The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Originally posted by MonsieurM View PostDave, if you intend on using it, please wear the safety helmet
I think that kind of helmet might increase the danger of a strike from
a Tesla Transformer. However if it was grounded by a wire it could be an
exciting and useful piece of head wear for inspecting a running coil for small arcs
(leaks). My suggestion is ground the helmet with a wire and insulate it from
the cranium, otherwise it would be an antenna wouldn't it. Haha And there
should be a nose piece, noses are break out points.
I wonder if I can tune my coils better if I wear my tinfoil helmet while I do it.
Worth a try.
as usual, while re-reading new "planes" of understanding unveil themselves
check out Russel's Table MALE and FEMALEBut saith Hermes, It is not so; the masculine truly is the Heaven of the feminine, and the feminine is the earth of the masculine.
The Son then asks, Father, which of these is more worthy than the other; whether is it the heaven or the earth? Hermes replies, Both need the help one of the other; for the precepts demand a medium.
Signs and symbols -Confucius.
I had to repost this, Because it carries some deep wisdom..thank you SliderOriginally posted by Slider2732 View PostI have no idea
But, am definitely reading along too...your posts carry a very strong yet subtle study of nature information, that triggers a sort of hidden knowing that appears unfathomable. I hope to fathom it out too
The only addition from here, is that of using magnetism and electrical energies in place of traditionally held 'substances' for the philosophers stone alchemy. Harmonics, resonance, mixing them and on to defining them when results are found.
Not a substance, but a method...the substance of the method being what I presume you wish to find ?
Scientists probe Earth's core, make mystifying discovery • The Register
Scientists carrying out extreme boffinry into the makeup of the Earth's liquid core have announced that they are very puzzled to find it is not made of what they had thought it was.Quartz: SiO2Thus it turns out that actually silicon may be even more important than we at the Reg have always thought. The new discoveries have important implications for our understanding of how the Earth formed, and thus in turn how other planets - perhaps ones orbiting other stars - might form.
just found an interesting post:
Tesla - What happened the day after he died...and who took his secrets..., page 1
a nice readFeb 9, 1981 Lt. Col. McLaren USAF Strategic and Space Systemscertain ongoing research within the DoD
I posted this a long while backImportant: It should be noted that this thread is a reposatory of observations talked about or observed or captured on camera....
As Duncan mentioned, there maybe nothing to it but if others made similar observations with a variety of visual effect and cared to share with us this information...It could prove to be of valuable use to you and you reaching your desired goal...No Avenue should remain unexplored...this is Fringe science
Randall Cole Roffe: Harmonic Resonance, there is something to what he says (not necessarily agree with it all ) that resonates with the tractate...for some reasons i keep going back to his article. But i have to add as you said it is important to "finding a way where there seems to be no way", in other words look beyond what you have been taught, and keep your mind open, because the answer maybe found in places that you would consider unreliable as a whole.
If we take a good look -- and listen -- at the whole of manifestation, and apply the principles of acoustics and music, and of the color wheel, the grand pattern that emerges is self-evident.More
than this, a possible explanation of a medium of transmission of a universal electrogravitational influence, as a plenum far more fundamental than an ether, becomes apparent. With this realization a
whole new understanding of physics also emerges, with awesome possibilities.
Randall Cole Roffe
Found this video....but no description...I did metion it in a previous post in another thread....
IMGP5275 - YouTube
also I know some people talked about associating a spark plug and a magnet :
Neodymium Magnet High Voltage Rotating Spark, arc, plasma - YouTube
Please note from the title:
you can link it to a video Dave found :
MAGNETIC VORTEX SPIN DISCOVERY, Sept. 2011, TORNADO UNDERWAT.mp4 - YouTube
a little surprise: related to what i just posted
plasma forcefield! - YouTube
Plasma Forcefield melting metal - YouTube
Alright here goes two more pics.....
Tesla 50,000 Volts Violet Ray Generator - YouTube
Tesla Coil 50000 Volt Electricity - YouTube
from High Frequency Currents: Oudin, Tesla>, d'Arsonval, Piffard, Violet Rays, Auto-Conduction, Auto-Condensation. Dr. Sinclair Tousey
When the vacuum electrode is placed in contact with the patient it will light up with a violet color the same as it would if attached to a high-frequency apparatus, but the sensation produced in the patient is entirely different, being of a vibratory character; it is, in fact, when used in this way in conjunction with a static machine simply a method of applying the wave-current by means of vacuum electrodes. This current has a certain therapeutic value, but should not be called a high-frequency current. It will be referred to as vibratory current (Figs. 329 and 330).
One very simple test to demonstrate physically the difference between this current and either form of high-frequency current is to have the subject come in contact with the metal part which holds the vacuum electrode. When this is connected with the static machine as above described, you will experience a very disagreeable shock, whereas, when it is connected with a high-frequency current no sensation other than that of having a slight feeling of warmth will be experienced. Vacuum electrodes are used in this same way with an induction-coil, the strength of current being regulated by the distance A and B are separated.Last edited by MonsieurM; 11-25-2011, 11:38 AM.Signs and symbols -Confucius.
check this video out...I'll post a pic:
Electricity from the air Crystal Radio - YouTube
I attached an LED light to my crystal radio and it worked surprisingly well..
I found the Schematic for this Crystal Radio on Jim McNutt's web site. It was called the Pixie 2 His web site is WA6OTP
a while back i posted this : http://www.energeticforum.com/renewa...tml#post165502Originally posted by MonsieurM View Post
Now what if you replace the crystal with one of your own mixture such as the one I proposed in previous postsYou could also grow the quartz crystal using the same apparatus above but instead of pulsed electricity just use the sun audio file , as it is already pulsating, if you have not listened to it here is the link :
I forgot to give you the link to solar sound...i downloaded the 22 mb file
try to listen to it then stop it....you'll feel the difference
Sounds of solar oscillations
put it in repeat and play until the quartz grows ....remember flowers are affected by music...and what better music than the sun's
note: when i play the solar sound and let the the vibe course through me and then i stop it ......i feel a sort of if you allow me to call it as such "bemf"....try it and you'll see what i mean
fractal constructs has an 'efficient function', they have a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
This important point, where the elements and the principles of the highest knowledge are
concentrated, could not be search nor encountered in life, as life is within is, as it radiates
around us, as it is familiar to us and as it suffices to know how to observe it in order to
grasp its different manifestations. It is in death that we can recognize it, in this invisible
domain of pure spirituality, where the soul, liberated from its bonds, takes refuge at the
end of its earthy stay; it is in nothingness, this mysterious nothing which contains
everything, the absence where all presence reigns, that it is proper to search for the
causes, the multiple effects which life is showing us.
Chemists develop liquid-based hydrogen storage material
University of Oregon chemists have developed a boron-nitrogen-based liquid-phase storage material for hydrogen that works safely at room temperature and is both air- and moisture-stable -- an accomplishment that offers a possible route through current storage and transportation obstacles.
