Visual Phenomena Observed in Tesla, TARIEL KAPANADZE etc.. Research
  • #76
    Chalk and cheese
    Originally posted by Kokomoj0 View Post
    ok kool but I have no idea what point you are trying you are trying to make
    The difference between your picture and this https://lh6.googleusercontent.com/-t...2520floyyd.png for instance is so blatent it requires no further comment .. you picture is a hertzian phenomina note the sharp horizontal scatter in this shot.
    • #77
      linear wave no such thing?????
      Originally posted by dole View Post
      Hallo,
      I may report successfully captured propagation of natural plasma phenomenon, produced by a capacitor pulse discharged trough the coil and one ordinary light bulb.
      Interesting is that observation may prove existence of external energy source and possible conversion to usable energy.
      I will try shortly to describe observation.
      1.png: Shows bulb connected to the capacitor, closing loop with a coil in series, generating high vibrating electromagnetic field in the blub filament wire.
      We may observe energy attraction (extraction) from environment to the oscillator (bulb) as a propagation of the blue ray towards oscillator.
      We already have current flow in the filament, but not light effect, since it is not produced by conventional circuit current as may be believed.
      2.png: 3.png: Shows full conversion as visible brightness in the bulb filament closed in the vacuum. We still see blue ray (energy) flow towards oscillator.
      4.png: Capacitor discharged current is disconnected and we may see decreasing oscillation of the filament manifested as glow and heat as side effect. There is no observation of blue ray.
      5.png: Same as 4, further in time frame.
      There is much more to say regarding presented observation relatad to Tesla rays and there propagation as historically described in some old drawing and statements, but for now I appreciate any comments.
      If someone decides to verify observation, pictures are clipped out from my last YouTube video.
      d.
      Good solid resarch with an object a method ( some actual doing something) a result and a conclusion right or wrong thank you very much dole
      • #78
        Sorry but I do not see any difference?
        maybe there is something in all those pics that I fail to see? I dunno?
        • #79
          Neither do we....that is why we are exploring this side of the OU research...just keep your mind open...and a keen sense of observation
          I am not saying you are wrong about it, I'm saying there is something to it; don't be so quick in dismissing it.
          In 1889 Tesla began experimenting with capacitors charged to high voltages and discharged in very short time intervals. These very short pulses produced very sharp shockwaves which he felt across the front of his whole body. He was aware that closing a switch on a high-voltage dynamo often produced a stinging shock. This was believed to be static electricity and it occurred only at switch-on and only for a few milliseconds. However, in those few milliseconds, bluish needles of energy stand out from the electrical cables and they leak to ground, often through the bodies of any people standing nearby, causing immediate death if the installation is large. While the generators of that time were rated at some thousands of volts, these discharges were millions of volts in intensity. The generator problem was eliminated by the used of highly insulated switches which were provided with a very large ground connection.
          Tesla was intrigued by this phenomenon which appeared to match the effect of his capacitor discharges. He calculated that the voltages produced were hundreds of times greater than could be supplied by the capacitor or generator. It was clear that the power supplied was being amplified or augmented in some way, but the question was, from where was the extra energy coming?
          If he was not intrigued by this phenomena, we would not be here having this discussion
          Signs and symbols -Confucius.
          • #80
            The phenomena described there has nothing to do with light beams coming off light bulbs, it's about switching transients.
            How exactly do you draw a connection between the smear from a camera capture of a light and a switching transient ?
            Did you notice in my video the smear rotates with the camera ?
            I know Duncan will probably say I am asleep and the light beams in my video
            are somehow different from the others and whatnot, but I don't care, his
            condescending rhetoric does not affect me.
            Switching transients are well enough explained already I think.
            • #81
              I'm not sure that quote is quite right
              Gerry Vassilatos - Secrets of Cold War Technology.pdf
              • #82
                Thank you guys, the point i was trying to make is not to be too quick in dismissing visual cues as not being indicator of some occurring phenomena
                • #83
                  It was the word "intrigued" that interested me in the text not the phenomena described.. misunderstanding happen
                  • #84
                    well by that I meant that maybe I was missing something that you all see, but apparently that was not the case.
                    the phenomena that tesla describes I have personally felt and describe some of it here
                    • #85
                      http://www.energeticforum.com/renewa...ead.php?t=9887
                      I suggest reading the image I posted above. These are all different effects in different situations. The effect Tesla describes is due to a large capacitor discharge, not switching a DC dynamo or shorting a transformer. The quote MonsieurM posted is NOT how it was originally written, it says completely different things if you read it carefully.
                      Of this surprising physical effect, Tesla was exceedingly intrigued...
                      The explosive effects reminded him of similar occurrences observed with high voltage DC generators...
                      This hazardous condition occurred only with the sudden application of high voltage DC.
                      • #86
                        it doesnt have to be "exactly" like that however to get those effects
                        • #87
                          It wouldn't be surprising and similar if it was the same effect
                          • #88
                            Hallo,
                            d.
                            Thanks Dole. Could you do another vid of that and barrel roll the camera.
                            while filming please. Ive mentioned it twice I guess they don't know what a barrel roll is. TIA, John
                            http://www.energeticforum.com/renewa...tml#post168640
                            • #89
                              Hi TEKTRON, I rolled the camera in this video Violet Smear.wmv - YouTube
                              And the purple line went with the camera.
                              The line shows up with DC and AC but lower frequency AC shows the Zig Zag
                              effect more clearly than HF AC I think. The lines are mostly not visible with
                              the naked eye. But they show up on camera.
                              • #90
