The essence of the physical effect of generating free energy from the secondary field
  • #16
    Originally posted by Guntis View Post
    No static magnets, it uses HV HF modulated rings and by triggering these fields
    you can move these rings horisontaly across the ferrite core and by moving it
    cause to spin ferrite domains in ferromagnetic matereal by this moving rings
    effect happening work who produces 50Hz frequency (depending on speed of moving rings)
    speed of movement causes to produce this Low Voltage Low frequency.
    it is fully tested near year. and i have witness that this device is fully
    working aparatus to produce electric power and it has capabilities to feed itself with that power.
    I see.
    Sounds more or less similar to this device built by Don Smith:
    Page 69/70:
    This is a small table-top device which looks like it is an experiment by a beginner, and something which would be wholly ineffective. Nothing could be further from the truth. Each of the eight coils pairs (one each side of the rotating disc) produces 1,000 volts at 50 amps (fifty kilowatts) of output power, giving a total power output of 400 kilowatts. It's overall size is 16" x 14.5" x 10" (400 x 370 x 255 mm). In spite of the extremely high power output, the general construction is very simple:
    The device operates on a fluctuating magnetic field which is produced by a small low-power DC motor spinning a plastic disc. In the prototype shown above, the disc is an old vinyl record which has had holes cut in it. Between the holes is an area which was covered with glue and then sprinkled with powdered neodymium magnet material. It takes very little power to spin the disc, but it acts in a way which is very much like the Ecklin-Brown generator, repeatedly disrupting the magnetic field. The magnetic field is created by a neodymium magnet in each of the sixteen plastic pipes. It is important that the change in the magnetic flux between the matching magnets on each side of the disc is as large as possible. The ideal rotor material for this is "Terfenol-D" (tungsten zirconate) with slots cut in it but it is so expensive that materials like stainless steel are likely to be used instead.
    You may also want to check out this patent:
    While quite different in it's particular design, the essential principle is the same: wobbling / triggering / modulating the microscopic permanent magnets (either aligned or unaligned) in a material / electron cloud in order to be able to tap the energy contained in the static electric field emitted by these atom-sized magnets. This energy is converted by these atom-sized magnets from the ZPE field, as described by Prof. Turtur: http://www.wbabin.net/physics/turtur1e.pdf
    • #17
      Originally posted by lamare View Post
      I see.
      Page 69/70:
      While quite different in it's particular design, the essential principle is the same: wobbling / triggering / modulating the microscopic permanent magnets in a material / electron cloud in order to be able to tap the energy.
      dear lamare this device is not related what i post here, here i post real working thing.
      sorry but you are start to spam this thread with stuff who are not related to this.
      Build, test yourself and then post. as we all know Don Smith not build at all any of FE device, only phrases from Tesla he say and thats all...
      • #18
        Sorry, no harm meant. Only trying to point you to further information that may be of assistance and in the hope it leads you to more insights and deeper understanding.
        Will leave you alone, then.
        Wish you all the best and appreciate your work and willingness of sharing your knowledge with all of us.
        • #19
          Guntis
          I understand (hope so) the concept, but please - BIG REQUEST - can you fix your pdfs. Or maybe write them in Russian and then we could translate ? Because I can't understand what is written in thos documents - too much grammatical problems for me. I tend to use simply plain English.
          • #20
            I think it works like Steven Mark said : "squeezing hose", but we are squeezing magnetic field generated by 50Hz modulation , along the length of stacked ferrite rings.
            • #21
