Ok a little bit of research and I think I found out what I did wrong. This explains the extreme voltages I was seeing in the tank cap at some points and how I was able to get fluro's to light dimly with 50 Ma input.
Dual Resonant Solid State Tesla Coil - HvWiki
Quote from the wiki, i'll bold a bit of it.
I have to do some calculations and thinking about how to harness this problem child.
There must be a way.
This is using the CEMF to add to the EMF. It should be able to be used in a fixed speed motor generator too. Like a Muller.
Cheers.
A DRSSTC is different than the conventional SSTC due to the addition of a primary tank capacitor, hence, "Dual Resonant." When in a resonant state, the added capacitance in the primary circuit cancels the inductance leaving no reactive component. Primary current flow is now only limited by resistance in the capacitors (ESR) and resistance in the primary windings, which is usually on the order of a few hundred milliohms. In a SSTC, primary current is limited by the primary's inductance and streamer loading. This is the reason a SSTC can run CW or "continuous wave". So a key difference between SSTCs and DRSSTCs is that a DRSSTC usually operates in the transient state, while SSTCs can safely run in the steady state conditions. However, if you were to drive a DRSSTC at it's resonant frequency for too long, a steady state current of many times the safe limit might be possible. This could have the following adverse effects
IGBTs blow from overcurrent - this would happen almost instantanly (few mS) depending on the size of the IGBT.
Overvoltage of the primary capacitor - The extreme current flowing over the primary tank can create voltages tens of times more than the supply voltage. (use Ohm's law to figure out just how high)
There must be a way. This is using the CEMF to add to the EMF. It should be able to be used in a fixed speed motor generator too. Like a Muller.
Cheers.
Must be Antigravity?
Nah it's just stuck in a hole.
. You can feed parallel tanks with pulsed DC but they dont have the voltage multiplication they have current multiplication.
Maybe
these pics are the best lighting I've had so far. It's a 550mm tube 18 watts.
