You are perfectly FINE, Codebondfuture!
Hello to All,
Thanks Codeboundfuture!, your explanation is great, plus your links also...and quotes from Tesla.
It happens very similar to your Baloon example...I will try to explain it the way I see it...with the Balloon...can I borrow it?...
Ok, we inflate our balloon, which is our magnetic field projection into the Aether Space. by doing this we are invoking, provoking the aether space, exciting it, stimulating it, aligning it in an atomic magnetic way.
As our pulse drops down to zero magnetic value at zero time...our balloon compresses to an exactly "Zero Space"...leaving in its previous volume-spectrum limits a very strong "Magnetic Vacuum" ...Then, the already aligned magnetically Aether space is practically "Dumped" into that balloon "used to be" space...and that occurs exactly in the center of our coils and the surrounding space to it.
Now, according to the simple magnetism laws that we all know...a North pole will attract a South...and viceversa...
...So the Aether around Our Balloon Space had originally an opposed magnetic structured configuration...Right?
So, when it takes our "Empty Magnetic Space" at Time Off...it is Opposed to our original "used to be" magnetic polarity config...therefore, it creates an opposed current flow to ours...
This process repeats itself "religiously" at every nanosecond of our On-Off Pulses...creating a flow of both currents.
Thanks a lot for the Balloon...Codeboundfuture!!
You could have it back I played enough!..
Regards to all
Hello to All,
...So the Aether around Our Balloon Space had originally an opposed magnetic structured configuration...Right?So, when it takes our "Empty Magnetic Space" at Time Off...it is Opposed to our original "used to be" magnetic polarity config...therefore, it creates an opposed current flow to ours...
Regards to all
I have a digital watt meter that tells consumption very accurately, but lead acid batteries are expensive (and I won't use lipos like you do even though I have lots of them I couldn't explain burning down our property to my wife) so maybe in a couple of months I might be able to buy 3 lead acid batteries. I try to use what I have if I can... you know poor people have poor ways. I could build a cement block bunker for them of course that would take up a lot of room on my bench. I'll look into making a smaller one out of fire bricks.
