Biodiesel is alternative fuel which use alternative to the ordinary petroleum based fuel. It contains no petroleum but it can be blended with petroleum at any level in order to produce a biodiesel blend. It can be successfully used for diesel engine with little or no modifications. Comparing to the ordinary petroleum based fuel it is simple to use, biodegradable, nontoxic, and essentially free of sulfur and aromatics. So using Biodiesel is more environmental friendly rather than using petroleum based fuel. Not only the environmental friendly but also it is a solution to petroleum fuels because these fuels are not longer exist in the future. So if we can develop the biodiesel as alternative to the petroleum based fuel, it will be a great finding for the next generation.
Some rating system according to the blend with the Petroliam based fuel.
* 100% biodiesel is referred to as B100
* 20% biodiesel, 80% petrodiesel is labeled B20
* 5% biodiesel, 95% petro diesel is labeled B5
* 2% biodiesel, 98% petro diesel is labeled B2
If we use blends less than B20, the engine modification is not required. But for the B100 little engine modification may require.
REED MORE
REED MORE
