Originally posted by Farmhand
ok what I do not understand is why you are at least from my knowledge base making this so complicated? at least that is how it looks again based on my knowledge base?
My understanding is that the b coil is a free resonant coil so it seems to me you would tune it much like stifflers methods using a spectrum analyser to start and then building the second as close as possible to it starting with the same wire lengths and mass etc.
then what is wrong with buying an elcheapo 1 amp 15,000 volt neon sign transformer and some 30 kv neon sign wire?
Could get 2 of them and fw rectify it and start with what is fw again 2.14x30kv? The higher the voltage you start out with the lower the coil resistances required to get your desired Vo and the sharper the Q will be at resonance.
stuff:
JavaScript Power Calculator
Inductors
Coil Construction Techniques - HAMwaves.com
RF Inductance Calculator - HAMwaves.com
If that interests you then you could either buy hv transmitter type diodes or just string 50 x 3 kv diodes in a row for each leg. LOL
Then for the air why couldnt it just be a rotary disk that is hollow on one side with holes drilled on the outside rim face to cut the air off from the pipe at whatever speed you dial in on your vari speed motor? then correspond how many holes you have and the motor speed to the freq you wish or do I completely not understand what you are trying to accomplish?
Can get fancy and sample it part way up and put a phase and voltage sensor on it and let it self tune to the resonance.
those 15kv neon xformers will hold a nice 4" arc either ac or dc, or step it down to 7500 or whatever v you are looking for and dont forget the screen cage to work behind.
Click the image to be able to read it.
Nothing creates energy.
