Originally posted by MonsieurM
Harvesting Energy From the Sun Using Crystals
@petar113507
check this out Smith Coil (Caduceus )
Levitationsmaschine-Cetin BAL - GSM:+90* 05366063183 -Turkey/Denizli
Signs and symbols -Confucius.
This makes sense in that if the disk were charged with a electrostatic field the A vector field would be attracted to it. It would boost the magnetic field in one direction causing lift - maybe
About the time travel- that may be a stretchLast edited by Dave45; 09-13-2011, 08:38 PM.Half of the Answer is knowing the right Question
THE STUBBLEFIELD PAPERSOriginally posted by Dave45 View Post
ZPE
your second coil:
Access : Solid-state physics: Golden ratio seen in a magnet : NatureThe golden ratio spotted in a magnetic compound.
Tachionator
This is one reason why certain scientific investigations in the area of subtle energies cannot be readily replicated. It is not always a matter of scientific protocol, but a matter of relationship. Unfortunately many scientists would consider this to be some kind of inessential and perhaps bothersome epiphenomena. Although such individuals are scientists, to Marcel, they were technicians attempting to prove what they already thought was true. The true scientist is one who attempts to discover with childlike curiosity. Too often we, all of us, only want to confirm what we already believe.The word crystal meaning frozen light.
what you are seeing is two opposing "drains" connected by the Smith Coil or if you prefer a "white hole/black hole"Originally posted by Dave45 View PostMM cool site I put it into google translate
I wonder is the A vector field moving in the aluminum disk, is it attracted to the disc.
translation: Google not meOriginally posted by Dave45 View Post
ZPE
If two coils are connected symmetrically in opposite directions against each other, this is a non-coil inductive.Wenn a current flows through it, one fine Helion it generates a field that shields the front of the room air flow coil. Sealing a room may not be with an external magnetic field lines penetrate filled. It is designated as a shield. This is also known as field Hochst resulting ZPE. This is only needed. Coils are not connected together as the inductive, not disturbing the flow and electromagnetic influences affecting escapes, and the pulsing coil.Signs and symbols -Confucius.
Tree of Life:As happened in his study of luminescence, he found the published technical literature sorely lacking. One morning, as shown in the Kabbalistic teachings. This was a teaching and a pattern with which Marcel was unfamiliar. At the time he saw only the pattern of a rectangle with a triangle at each termination.
Originally posted by MonsieurM View PostAs i was searching the symbol Flower of Life, i found this tidbit of info
Flower of Life - Wikipedia, the free encyclopedia
Tesla and and Leedskalnin had the same opinion...
see post: http://www.energeticforum.com/148673-post110.html ;
A Vogel Cut Crystal (compare with Dan Winter's vortexer )
Originally posted by Dave45 View PostI got this in an email amazing
The Cross in Our Bodies
This would make a great coil configuration
My Truth
new illuminati: ALCHEMY: The Science of Enlightenment
7 spheres...The Emerald Formula
The foundation of alchemical philosophy and practice is reflected in nature's elements and universal pattern of transformation.
(middle picture )
Dave, you should definitely read Vogel's research ...on structured waterOriginally posted by MonsieurM View Post
remember this
Resonance transfer occurs because the energy waveforms coming out of a vibrating substance have nearly identical waveforms.Last edited by MonsieurM; 09-14-2011, 12:01 AM.Signs and symbols -Confucius.
MM Iv been looking at the Testatika machine, could we rotate the wheel around a coil in the A vector field, and collect the field.
Or maybe in the middle of these coils
I really need to put the bucking fields of a magnet in the freezer, I may get it done tonight.Half of the Answer is knowing the right Question
After quite a few minutes looking at the coils, it dawned on me:Originally posted by Dave45 View PostMM Iv been looking at the Testatika machine, could we rotate the wheel around a coil in the A vector field, and collect the field.
Felix Ehrenhaft: Magnetic Current --- 9 articles
Ehrenhaft and his colleague, Ernst Reeger, have proved that there is more than a little truth in the suspicion that tiny particles of dust tend to rotate when exposed to the rays of the sun. For they have not only reproduced this phenomenon in the laboratory, but they have succeeded in photographing it as well. In order to do this, Ehrenhaft placed tiny graphite particles into a glass flask, from which the air was completely evacuated. Then the flask was exposed to focused beams of sunlight. Instantly a large number of particles were seen to rise from the bottom of the flask and start to weave elliptical, circular and spiral-shaped paths, which were quite visible to the naked eye. The phenomenon ceased as soon as the light was weakened or cut off completely. Photographs taken at one-fifth and one-tenth of a second proved that not only were the particles orbiting, but more significantly, they were spinning on their own axis.Electric and Magnetic Charges ~
In subsequent experiments Ehrenhaft established that particles can carry both electric and magnetic charges at the same time as evidenced by their motion in gas or liquid. He theorized that the magnetic charge equaled the electric charge on particles of the same size. In one experiment, the particles rotated around the magnetic current because of their electric charges. Because of their magnetic charges, bubbles moved either upeard or downward. Their resulting path was a helix and could be seen "even by the naked eye to be circulating in a counterclockwise direction, when looking upon the face of the S pole. This movement carried the bubbles downward, even against the force of buoyancy". (Ref. 12)
We're not the first,
Pay attention to detail
I didnt get the bucking magnets in yet, its hard to get them aligned and keep them there. But I got it.
Next Im going to put them in attraction mode, we may explore some new ground after all
