The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • found a really good Article on Synchronicity :
    a few excerpt ( you should read it in its entirety )
    Cryptoscatology | Articles | Features | Fortean Times UK
    In 1919, HM 1 .
    [B] Randall Cole Roffe: Harmonic Resonance
    [/B]
    The application of the principles of one science into another is often neglected. Today we have a massive and growing volume of experimentally proven information that certainly does not always
    find its every application.
    In the real world, we can work from scientific theory, through experimentation, into an engineered result, but just as often we work via reverse engineering, from the
    result back into the origin.
    If we take a good look -- and listen -- at the whole of manifestation, and apply the principles of acoustics and music, and of the color wheel, the grand pattern that emerges is self-evident.More
    than this, a possible explanation of a medium of transmission of a universal electrogravitational influence, as a plenum far more fundamental than an ether, becomes apparent. With this realization a
    whole new understanding of physics also emerges, with awesome possibilities.
    Randall Cole Roffe
    .Fulcanelli
    Signs and symbols -Confucius.
    • took it for a ride at my bro's place ... gave it to him for try it out as he knew where a water line was running underground .... result ... spot on
      did a few other tests .... all concerning water detection ... all successful
      ps: he was a little reluctant as he was not a 100% believer .... but after trying it ... he was quite surprised
      • ave just posted the following from: http://www.energeticforum.com/renewa...magnet-25.html
        Originally posted by Dave45
        Ezechiel's wheel within a wheel
        so figured we'd have a look at it in the Bible with some Harmonic Math Goggles on
        Ezekiel 1:4-26 NIV - I looked, and I saw a windstorm coming - Bible Gateway
        Ezekiel 1:4-26
        1:4 - 26 = 1 4 8 = 13 = HM 4
        so let's see if HM 4 is mentioned
        I looked, and I saw a windstorm coming out of the northflashing lightning and surrounded by brilliant light. The center of the fire looked like glowing metal, 5 and in the fire was what looked like four living creatures. In appearance their form was human, 6 but each of them had four faces and four wings. 7 Their legs were straight; their feet were like those of a calf and gleamed like burnished bronze. 8 Under their wings on their four sides they had human hands. All four of them had faces and wings, 9 and the wings of one touched the wings of another. Each one went straight ahead; they did not turn as they moved.
        etc...
        • Let us re discover the principle of Mentalism:
          as I was checking out a science Channel : Fresnel Lens - YouTube
          the Subject of The Fresnel Lens Caught my Attention
          Fresnel lens - Wikipedia, the free encyclopedia
          History
          The idea
          How a Fresnel lens focuses light
          If you look closer .... a 360 degrees Fresnel Lens resembles amazingly a Standing Wave :
          ---------------Turn the following image 90 degrees and you have the effect of a Fresnel Lens when light reaches it :
          time warp standing wave check it out ... much to be inpired by these pics
          time warp standing wave pictures by MonsieurM - Photobucket
          ps : we discussed standing waves here : http://www.energeticforum.com/renewa...tml#post157763
          work of Walter ( Lea ) Russell
          reduction / expansion Harmonic Math / Scientific Math ..... inhale / exhale ..... centrifugal / centripedal
          centripetal energy is the basis of life whereas centrifugal energy is the basis of decay and destruction. V. Schauberger
          • let us consider the following for a second:
            and what happens if you create a Magnetic Fresnel Lens , do you concentrate electricity or Magnetism
            either way .... it would be mighty useful
            • If you were to read the following and then look at the picture ; Surely you will find quite a bit of Correspondence / Resonance in these two Fractal Constructs :
              Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature (fractal nature), for in it there is a spirituality and conjunction of elements, and an earth which is golden in its tincture. Hermes Trismegistus
              note the mirror effect when you look at it
              ------------------------------- also related
              -------------------on a side note
              the last image is a Tesla coil
              Electricity Generator Demonstration - YouTube
              • The largest (first-order) lens has a focal length of 920 mm (36 in) and an optical area 2590 mm (8.5 ft) high. The complete assembly is about 3.7 m (12 ft) tall and 1.8 m (6 ft) wide. The smallest (sixth-order) has a focal length of 150 mm (5.9 in) and an optical area 433 mm (17 in) high
                focal length of 920 mm (36 in) = 11 / 9 =HM 2 / HM 9
                an optical area 2590 mm (8.5 ft) high = HM 7 / HM 4
                The complete assembly is about 3.7 m (12 ft) = HM 1 / HM 3
                1.8 m (6 ft) wide. = HM 9 / HM 6
                • from: http://www.energeticforum.com/renewa...tml#post190139
                  Looks like one could move through the inside of the other eh
                  indeed, however keep in mind that the South pole ( - sign ) is smaller than the North Pole .... so in the drawing the Negative Pole with arrows would be a bit smaller ( asymetry )
                  Think of it this way, The South Pole Wheel has to fit within the North Pole Wheel a Standing Wave
                  North Pole and South Pole ( look closely at the circles )
                  an Alchemical Analogy for you would be:
                  When the Sun meets the Moon (the sun is larger and More immaterial than the moon )
                  the same is shown here :
                  • an Alchemical Analogy for you would be:
                    When the Sun meets the Moon (the sun is larger and More immaterial than the moon which is more Material )
                    The Intiate / The Teacher
                    Moon square / Sun Square :
                    • a bit of news for you :
                      Strange lava spirals discovered on Mars | TG Daily
                      Lava flows coiled like snail shells have been found for the first time on Mars - and they're bigger than anything similar on Earth.
                      Pigeons Navigate With GPS? Science Measures Reaction to Magnetic Field | Decoded Science
                      Scientists have figured out how
                        Meet Brain Magic ... we have Discussed what you are capable of doing with just Two Sticks also called Dowsing
                        ... how about breaking a bottle (Glass = 75% Silica SiO2) with your projected Energy
                        Silica (the chemical compound SiO2) is a common fundamental constituent of glass. In nature, vitrification of quartz occurs when lightning strikes sand, forming hollow, branching rootlike structures called fulgurite.
                        Keith Barry: Brain magic - YouTube!
                        Keith Barry shows us how our brains can fool our bodies -- in a trick that works via podcast too. Then he involves the audience in some jaw-dropping (and even a bit dangerous) feats of brain magic.
                        one word for you : Impressive
                        originally on before its news
                        • Now here is a nice synchronicity for you
                          Before It's News
                          Some scholars are convinced an ancient, advanced civilization existed where the nation of India is today. They claim the prehistoric city-state had advanced technology including high-energy weapons, jet-like aircraft, and even the atomic bomb. Now a stunning artifact has been identified by some researchers as the part of an aircraft landing assembly dated as old as 20,000 years made from a metal that wasn't discovered until the early 1800s.
                          For many years certain researchers in India and Asia have tried to convince Western skeptics that the so-called religious texts of the Vedas are really descriptive history. Lending credence to their claims are various artifacts found over the years and detailed descriptions of the vimana aircraft engineering and construction.
                          The incredible discovery during the 1990s of the remains of an ancient city in northern India that was still highly radioactive sent some archaeologists scrambling to the site.
                          And then, a very strange artifact, the Wedge of Aiud,first unearthed in 1973, was given another look: a machined piece of metal made of an aluminum alloy
                          • Are you familiar with morphic resonance ( similar to the Fractal Resonance we have been discussing )
                            The Science Delusion | Fortean Bureau of Investigation | Features | Fortean Times UK
                            morphic resonance. Similar patterns of activity resonate across space and time with subsequent patterns. This hypothesis applies to all self-organising systems, including atoms, molecules, crystals, cells, plants, animals and animal societies. All draw upon a collective memory and in turn contribute to it.
                            Sheldrake believes that memories are not stored in the brain but somewhere outside of it; the brain recalls them not as a hard drive does, by playing back physically-stored electrical signals, but more like a television that tunes into transmitted signals and decodes them as memories. It does this by morphic resonance. Here, there are
                            But Sheldrake, to the chagrin of his detractors, is not just another amateur crackpot materialists
                            The final figure is arrived at by a committee of expert metrologists some are discarded, either because they differ too much from what is expected or because their source is not considered totally reliable.
                            now you know ... a committee of expert
                            read on .....quite interesting
                            • compare the above theory with :
                              The akashic records are described as containing all knowledge of human experience and the history of the cosmos. They are metaphorically described as a library; other analogies commonly found in discourse on the subject include a "universal supercomputer" and the "Mind of God". People who describe the records assert that they are constantly updated automatically and that they can be accessed through astral projection[1] or when someone is placed under deep hypnosis. The concept was popularized in the theosophical movements of the 19th century and is derived from Hindu philosophy of Samkhya. It is promulgated in the Samkhya philosophy that the Akashic records are automatically recorded in the elements of akasha one of the five types of elements visualized as existing in the elemental theory of Ancient India, called Mahabhuta. In the Mahabharata mention is made of Chitragupta (lit. "hidden picture"). He is the son of Brahma and a minister of Dharma and his duty is to examine a list of the good and evil actions of men (the Agrasamdhani) after their death. "Nothing is lost of either piety or sin that is committed by creatures. On days of the full moon and the new moon, those acts are conveyed to the Sun where they rest. When a mortal goes into the region of the dead, the deity of the Sun bears witness to all his acts. He that is righteous acquires the fruits of his righteousness there." (Mahabharata, Anusasana Parva, Section 130, Ganguli trans.) The term akashic records is frequently used in New Age discourse.
                              • just a little info from: http://www.energeticforum.com/renewa...qm-thread.html
                                Originally posted by AetherScientist View Post
                                Can someone post information about the special characteristics that Sweet's magnets had?
                                found the following , hope this helps (heat is a way of exciting the atoms )
                                from: Site:LRP:Tom Bearden Remembers Walter Rosenthal & Floyd Sweet - PESWiki
                                Hi Les,
                                "Walt was a professional electrical test engineer, and a darn good one, who made his living in aerospace etc. doing professional electrical and electronic testing, for many years.
                                He was completely competent (far better than 99% of the present BS level EEs in the overunity field). As one example, Sweet had great difficulty in activating his barium ferrite magnets so the VTA process could occur. Walt designed and built Sweet a professional "discharge control, activation unit" which made the initiation process happen with precision. Only a few of the barium ferrite magnets could be activated anyway (Sweet used surplus audio barium ferrite magnets, and he could only get about 1 in 30 to activate). Sweet did a pre-screening of each magnet with a field meter and probe, going over the surface of the magnet, bit by bit, with precision. If the surface field intensity had abrupt changes in little areas of 8% or so, then that magnet would not hold activation longer than a few seconds. The smoother and more uniform the magnetic field, the better
                                ------------ just a side note :
                                So with self-oscillation established in such powerful fields, right at their source, this led to an oscillating magnetic field in the magnet itself. For an activated magnet, one could stand a little piece of shim stock on it, and the shim stock would wave continuously to and fro, fanning the air
                                it is also called a Standing Wave:
                                ---------------------------------------------- anisotropy again
                                here is why some of his magnets worked and others did not ( not all Barium Magnet are equal )
                                Magnetocrystalline anisotropy - Wikipedia, the free encyclopedia
                                Magnetocrystalline anisotropy is the dependence of the internal energy of a ferromagnet on the direction of its magnetization. As a result, certain crystallographic directions are preferred directions, or easy axes, for the magnetization. It is a special case of magnetic anisotropy. The spin-orbit interaction is the primary source of the magnetocrystalline anisotropy.
                                Magnetocrystalline anisotropy determines whether a magnetic material can be made into a good hard magnet, a good soft magnet or neither. Hard magnets are an essential component of electromagnetic motors and soft magnets are an essential component of transformers.
                                he must have been looking for a sweet spot that combined the soft magnet properties and the hard magnet properties
                                COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
                                An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. a harmonic cascade effect
