Any news ?
Alfred Hubbard free energy device need your help
I have just writtent their executive editor, I will post any useful reply.Originally posted by boguslaw View PostHi
I ask somebody located near Seattle to dig into archive of
The Post-Intelligencer (Seattle WA) for article from Thursday, July 29, 1920 about Hubbard generator. Please if you could find every possible copy of this article and resolve two most important words in it.
A simple Tesla Coil with multiple secondaries?
As you can see in the schematics and some pictures of the hendershot transformer, it really looks like a Tesla coil but instead of having one secondary it has multiple secondaries.
Have anyone heard about someone that had used more than 1 secondaries in a Tesla coil? You know that there are different techniques to use the output energy from a Tesla coil secondary. A lot of people used it to make big sparks, but you can perform work with it.
My question right now is....
A ferrite rod (that acts like the core of the transformer) can act as a core? If I apply Pulsating DC in the primary, can I get dc or AC in the secondary?Last edited by AetherScientist; 07-28-2011, 10:40 PM.
While it may work also I believe Hendershot and Hubbard devices were the same and a bit different kind It was also very close to Hans Cooler device.Originally posted by AetherScientist View PostAs you can see in the schematics and some pictures of the hendershot transformer, it really looks like a Tesla coil but instead of having one secondary it has multiple secondaries.
Not just many secondaries but many transformers connected in series closed loop with Len'z rule eliminated.Radio frequency electrons speeding up in closed loop aka particle generator creating huge magnetic flux around center coil-capacitor charging it immediately with high current.
TPU is also similiar. It all ends with antenna system but here antenna is incorporated into oscillator system in very intimate manner compared to what Henry Moray,Don Smith, Kapanadze had done.
The noise around all those free energy devices is really big, I still cannot see the overall picture.
I think a big help would be to answer question why Tesla in his hydro-electric patent forced oil to circulate not only via spark gap but also via capacitor plates
Seems he eliminated charge immediately when capacitors are charged !? How then he would be able to discharge them ?
It works because Kapanadze and now other russians replicated that hydro-device patent.
For hydro-device I see only 3 solutions :
1. Capacitors were still charged but without electrons between capacitors plates
2. Device operation and oil flow were synchronized and replacement of oil between capacitors plates were done to avoid Len'z law in precise moment of electrical switching
3. Oil stored charge (electrons) and the amount of them accumulated over time. After some period of time capacitors were charged continously !?
boguslaw, did you check out this post: Oil Water and Energy -Originally posted by boguslaw View PostFor hydro-device I see only 3 solutions :
it may give you a clue on why tesla used oil....
That means 35 KiloWatt. Too much energy to flow in that thin wire. If we read more the article he says that he needed to stop his transformer because it got very hot.tests of the coil show a current of 280 amperes and 125 volts
A simple experiment that has been shown to work (check mopozco's channel), is to build a tesla coil and in the secondary you can use wireless longitudinal induction. Use a pancake coil as a transmitter, and one pancake coil as a receiver. You'll see how using only pure voltage you can perform work. Then you need to try the same experiment using more than 2 receivers. If they're in resonance, you should be able to magnify energy several times.
Thank you Shawn for taking the time to figure out the 2 missing words, now we know it is "house light-ing" circuit....much appreciatedOriginally posted by shawnnweed View Postthe two words are "house light-ing" circuit. It was smeared but I had another person verify with me and we both concur.
Signs and symbols -Confucius.
Yeah, it's not problem. I was in the Seattle are anyway. I called the newspaper, which is no longer a newspaper. They seem to only run online ads now. They referred me to the Central Seattle Public Library. I called them and they sent me to the historical section on the 9th floor at 1000 4th Ave. It's amazing the whole building, all ten floors, is one big library. I talked to the side desk and they sent me to a microfilm machine with the entire month of July 1920. They had new machines so it was microfilm and not micro fische. I went to the end and of the film and read the article. I had to use light enhancements and magnification to read it. However, it was still discernable. The article said that the entire thing was only 11 inches by 14 inches and put out something like 120 volts and 230 amps. He hooked it to a boat engine and ran the boat at ten knots. The article said that the entire thing was inert until he touchedfor a few seconds with a common house lighti-ing circuit. This reminded me of John hutchinson using a 12 volt dc adapter, with the wires cut, to polarize his crystal cells. 12 volts causes 1 volts. I have a feeling that both John's used higher voltage and amperage to polarize both of their batteries in a 12 to 1 ratio. But that is just a guess. However, not an unfounded guess.
,Shawn
Shawn, have you watched the vid i posted in this post, what you said reminded me of itOriginally posted by shawnnweed View PostYeah, it's not problem. I was in the Seattle are anyway. I called the newspaper, which is no longer a newspaper. They seem to only run online ads now. They referred me to the Central Seattle Public Library. I called them and they sent me to the historical section on the 9th floor at 1000 4th Ave. It's amazing the whole building, all ten floors, is one big library. I talked to the side desk and they sent me to a microfilm machine with the entire month of July 1920. They had new machines so it was microfilm and not micro fische. I went to the end and of the film and read the article. I had to use light enhancements and magnification to read it. However, it was still discernable. The article said that the entire thing was only 11 inches by 14 inches and put out something like 120 volts and 230 amps. He hooked it to a boat engine and ran the boat at ten knots. The article said that the entire thing was inert until he touchedfor a few seconds with a common house lighti-ing circuit. This reminded me of John hutchinson using a 12 volt dc adapter, with the wires cut, to polarize his crystal cells. 12 volts causes 1 volts. I have a feeling that both John's used higher voltage and amperage to polarize both of their batteries in a 12 to 1 ratio. But that is just a guess. However, not an unfounded guess.
,Shawn
