Tesla's Magnifying Transmitter "Replications"
  • Originally posted by IEatFrauds View Post
    Suspending the tape from a point anywhere but directly above the globe it is theorised to be attracted to would exclude gravity as the cause.
    Not unless you can turn gravity on and off
      Hi all, I would like to present some plans I have of building some new coils and
      associated equipment. The new coils will be resonant below 200 Khz and capable
      of very high voltage.
      Specs;
      Coil A 300mm diameter 100mm high 0.5 mm wire, 160 meters 200 turns.
      Coil B 100mm diameter 300mm high 0.5 mm wire 160 meters 600 turns.
      Coil C 320mm diameter 40mm high 5 mm tube 2 to 4 turns tapped 5mm spacing between turns.
      This is what the coil will kinda look like.
      Hi Farmhand. Just wondering how to go about making another mini coil with this wire, but MT ideas keep popping up. Anyway I looked at a couple of images and measured the extra coil, and the frame is the same height as the width.
      Also you can see the spacing changes near the top. And I just realised I can wind mine higher up to make it the same height as the width by making some of the turns single layer instead of two thus effectively extending the wire Maybe that's what the extra spacing is about in Tesla's coils, besides avoiding arcing between closer turns. Maybe he's also increasing the spacing so the wire actually ends up at the top, not when the wire runs out.
      • Also did you notice Telsa usually used his spiral coils in a vertical orientation ?
        I think the spacing is mainly for voltage reasons the voltage increases a lot
        towards the top. And I think Nikola would have used un-insulated wire except
        for the air spacings. The Colarado Springs setup still had several flaws I think
        which he ironed out for the final patent .
        I draw your attention to page #2 line 73 to line 83 of this patent below,
        where he states the turns of coil "B" should be close wound for the reasons
        he states. I see no reason to doubt his words.
        ELECTRICAL ENERGY - Google Patents
        If you look closely at the drawing you can see that the wire in the "B" coil is
        the same diameter as the wire in the "A" coil but it seems to have thick insulation.
        Which can be seen in my opinion at the top of the "B" coil where it joins the
        hood.
        When I look at the patent I see the "B" coil has 5 times the turns of the "A" coil
        and the "A" coil is 5 times the diameter of the "B" coil. So they have the
        same length of wire.
        The "C" coil has half the turns of the "A" coil but twice the thickness of wire
        at least.
        These are the ratio's I think I will try to achieve. The other thing that jumps
        out of the patent is the quite significant capacitance of the terminal and the
        tube conductor (B'). Overall the coil arrangement is the same height as it is
        wide roughly. The terminal goes higher.
        With the primary coil "C" and the secondary coil "A" having such close coupling
        there would be a constant voltage output effect I think, and the current input
        should
        rise and fall to meet the demand of the load on the receiver. As any good
        power transmission facility should, I think. The current input should decrease with
        diminished load at the output. We wouldn't want to have to input full power even at low demand.
        P.S. The coil I drew above that you linked Has a 1:3 - 3:1 ratio "B" coil to "A" coil.
        But the Primary varies from the ratio's for practicality, I hope. I am still
        thinking it is a valid design and I might just go with it still, 3:1 should give enough
        distance between "A" and "B" coils to prevent arcing at the voltages I want to
        use. There will be a 100 mm space with less than 50 KV at that level I think.
        Then from the top of the "B" coil to the top of the "A" coil will be about 300mm,
        It should take a couple of hundred Kv to jump that. And an arc rail can be
        fitted if necessary.
        • You could be right about the spacing's towards the top, this spiral coil coil has the same kind of thing going on,
          Uploaded with ImageShack.us
          With a spiral coil used vertically the extra coil would have to be also spiral.
          Otherwise it would stick out the side and the only way to space the extra coil from the "A" coil is to increase turn spacing.
          I still think it's more to do with voltage, but it sure can't hurt to do it. So it's a safe bet. And well worth doing.
          As the voltage increases between the turns so would the effective
          capacitance there and therefore the energy as well.
          I guess as the voltage between the turns fluctuates the capacitance is also varying.
          When the point is reached where the energy exceeds the capacitance
          (storage level) there will be a leak of energy from the terminal or top of the
          coil and the voltage will drop. We want to avoid that happening before the
          safety valve "V" triggers and releases excess energy back to the ambient.
          Depending on where "V" is positioned within the field of the terminal it's
          propensity to leak off juice will change. And is predictable.
          Oh yeah, I think the advantage of the toroid as compared to the sphere
          terminal is that the voltage is less on some parts of the toroid whereas I think
          it would be uniform on the sphere, the sphere I can't be certain of because I
          haven't tried one.
          2nd P.S.
          The coil he's holding does look like it gets fitted to the spiral on the wall and
          the coil he's holding is close wound by the looks of it to me. You can see the
          mounting brackets on the two coils. Hmm cool pic thanks dR.
          Picture tells a thousand words.
            Yes good point, I hadn't noticed that.
            I don't know if Tesla actually used his spiral coil vertically all the time, all the pics I've seen show it like that but I can tell you mine gets in the way when it's horizontal, so I can imagine trying to do things with that in the way Interesting anyway, I hadn't thought of using it vertically with the extra coil. Also a spiral extra coil could be interesting.
            I don't know anyway, I think the best plan of action is to try it each way and then compare the results. I like the idea of building a smaller scale version of that Colorado Springs one to play around with.
            Have you seen that film The Secret Of Nikola Tesla? This thing is in it...
            I like that
            • No I haven't seen that movie, where can I get it ?
              I agree we should experiment with different designs, Tesla did.
              I did buy from the hardware some 6 mm square Tasmanian oak for wood strips
              to build spiral coils and some round dowel as well but it's pine.
              I would really like to build a scale model of the Magnifier patent picture,
              complete with wooden supports, the hood and tube conductor. It would still
              be at least 600 mm high though.
              This picture below I think shows the same coil before it was modified.
              I'm still looking for the picture of four spiral transformers i seen before, they
              are mounted vertical on a central dowel or core maybe and appear to be for
              four phases of supply or conversion. My guess is they were four HF transformers
              for a 4 phase HF HV supply.
              For supply transformers, by HF I mean above normal iron core transformer
              frequencies. So 5 Khz each would be HF.
              And for HF resonant air cored transmitters 20 Khz is low frequency. That's
              how I think of low and high frequency for things. It's relative to the regular
              frequency of devices doing a similar thing.
              • Those are some interesting pictures, it's interesting to think of the possible
                progression of the modification to the Transformer.
                It looks to me like he built this one first, and wound it right on the wall.
                Then I assume he developed very high voltages which arced over in the center
                of the coil, so I think he would have spaced the turns in the problem area,
                needing to remove some wire to do it. So then he built another coil to stick
                out the side. I think at that time he was using the extra coil like an antenna.
                Which he is holding, it looks like it fits to the spiral coil and covers the spaced
                section, there is a distance between the center of the spiral out to the start
                of the extra coil. It's turns could be spaced too it's hard to tell from the angle.
                t would make sense that the wire he removed is on the extra coil and spaced
                as well like your's.
                dR, it looks to me like the setup you came up with is exactly what Tesla has
                in that picture. Good job. I've never seen that picture before.
                That is quite the coincidence.
                If you look closely at the first picture blown up, it looks to me like the primary
                is the first eight (8) turns or so which are a much darker color than the rest
                of the turns, they must be the primary.
                • You can watch the film here
                  The Secret Of Nikola Tesla - YouTube
                  Or download it here
                  Secret of Nikola Tesla - The Movie (Tajna Nikole Tesle) (1980).a (download torrent) - TPB
                  I don't know if Tesla built one that size or if it's just for the film, it appears to be working because you can see what looks like series spark gaps in one of the pictures. I like the size of it anyway, could be good to experiment with something like that. I'm interested to follow the same kind of progression and try the same kinds of things to see where it goes. I could read things all day explaining what and why, but nothing beats doing something and then seeing the effect.
                  My dowels have all been pine so far, got a hardwood one but haven't tried it yet. Haven't had any problems with it so far, I don't know how "reasonable" it is to be concerned about the resin in the pine. But only my primaries have been on pine so far, haven't tried any really HV.
                  Yes I'd like to make one like that too, maybe I'll copy your design when you decide everything
                  Reminds me of that Egyptian image with the dudes in sunnies
                  It's basically that image of Tesla with the book I copied for the design of my spirals. I can see in that picture though relative to the spot in the centre, the supports are positioned so it does spiral progressively with no "cross over" sections like you'd have with layered turns.
                  Yes I can see 8 turns that looks like the primary. I think in the patent he says single turn primary though, can't be sure. I wonder what the timeline is with all these pictures and patents. Could be an interesting coincidence anyway, I wasn't aware that Tesla might have added an extra coil to the spiral like that. It does look like that's what's going on
                  Off to make two mini secondaries with the 13 metres 26.6g 24 SWG wire now
                  • I think but I'm not sure, my 6mm diameter spark gap copper rods are expanding with the heat I normally leave it shorted out when it's not being used, and the last 2 times I've come back to it it's no longer shorted. So it's either unscrewing itself or something is changing size.
                      That document of Eric Dollards is rather technical. And I think maybe a bit over the top, which is ok if thats how you want it. He says things like the primary should be only one turn amongst other things, which I think are debatable and relative to an overall design he had in mind.
                      I cannot believe that Magnifying Transmitters cannot be built to work with more than one primary turn, he is talking of absolute theoretical optimums.
                      Real life is different and absolute theoretical optimums may not be practical. I think he even mentions something like that in there, amongst all the numbers and letters that are not words.
                      I won't say he is wrong but it seems like theory, I still have not seen a large magnifying transmitter, ground connected, transmitting energy over a distance and received by another coil and converted to DC or AC usable 50 60 hz.
                      Has anybody seen that ?
                      Seems the whole picture should end wih a device running from the receiver from converted DC or from 110v or 220v AC 50 / 60 hz.
                      Just a quick disclaimer here. This is response is from Eric Dollard. Not from me. Eric's words directly. Eric is "pissed off that people aren't getting it." "They are getting way off the track." "And there's no legitimate reason for it".
                      How many turns did Tesla use at Colorado Springs? One- there is a reason for that. It's only with one turn that you can get the maximum amount of capacitive dishcharge with only one turn. Read the Colorado Springs notebook. For never building one, why is there a picture of me with a wireless Tesla Transmitter lighting up a light bulb in two peoples hands on the cover of "Condensed Intro to Tesla Transformers"? With no wires! And by the way any idiot can make a Tesla Transmitter out of the information provided in that book. It seems to me there's a lot of people who need to go back to high school electricity class before playing with Tesla. Don't bog the world with your miscomprehensions.
                      Please help support my indiegogo campaign: Cosmic Induction Generator
                      • Originally posted by jpolakow View Post
                        Well, some of my personal demonstrations and the construction of my spiral coils are obtained directly from Eric's Borderland Sciences video, so if I'm not doing it right, then it's not my fault All appears to be on track based on the fact that I can light an incandescent bulb in my hand without a direct wired connection to the coil, the same bulb attracts aluminium tape, there is no need for closed loops, and the receiver receives at the other end as intended. In other words Eric's demonstration has been replicated. It has all been recorded on video and published on youtube, so what can one say If none of this is correct then I would argue that it's necessary, personally, to progress this way in order to get it. Unless someone is happy to just hand me a complete design, including all the measurements, of what I should be building. That would be greatly appreciated But thanks to Eric anyway. I don't know if he's referring to people personally, individual posts, or the whole thread in general and everything we're doing here is wrong, but all I can say is I've replicated what he demonstrates in one of his videos, so if all that is wrong, thanks anyway because it's all certainly very interesting and it all works like he showed
                          Eric is allowed to be pissed off but he'll have to get over it, because Eric
                          doesn't rule over me.
                          As for the one turn, while that may be true that one turn is best. And Tesla
                          may have used one turn at Colorado Springs. How many Turns was on the
                          Long Island Transmitter ?
                          My contention was that one turn is the theoretical optimum and the Earth
                          wont split in two if more are used. I don't think Tesla would mind that we use
                          more than one turn.
                          The transmitter I built here is solid state, should it also have only one turn ?
                          Even though it is powered with 12 volts and transistor switched.
                          In my opinion the primary/secondary resonant frequency's should match for best results,
                          that could be difficult to achieve with one primary turn on some setups. I
                          don't think it is absolutely necessary they match, and the matching can be
                          done different ways.
                          This is a perfect example of why I don't take to Eric. He's a name caller. It's
                          unnecessary. I bet I know a lot of stuff about non electrical stuff that Eric
                          doesn't know, does that make him an idiot or moron ?
                          When I said Eric had never built one any more than I have, I was talking
                          about a system that transmits power using the ground over a distance,
                          enough to light lights, over more than a few meters with high efficiency.
                          No where in this thread do I propose to be an Expert and "know" everything.
                          But the fact remains, I can do whatever I want as long as I don't break any
                          laws. I can experiment any way I so choose. And I will.
                          If Eric was to try his hand at something he had no previous experience at, but
                          something I was well experienced at, and he made some mistakes or was
                          thinking the wrong way, I would not call him an idiot. I would praise him for
                          trying then offer some help, or leave him alone.
                          Unfortunately for me, I take an instant dislike to condescending name calling.
                          jpolakow, where is your transmitter ? Where are all the devices Eric's thread
                          followers are building ?
                          How many Primary turns are on the spiral transformer in the pictures above ?
                          How many primary turns were on the long island transmitter ?
                          I honestly have had not much more than a quick skim through Eric's papers.
                          Mainly because I like to experiment more than read and I like to think about
                          things in my own way. I have referred people to Erics papers if they want to
                          get Technical. I don't dispute his work at all. But everybody doesn't need to
                          do everything Eric's way. It's a free world.
                          After the research and experiments I have done it's my opinion that to
                          transmit energy using the ground as a conductor with good efficiency a
                          frequency of 20 Khz or less should be used, as Tesla states.
                          So what of the comment by Eric that the rotary parametric transformer
                          outputs more power than is input ? After all that setup is only about 53 % efficient.
                          Originally Posted by vrand
                          Hi Eric
                          Can you please suggest a simple experiment/device where we can build a free energy device to power our homes and cars? Around 10 kw power output?
                          Cheers Mike
                          Here is Eric's reply on his Yahoo egroup n6kph forum:
                          n6kph : N6KPH
                          Thank you Eric
                          Cheers Mike
                          Sent: Friday, September 30, 2011 1:55 PM
                          To: n6kph@yahoogroups.com
                          Subject: [n6kph] Response to the forum
                          Santa Barbara Rotary Parametric Transformer, tested gave transformation
                          ratio, power it to power out, of 108% +or- 5% error of measurement. It
                          works, see video.
                          The guy asked for pointers to an experiment or free energy device of around
                          10 Kw to power a household, if he already had power to feed to a rotary
                          parametric transformer I don't think it would be advantageous to lose 47 % of
                          that power by feeding it through a Rotary Parametric Transformer.
                          • Besides, at the present time I am working on designing and building the required
                            equipment to transform the stored energy in my batteries to HV DC in a cap
                            bank. As a power supply to power my experiments. When I'm done with the
                            power supply I will know how much power I can use. Then I will build some more
                            coils using the experimental data and experience I've gained, and have some
                            more fun.
                            I'm winding a annular core now with four transformers for experimenting with, I'm
                            making it so that when I'm done experimenting with it, it can be used for a
                            regular 12 to 240 volt AC inverter.
                            • Here's an example of kinda what I'm talking about. I'm a qualified metal
                              fabricator/welder (boilermaker). I can do structural steel work, gas pipe
                              pressure welding ect.
                              If I seen my next door neighbor fabricating and welding the frame for his home
                              made dune buggy without properly preparing the joins to be welded or without
                              the proper gusseting, I'm not going to go to him and try to tell him he needs
                              pressure pipe quality preparation and welds or that he should use a special
                              procedure to perform the welding so the frame does not become distorted or
                              weakened. Because it's not necessary it's a home made dune buggy not a
                              $250,000 custom race car. A backyard builder does not need to know the ins
                              and outs of gas pressure pipe welding procedures or other such complex things.
                              A backyard builder can cut corners for convenience the buggy will still work,
                              even if corners are cut the invention will be more or less realized.
                              If on the other hand I seen him I seen him using a dangerous procedure on a
                              tow bar or tow hitch for a road bound vehicle which could be dangerous to
                              others I would say something and in no uncertain terms warn him of the
                              possible consequences of it failing while in use.
                              (eg. people getting killed by a wayward trailer) and jail terms.
                              We should keep things in perspective. My Tesla transformers are not going to
                              kill anybody.
                              Same thing with this. Theoretical optimums are not required, Tesla states as
                              much in the patents.
                              The information required to build, tune and operate a Tesla Transmitter is
                              contained in Tesla's patents.
                              I don't intend to have a whole town full of households relying on power
                              transmitted through my experimental setup. So I don't have much to worry
                              about. I don't profess to be an expert or to have built a perfected system.
                              I don't see how I could be the reason other people don't "get it". I can hardly
                              be blamed for people not "getting" what Eric is teaching them.
                              I didn't do any high school electricity class, and I don't play with Tesla, he's
                              dead.
                              Furthermore I do not need to ask for Eric's permission before I post my opinion
                              on a particular matter. And I don't think people should be worried about what
                              Eric thinks. We can tinker with whatever we want.
                                To begin with you titled the thread using the term "Replications", not Replications. Also Peter contributed on the first page so this divergence if you will is made clear from the start. Then we have both essentially been going our own directions with it while at the same time sharing results. The thread is full of terms such as "I think", "I believe", "in my opinion", "I will test" etc etc. The whole thing is open and there are questions throughout. If someone comes along, reads it all and then builds it wrong when they expect it to be right then they haven't noticed the fact that it's all a process of discovery. There are no instructions in post 1 as to what everyone must build and nothing is hidden. But I think it would be fair to say that Eric hasn't read through the entire thread (in fact neither have I), so it's not really a valid or fair judgement to base it on page 1 when a lot has developed since then. So I wouldn't be too concerned about it. I don't think you are the reason why I'm not getting it I'm not getting it for the same reason that someone who got on a bike for the first time 5 minutes ago isn't getting it. That's the purpose of getting back on and trying again.
                                Also don't get me started on the "let's all sit on our asses until someone else comes up with the answer and then we'll use it, and if it's wrong we can all blame him" method of modern humanity. If they sat on their ass and waited for the answer then they have only themselves to blame when it all ends up in a big mess. As long as one doesn't proclaim to be the source of all knowledge then I don't think there is any connection or basis for blaming that source for one being misled.
