Hi ALL, Jerry D sent me this just wanted to share.
Ash
Dr. Hartmann writing about Keely's views on tuning forks;
Everybody knows that a note struck upon an instrument will produce sound in a correspondingly attuned instrument in its vicinity.
If connected with a tuning fork, it will produce a corresponding sound in the latter; and IF CONNECTED WITH A THOUSAND SUCH TUNING FORKS, IT WILL MAKE ALL THE THOUSAND SOUND, AND PRODUCE A NOISE FAR GREATER THAN THE ORIGINAL SOUND, WITHOUT THE LATTER BECOMING ANY WEAKER FOR IT.
Here, then, is the AUGMENTATION OR MULTIPLICATION OF POWER. If we had any means to TRANSFORM SOUND again into MECHANICAL MOTION, we would have a THOUSANDFOLD MULTIPLICATION OF MECHANICAL MOTION.
...Nor does the idea seem to be Utopian if we remember that modern science heretofore only knew the law of the conservation of energy; while to the scientist of the future the law of the AUGMENTATION OF ENERGY will be unveiled.
As the age which has passed away has been the age of steam, the coming era will be the age of induction. There will be a universal rising up of LOWER VIBRATIONS INTO HIGHER VIBRATIONS, in the realm of motion.
Mr. Keely will, perhaps, TRANSFORM SOUND INTO MECHANICAL MOTION by applying the LAW OF AUGMENTATION AND MULTIPLICATION OF FORCE."
John Ernst Worrell Keely - Wikipedia, the free encyclopedia
In 1872, Keely invited scientists to attend a demonstration at his laboratory at 1422 North Twentieth Street Philadelphia, of a machine which he asserted was motivated by a new and hitherto unknown force. Keely announced that he had discovered a principle for power production based on the musical vibrations of tuning forks and that music could resonate with atoms or with the aether.
Keely assembled an apparatus on top of which was screwed a globe with several apertures to which tubes were fixed, leading to cylinders. A reporter asked if he could see the globe's contents, but Keely declined, saying that it would take too long, and that he wished to show results rather than the mechanism. Keely then proceeded by taking a violin bow and rubbing it across one of two large tuning forks which formed part of his apparatus. After making a minor adjustment to the device, he opened a stopcock leading into one of the cylinders and the witnesses heard "a hiss as of escaping air". Keely told them that it was in fact "etheric vapor", adding "It ain't compressed air or any vapor having substance." The force was then used to lift some weights, and Keely claimed that he had about 22,000 psi of pressure at his disposal.[3]
Egyptian tuning forks
Egyptian Tuning Forks
The tuning fork car
Interact on KeelyNet Mail List: Re: Re. Linear induction for space launch
Zero Point Energy - Keelynet 3 - MDG 2007
The Hubbard & McKie machines appear to have used the principle Keely talks about where one excited tuning fork, placed in a room of hundreds of thousands of resonant forks, would cause all the other forks to resonate to a similar intensity, thus AUGMENTING the force. Magnets attached to the vibrating tines of tuning forks would be driven in and out as the tines moved. Coils of wire wrapped around the tines or in their presence would inductively produce a current that could be extracted. One excited fork would thus drive many other forks w/magnets so that energy would be multiplied. And this method will not produce the anomalous effects reported with some ZPE tapping devices (as with Sweet).Any other ideas on how we can quite screwing around and do some basic tests that will show how power (mechnanical or electrical) can be extracted as overunity, whether aether/zpe, resonant or gravity driven?
You might recall Hubbards claims that you can have one central coil that feeds 6-8 secondary coils and that through resonance you could 'evoke' additional energy from space for the same amount of power in the secondary coils.
Alfred M. Hubbard: Coil Generator
and the more modern Scott Mckie;
Mckie Podmod - KeelyNet - 06/02/94
My understanding of Bearden 'Final Secret' as something like this..that you get the same voltage on the end of every wire in a multiwire bundle....say 100 insulated wires all with the same voltage at the ends...
That where there is voltage you can 'evoke' current equal to whatever needs the load requires
Best analogy of this I've found is...imagine a huge wire, maybe a foot thick...voltage free amps can be drawn from the center core to the outside edge where the no voltage amps mix with the outside voltage to produce useable power when it flips by 90 degrees and moves as a current to power the load(s) attached to it.
Tewari, dePalma and others say this with homopolar motors...that the energy comes from the center of the magnet and is moved to the outside rim where it is tapped as high amperage DC with brushes or carbon contacts.
Typically homopolar generators produce 1.5 volts DC at anywhere from 1000-1500 AMPS...sounds like a lot of power but Volts X Amps = Watts so that is 1000 X 1.5 = 1,500 watts
There is a connection here to the mythical Dr. Gee in an old flying saucer book, ah yes, Frank Scully 'Behind the Flying Saucers' where he discusses the properties of magnetic lines of force and says if you can cross flux lines by 90 degrees you can destroy matter, etc.
Possibly if you can tilt one set of flux lines against another at varying angles LESS THAN 90 you can get various other forces, electricity, heat, mechanical force, etc...
BEHIND THE FLYING SAUCERS - Frank Scully, 134 pp ebook
Mantell's plane and every portion of his plane from teh motor to the tips of the wings hung together by reason of magnetic frequency. This was true of even Mantell himself. Therefore all that a flying saucer had to to do disintegrate Mantell's plane, the lecturer revealed, was to demagnetize it.
No two lines have ever been known to cross each other naturally. If forced to do so, or if crossed by 'accident' you get disintegration and fire. Anybody who could create such a magnetic disturbance could wipe out every living thing on this earth in a second.
They had come to the conclusion that everything existing owed its shape and being to magnetic lines of force. He explained there are 1,257 magnetic lines of force to the square centimeter. That is to say, to about a half inch.
Our late friend Peter Kelly always said 'energy as information'...that you can suppress the magnetic component of any mass so that you only have the electric which you can easily modify to whatever you wish (using radionics and other methods)...then you bring in the magnetic component and it will TRANSMUTE the mass to fit the new electric pattern...
So it appears that through resonance we can use the neutral centers of resonant masses to 'evoke' additional free power that we can convert to the forms we want...mechanical motion, electricity (coils), heat, etc...
I wish this Lawrence fellow the best of luck in producing a new type of resonant power generator.
Jerry @ Keelynet in Ixt
Ash
The tuning fork car
