The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • Originally posted by shawnnweed View Post
    I see what you mean. Will definately require testing but i think you are right when you say pulsed DC and AC are a perfect match. As a matter of fact I think that pulsed DC is a physical representation of the ether channel. This could most likely be the greatest discovery for the roddin coil. You know how they say keep a spacing available on the torroid for the ether channel. I bet this would be a perfect place to rap a third wire for pulsed DC. I would really like to see what happens then.
    just to recap the principle of polarity in the Ankh Set up:
    Copper vs Iron
    Copper Egg vs Emf Egg
    opposing vortex in Rodin Coil
    AC vs DC
    Copper vortex (secondary coil in Tesla Coil ) vs Emf vortex in Copper Egg
    etc.....
    Signs and symbols -Confucius.
      petar113507 posted this over at : http://www.energeticforum.com/155402-post527.html
      Note: Too quick of alternating currents don't let the dielectric "relax" -- and dissipate heat as waste. Pulse DC too quickly, and it behaves the same as AC. More hints in the book are on this later -- effectively telling me why I need a sharp rise/fall, rapid (microsecond) DC pulse.
      This also Applies to SonoFusion;
      worth the read
      page 105 mentions crystal geometry too
        Pulse DC and it behaves like AC. WHich explains why it matches up in an alternate rythm to form the electrical helix. All that has to be determined is the rate of pulse or should i say the frequency. Once the DC coil is on the right frequency and combines / resonates with the AC pulse then according to what he is saying this should create a high frequency superconductor. Or did I read it wrong.
        • from the same post:
          DC -- "infinite" temperature -- as long as it is confined within a small enough space. The average temperature seems normal.
          The velocity of fluid at any point in a vortex is equal to a physical constant divided by the radius from the suction center. That is to say that velocity increases as the radius gets smaller. In a perfect vortex, as the radius approaches zero its fluid velocity will approach infinity. As infinite velocity is impossible in the physical universe, something has to give. In the case of water the molecules begin to dissociate into a vapor. This dissociation is accompanied by the generation of high voltage electricity. We have measured charges as high as 12,000 volts in the exact center of a liquid vortex! The pressure in the center of a vortex is theoretically infinitely negative. In this condition, space would be turned inside out.
          We find that the vortex has a rhythm of its own. It shrinks in diameter and increases in length at one moment, at the next it expands in diameter and shrinks in length. It continues this oscillation in a periodic manner just like a pendulum or the mainspring of a watch.
            It is the behavior that becomes the same....
            John W. Keely
            ...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
            one more for the Ankh Set up...the Vortex behave the same too
            AC/pulsed Dc is looking more and more perfect for the Rodin Coil and the Ankh Set up
            AC/DC love the band: http://www.youtube.com/watch?v=hSAHHd7q8BU
            • Shawn, I just wanted to point out that for the stacked Rodin coil set up.....the third field (the empty space ) if you virtually join one gap from one coil to the gap from the coil above and so on ; the joined gaps will have to also form a golden ratio
              i also found this here : Balkanmysteries.com | Just another WordPress weblog | Page 2
              Inspired by the pioneering work of Dr. Kervran, Dr. George Ohsawa sought to transmute sodium into potassium in vitro. The method revealed itself to him in a symbolic dream. Thus inspired, Dr. Ohsawa and Michio Kushi, et al., constructed an experimental electric discharge tube with copper (Yin) and iron (Yang) electrodes (and the egg is created )
              and another wink from mother nature
              Large hailstone with concentric ring
              • from the same link mentioned above:
                pyramid antenna
                  the beauty of this setup is that you can use a magnetic stirrer, watch the following vid
                  Homemade Magnetic stirrer - YouTube
                  note: this set up is also good for water desinfection (use copper for the ball )
                  once again all the element present in the Ankh Set up are present in the Peter Davey setup
                  the Egg
                  The Coil / Ring (i would recommend quartz ring coated with mica or ceramic coil )
                  a Pole
                  Water one of its properties is memory
                  the ball
                  I would like to add this info to this set up :
                  James Y Johnson -- Dipolar resonance -- Anomalous dispersion bands
                  Accordingly the resonance positions of electron polarization lie in the region of the Roentgen, ultraviolet and light rays, the resonance positions of atomic polarization lie in the region of the infrared spectrum and the resonance positions of orientation polarization lie still further beyond in the region of the radio short and ultra-short waves.
                    copper wire is non magnetic but if there is a current running through the wire then it is magnetic -- attracts electrons Im sorry I thought this post was referring to running ac and dc together in a rodin coil.
                    Iv got to slow down seems my mind has been in overdrive here lately.
                      it is quite alright, you are on fire , drink some spring water
                      • it was literally under our nose
                        Wine glass resonance in slow motion - YouTube starts at 1min 30
                        imagine that happening with the copper layer and iron layer in the egg
                          Mother nature is a flirtatious gal that is constantly giving winks and nods in our direction but how often we over look them.
                            John W. Keely
                            I agree whole-heartedly.
                              I forgot to mention this but if you watch the vid, you'll have an idea how the Peter Davey Sonic boiler works
                                I had no clue that the glass moved that much.
