Yes.
Hello,
Not the papers but the experiments inspired from Walter Russell's work
The DVD is in the "Energy from the Vacuum" series, #18. When covering transmutation he holds up Walter Russell's book, "The Universal One" and said all the information is in there if we want it. I don't want to be spoon fed but has taken years to build up the nerve to read his work. Therefore, a replicatable experiment is where my mindset is focused on.
Bedini does show the Silver+Ruby slag from the process and the gold transmuted from the copper substraights.
I was inspired to try a test with Hydrochloric acid as described in the EFTV#18 DVD, but I failed to obtain much growth on the steel/also an iron rod in the months was sitting there
(used 5 different mineral samples and was suprised NONE showed any promise)
As annoyed as I was by this at the time, now is an opportunity to work out where I went wrong/or how to do it correctly and share it with others to achieve the same results as I will upload.
You are attacking this technology from an angle that is needs clarity for me to 100% grasp the fundermental concepts, time will tell and has been true to form of late
Zero
(used 5 different mineral samples and was suprised NONE showed any promise)As annoyed as I was by this at the time, now is an opportunity to work out where I went wrong/or how to do it correctly and share it with others to achieve the same results as I will upload.
Zero
artoj .... and thank you for the amazing reproduction of WR Table of elements
