The book Survival of Civilization was written about 25 years ago. It is an alarming book with warnings of the end of the world.
GET THE SURVIVAL OF CIVILIZATION - pdf file 1.71MB
The time line of a global catastrophe is off but this is the clearest and most to the point book I have ever read that shows a very clear picture of what causes the global warming AND cooling cycles and their relationship to glaciers and minerals in the soil.
I would recommend this book to everyone and this PDF version is a special version with comments by Donald Weaver.
Please look past the time line that Hamaker predicts and look at the concepts and the science behind it and make your own decision.
This book is appropriate for quite a few different categories, but I put it here first because of the main theme and that is that the soil needs to be re-mineralized.
The concept is this: Minerals are necessary for organisms in the soil. Plants obviously need this as part of their nutrients. The minerals in soil from the last ice age is dying down...not just in farm lands but from run off on land mass around the world and the soil is no depleting everywhere. If mineralized, there is a lot of luscious plant life. They absorb CO2 out of the atmosphere and keep the climate regulated. With demineralization, not as much plants and increase in CO2 in atmosphere. That traps heat and there is more moisture leaving the ground going to the air and the warm air displaces cold air that moves towards the polar areas making more cloud cover. That reflects lots of heat from the sun making those regions even colder and causing more freezing and thicker ice caps (ice age). That ice grinds the rocks below it releasing those minerals mixed with water back over the lands to mineralize the lands. That will help plants grow in the warmer areas pulling more CO2 from atmosphere slowing down this cycle and the ice age starts to go away. The process of this glacier cycle and the mineralization from them is called glaciation. Basically, if we don't start global scale remineralization of the soil, we are inevitably triggering an ice age and the "global warming" trend is only a symptom of that, which precedes the ice age events.
This book hints to several resources including a book, which you will learn of that is probably one of the biggest mistakes in the history of mankind convincing farmers that NPK type fertilizers is the way to go. Justus Von Liebig in 1840 wrote Organic Chemistry in its Application to Agriculture and Physiology. Later he repents on his big mistake causing chemical companies to take over and push NPK fertilizers that wind up killing the soil, growing poor quality food and causing a degeneration of health in mass humanity.
Von Liebig even said later:
"I had sinned against the wisdom of the Creator, and received my righteous punishment. I wished to improve his work, and in my blindness believed that, in the marvelous chain of laws binding life on earth’s surface and keeping it always new, a link had been forgotten which I, weak and powerless worm, must supply."
—Justus von Liebig, late in life quoted from Encyclopedia Britannica , 1899;
removed from subsequent editions.
The landmark book Bread from Stones - A New and Rational System of Land Fertilization and Physical Regeneration (1894) by Julius Hensel, is the book that brought sanity to the issue of soil fertilization / mineralization showing that rock dust of rocks with a full spectrum mineral blend is the most effective method of remineralizing the soil.
GET BREAD FROM STONES - pdf 3.90MB
Donald Weaver wrote To Love and Regenerate the Earth and is a thick read, which I have not devoured yet. It is a companion to The Survival of Civilization.
GET TO LOVE AND REGENERATE THE EARTH - pdf 2.93MB
John Hamaker developed and patented a device (patent expired), which allows the most effective and efficient method for crushing rock to the necessary size. US Patent # 3,552,660
GET METHOD AND APPARATUS FOR THE AUTOGENOUS CRUSHING OF STONE AND THE LIKE - pdf 342kb
If you resonate with the concepts shared within this post, please pass this on to anyone you feel would appreciate learning about it.
