Volt-ampere reactive - Wikipedia, the free encyclopediaAC power - Wikipedia, the free encyclopedia you can calculate the complex power S which is consumed by the primary, using the Phitagoras formula for the right triangle where P and Q are already known when the phase angle is known that is.)
Question is whether we can neglect the reactive power input to the transformer primary or not? I do not think we can because the var power must also be supplied by our power source, in your case by the signal generator or the amplifier, in other cases by the AC mains.
I am puzzled by your third test: did you mean the secondary current was 0.835 mA ie you used an AC ampermeter for doing the actual short? You may wish to repeat this test because it would be good info how this transformer behaves at higher input AC voltages like a few volts or even at some 10 volts if possible.
I cannot answer whether you go on building another transformer (a prototype as you say), this must be decided by you, sorry. What I wrote above as an evaluation of your data comes from conventional science knowledge, and it is possible that in many countries the electric meter does not register var power...
Greetings, Gyula
Greetings, Gyula
