I notice that John Bedini twists all of his wire together before building his coils. Is there an advantage in doing this? If so, are there any how too's out there, as it seems quite tricky to twist 200-300 foot lengths of wire with a drill.
To twist or not to twist, that is the question
Hi WoodskiOriginally posted by woodski View PostI notice that John Bedini twists all of his wire together before building his coils. Is there an advantage in doing this? If so, are there any how too's out there, as it seems quite tricky to twist 200-300 foot lengths of wire with a drill.
Just spectulation, but it may be to loosen it up and make it more pliable when bending it around the coil form.
BizzySmile it doesn't hurt!
Jesus said,"...all things are possible through God." Mk10:27
this is a video i found a while back. this guy has his set up to wind up to three wires twisted onto one coil and count the number of turns as it winds. it's pretty awesome, but would take a little bit of time to buildOriginally posted by woodski View PostI notice that John Bedini twists all of his wire together before building his coils. Is there an advantage in doing this? If so, are there any how too's out there, as it seems quite tricky to twist 200-300 foot lengths of wire with a drill.
hope this help. besides a jig like this, it would take unwinding a lot of wire, then twisting it then coiling it back up, which would be a pain
N8
YouTube - Trifilar Coil JigThe absence of proof is not proof of absence
It is my understanding that twisting wires causes self canceling fields. I wouldn't bother twisting small SSG coil. You wont see any difference. However, for more powerful setups I would do that. I have twisted wires in all my bigger devices, up to 8 strands but only 100 -150 feet.Thickest was AWG#18.Originally posted by woodski View PostI notice that John Bedini twists all of his wire together before building his coils. Is there an advantage in doing this? If so, are there any how too's out there, as it seems quite tricky to twist 200-300 foot lengths of wire with a drill.
You can twist from both ends keeping drill in forward position (clockwise). Gym in local school can be handy but not for 300'.
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Here are some info on it that John bedini posted somewhere.
"Your coil needs to be wound in such a manner as to hold the "magnetic field inward" so nothing can get out, one litz wire will do the trick or just wind it that way.
You can do this one of two ways, you can try to wind this as you put this on the coil or you could just tie the wires to a tree or something, walk 150 feet away and twist it with a drill as tight as you can."
You can find it here.
Yes, I have this in my JB notes tooOriginally posted by nvisser View PostHere are some info on it that John bedini posted somewhere.
Thanks for posting this nvisser
That makes perfect sense.
Litz wire - Wikipedia, the free encyclopedia
Read it all but especially read the last paragraph under skin effect.
Matt
How to Wind A Coil
if you are winding a Bedini coil I should be longer that 65ft but everything else should apply How to Wind A Coil
Tecknomancer
Zeropointfuel.com
65ft
Yea most people don't get it.. they even have told me it wont workOriginally posted by woodski View PostOnly 65ft. Most people talk about 150-175ft. Even on the linked video it says that if you want to capture alot of radiant energy you need more.
but because the trigger time is so short and the Cartmotor operates at 120v there is a radiant element to it just not as big, but I can get 10 to 40 amps into the 275amp hour battery bank so it works perfect for me, I have a small Bedini charger with 150 ft coils but most of my work is about torque so it just how it works for me "always build your first motor to Bedini specs so you have a good grasp of the technology"
CartMotor 4.0 Coil Test
Cartmotor V5
Tecknomancer
Zeropointfuel.com
