found this website on new innovative energy producing devices from Russia:
(i'd suggest to use google chrome it does automatic translation
Legend:
1 intake manifold injection
2 inlet valve engine
3 vortex nozzle liners
4 swirling jet (fuel-air)
5 knurled sleeve swirl injector
6 connection for air supply and water
7 Electrical connector standard fuel injector
8 standard injector fuel injector
Photo 3 Powerful field emission from the output transformer Tesla (below)
there is more on the website, enjoy
Note: Dudysheva is a name that keeps coming up in the webstie googled him but all i could come up with are russian websites...worth checking him out
Vortex fuel injector
Simply swirl the device is designed to save fuel injector of any internal combustion engine. Installed between the injector nozzle and the engine intake manifold. Used to vortex mixing and preparation of a homogeneous fuel mixture, which completely burned in the engine chamber. As a consequence, there is a significant savings of gasoline, increase capacity and reduce exhaust emissions engine.
Legend:
Magnetic spark to the rotation of the electric arc
The basis of the magnetic effect of rotation of the candles put an electric arc in a magnetic field. This candle-plazmotoron effectively vozplamenyaet any fuel mix, even with low-grade gasoline. Suitable for all gasoline and auto injector.
Anomalous energy sources and low-cost electric lighting
We offer on the basis of the Tesla transformer unique efficient sources of energy and cost-effective light sources. The photo shows the effect of the glow of incandescent and fluorescent lamps near the Tesla transformer with minimum power consumption of the network that the transformer. We are looking for investors and partners.
The vacuum tube as a source of gratuitous power
Valery Dudyshev solve the mystery of Nikola Tesla about his source of power for its electric car!
maturing energy revolution in the field of alternative energy...
...Nikola Tesla actually demonstrated in fuel-free electric car in 1931 in Buffalo (USA). Electricity to the motor car came to a mysterious box with radio tubes. But until now, the mystery is the source of electricity for the electric car remains unsolved!
The key is to get electricity directly from the conventional tube triode pentode-in unusual modes of their operation. It is only necessary to provide the explosive electron emission from its cathode. As a result of the triode vacuum tube can be obtained from the electrical load attached to it in parallel - so much power - what we want (well within reason of course: for example with an output power 5-10 kW). Explosive electron emission - used in this invention is the discovery of Academician of the Month. - Is achieved in the triode fed to the control grid of the triode by a series of short duration but high-voltage high-voltage pulses.
Explosive electron emission from the cathode surface leads to the formation of an avalanche of electrons accelerated by a control grid and anode fall in the triode
As a result, this avalanche of electrons from the anode goes to the electrical load, and through it again to the anode of the transistor. Here and there, and supported by the gratuitous electric current in the circuit "triode - the load". In other words in this mode, the usual triode vacuum tube with strong e-mail. field on the control grid becomes gratuitous source of electricity.
Calculations show that the usual triode vacuum tube evacuated to such a mode of operation, provides a powerful electron emission in vacuum-tube triode and after some work, get the transistor from the usual triode tube free electricity, and cooling the cathode and anode - with a radio tubes up to 10 kilowatts - that's such miracles!
Ritsionalnym very technical solution is a combination of resonant Tesla transformer with a vacuum tube. In this case, the explosive electron from the cathode emessiya vakuumery lamp is provided by the transformer Tesla.
