Ognyanov Free Energy Device - Similar to Kapagen
  • Ognyanov Free Energy Device - Similar to Kapagen
    Hi all,
    While browsing Free Energy Research Archive I found an interesting patent by Ognyanov. I downloaded the patent, along with a German version and uploaded these here:
    Directory contents of /pdf/Patents/Ognyanov/
    More here:
    Micahel Ognyanov -- Electric Power Pack --- US Patent # 3766094
    Excerpted from Patrick J. Kelly : The Practical Guide to free Energy Devices ---
    A patent application US 3,766,094 (shown in detail in an accompanying document) gives the details of an interesting device. While it is only an application and not a full patent, the information implies strongly that Michael built and tested many of these devices.
    While the power output is low, the design is of considerable interest. It is possible that the device works from picking up the output from many radio stations, although it does not have anything which is intended to be an aerial. It would be interesting to test the device, first, with a telescopic aerial added to it, and second, placed in an earthed metal box.
    The device is constructed by casting a small block of a mixture of semiconductor materials such as Selenium with, from 4.85% to 5.5% Tellurium, from 3.95% to 4.2% Germanium, from 2.85% to 3.2% Neodymium, and from 2.0% to 2.5% Gallium. The resulting block is shaped with a dome on one face which is contacted by a short, pointed metal probe. When this arrangement is fed briefly with an oscillating signal, typically in the frequency range of 5.8 to 18 Mhz, it becomes self-powered and can supply electric current to external equipment. The construction is as shown here :
    Presumably the output power would be increased by using full-wave rectification of the oscillations rather than the half-wave rectification shown. Michael says that increasing the dimensions of the unit increases the output power. The small unit shown in this example of his, has been shown to be able to provide flashing power for an incandescent lamp of up to 250 mA current requirement. While this is not a large power output, it is interesting that the output is obtained without any apparent input. Michael speculates that the very short connecting wires may act as radio reception aerials. If that is the case, then the output is impressive for such tiny aerials.
    It appears to me that the metal probe together with the semiconductor basically forms a Schottky diode:
    Schottky diode - Wikipedia, the free encyclopedia
    The Schottky diode (named after German physicist Walter H. Schottky; also known as hot carrier diode) is a semiconductor diode with a low forward voltage drop and a very fast switching action. The cat's-whisker detectors used in the early days of wireless can be considered primitive Schottky diodes.
    Construction
    A metal-semiconductor junction is formed between a metal and a semiconductorvery fast switching and low forward voltage drop.
    Cat's-whisker detector - Wikipedia, the free encyclopedia
    wire that lightly touches a crystal of semiconducting mineral to make a crude point-contact rectifier.
    Note that the construction has certain similarities with Kapanadze's design around T1:
    More on Kapanadze here:
    Directory contents of /pdf/Reference_Material/Kapanadze/
    KAPAGEN, the Tariel Kapanadze's generator
    The Worldwide KAPAGEN successful replications
