How to build a water coil
  • Check this thread out, i think Michael John Nunnerley has shown us the missing piece of the puzzle
    Signs and symbols -Confucius.
    • Scientists identify quantum differences between light and heavy water
      Scientists know that light water (H2O) and heavy water (D2O) have similar but not identical structures. Using quantum mechanics, researchers have recently identified several differences between the two water isotopes that previous research had not predicted.
        Dusty Shock Waves Generate Planet Ingredients
        I present you with the first detected Cosmic Hydro-Magnetic Generator
        just an addition from a previous post:
        the Crystalline forms of SiO2 Table, for instance the α-quartz
        Helical chains making individual single crystals optically active; α-quartz converts to β-quartz at 846 K
        and now read this info:
        An electrostatic spatial resonance model for coaxial helical structures with applications to the filamentous bacteriophages.
        It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
        • Investigation of changes in properties of water under the action of a magnetic field
          Professor Pang Xiao-Feng and Deng Bo studied the properties of water, and their changes under the action of a magnetic field were gathered by the spectrum techniques of infrared, Raman, visible, ultraviolet and X-ray lights, which may give an insight into molecular and atomic structures of water. It was found that some properties of water were changed, and a lot of new and strange phenomena were discovered after magnetization. Magnetized water really has magnetism, which has been verified by a peak shift of X-ray diffraction of magnetized water +Fe3O4 hybrid relative to that of pure water + Fe3O4 hybrid, that is, a saturation and memory effect. The study is being reported in the November 2008 issue of Science in China Series G- Physics, Mechanics & Astronomy because of its significant values in science and extensive applications in industry, agriculture and medicine.
          Mstate Water
          Rare Masers -Cosmic 'Water Fountains'- Discovered
          Three new water masers have been discovered in the Milky Way
          find out more news on magnetism here:
          NASA's Cosmicopia -- Basics -- Magnetic Fields
          • Originally posted by IndianaBoys View Post
            MonsieurM,,
            Thought Jacques Benveniste would be a good addition to your collection.
            Dr. Jacques Benveniste digibio part1 of 2
            YouTube - ‪Dr. Jacques Benveniste digibio part1 of 2‬‏
            Dr. Jacques Benveniste He claims that the "structure" of biochemicals can be impressed on water electrically using white noise and coils, and then the water will display some of the activity of the original biochemical.
            IndianaBoys
            IndianaBoys, hope to hear from you soon
            As I was reviewing the various threads, i noticed i have not yet watched your post; but it is in complete accordance with
            Luc MONTAGNIER DNA Teleportation
            A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
            According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
            Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
            note: looks to me that a zone of activation (zone of resonance ) was created then the dna transfer was accomplished
            • This is probably one of my favorite moments,when you find a nugget....
              i found this info here: (the cosmic egg )
              Method & Apparatus for Splitting Water Molecules Dr. Andrija Puharich M.D
              Method and apparatus for splitting ... - Google Patents
              and Schauberger's Cosmic Egg
              wow
                transfered info from the tree as radiant antenna thread:
                Kelvin water dropper
                Kelvin water dropper - Wikipedia, the free encyclopedia
                note: you could try coils instead of a conducting ring, mash up time
                also:
                you could try also a water/methanol mixture Kelvin Experiment
                each drop of water/Methanol Mix is a tiny capacitor that will discharge its energy when it hits the bucket
                (see: Velocity Compression in Cylindrical Capacitor Electrospray of Methanol-Water Mixtures)
                or just a water/methanol Capacitor to charge the energy produced by the electrostastic created by water (or water/methanol) drops
                YouTube - ‪Lord Kelvin Water Dropper/ Schauberger Waterthread Experiment‬‏
                Schauberger take on Lord Kelvin Experiment
                YouTube - ‪The Extraordinary Nature of Water -Viktor Schauberger 6/6‬‏
                Dielectric Study of Water-methanol Mixtures for Use in Pulsed-power
                Looks like something went wrong... The link you have may be incorrect, or the page you're looking for may have been removed or renamed. Try using the site's menu to locate the page. Try using the site search to search for the page by name. Try starting from the homepage. If that doesn't work, use this form to let us know what you were looking for, and someone will get back to you shortly.
                also used in engines
                http://en.wikipedia.org/wiki/Water_injection_(engines)
                I'm going to try the Kelvin Experiment using acid water on one side and alkaline water on the other (for experimentation sake )
                note:
                Have you tried the Kelvin Experiment on your M state Water?
                the point I am making here, is that besides Schauberger, people tend to overlook the nature of water.
                I wonder if you took the water after it ran through the Kelvin experiment kept it isolated and froze it, the ice should be negative or positively charged depending which you froze.
                Might make a good experiment.
                  MonsieurM,
                  Astronomers Find Largest, Most Distant Reservoir of Water
                  NASA - Quasar Drenched in Water Vapor
                  This artist's concept illustrates a quasar, or feeding black hole, similar to APM 08279+5255, where astronomers discovered huge amounts of water vapor. Gas and dust likely form a torus around the central black hole, with clouds of charged gas above and below. X-rays emerge from the very central region, while thermal infrared radiation is emitted by dust throughout most of the torus. While this figure shows the quasar's torus approximately edge-on, the torus around APM 08279+5255 is likely positioned face-on from our point of view.
                  IndianaBoys
                  Diamond planet discovered by astronomers | MNN - Mother Nature Network
                  University of Technology in Melbourne, Australia may have just discovered the supreme BFF: an entire planet made of solid diamond, according to a report by New Scientist.
                  The planet is orbiting a pulsar about 4,000 light years away and represents some serious bling. Astronomers estimate that the planet is only slightly less than 60,000 kilometers in diameter and has a mass roughly equal to that of Jupiter
                  • from a link provided by Dave45 :
                    Anomalous properties of water
                    Water phase anomaliesWater density anomalies Water material anomalies Water thermodynamic anomalies Water physical anomalies http://www.energeticforum.com/152708-post377.html
                    • Hi
                      Another interesting thing I found out about water is this:
                      In Celsius the freezing point to boiling point of water is scaled from 0 to 100, and the human body's interior is 37 degrees of Celsius. This actually marks the scale of vibrations liquid water molecules can possess. The golden mean is 0.618 and 37 degrees is very close to 38.2. Therefore This satisfies very closely the golden mean ratio, so that our body temperature or water molecule vibration is somewhat in golden mean ratio relation to the vibrational scale of liquid water?! Does this mean something? It is said that this temperature is vital to maintaining balance inside the body, as 1 or 2 degree of Celsius vibrational change in the molecules of water just causes fever and extreme discomfort.
                      Elias
                      http://blog.hexaheart.org
                        water and photons is the origin of life
                        - Pollack G.H. Water structuring at interfaces - EZ water "exclusion zones"
                        Pollack Laboratory - Water Science
                        video
                        Water, Energy, and Life: Fresh Views From the Water's Edge - UWTV.org
                        Pollack G.H. Water structuring at interfaces. Pt.1 - YouTube
                        Pollack G.H. Water, Energy and Life - YouTube
                        - water is source of free energy close to the "exclusion zones" you can collect it
