma Sphere and hook the coils up in Horse Shoe .
Tesla Cosmic Induction Generator Experiment #5 - YouTube
There is a Blue/Pink/PurpleWhite Big Flame in the Sphere .
It looks like A Deep Sea Worm :This Deep Sea Alien Worm, Tomopteris, Is Utterly Captivating : The Featured Creature
I did Modulate the coils With AM modulation and CW .
The Ringing of the glas the the plasma flame make the the sound high likely , the sphere is vacuum with some gas mix argon/neon .
When induse the highvoltage from the plasma sphere toy it interfere the flame but the HV line have huge rf power it burned straight trough my tumb nail from the HV wire 0.2 copper transformer wire .
The Flame looks lovely on one coil it is huge and when spin the sphere it move nice and slow , as well when spin fast and stop it will spin a little due its momentum .
Here is a Great man who make lovely Plasma Tubes :
PD7Z
