I've been really impressed by the level of knowledge on display here and other similar sites. But as my username suggests I'm kinda clueless in this field. In a previous life I worked maintaince in an industrial setting and also repairing and painting cars.
In Dec of '97 I suffered the 1st of four heart attacks, the 2nd in '03 put me on disability. The last one was in '06.
The reason I bring this up is threefold. First the heart attacks caused some brain impariment and with time I have misplaced a lot of former knowledge on these subjects. Second I had to sell $10,000 of my tools for pennies on the dollar while waiting on disability. And third after 3 heart attacks in 3 years ('0-'06), in '06 I begin to follow an inner guidance. Since then I haven't had another HA. Bascially I listen to professional advice mixed with my intution and formulated a hybrid plan.
I have a friend who is an electricial engineer who lent me some stuff to play with and I bought a science kit to learn circuits. And I have been fashioning a workbench in the LR (ours is a confined space)to lay the circuits on.
After reading through hundreds of pages on threads her and OU and other similar sites and following several youtube series along with my friend ( the engineer) some knowledge(from the past) is returning.
I have had two ideas come to me from out of the blue actually from dreams and from my experience with intuitive prompts on my health I don't dismiss them lightly.I hoped someone here can either (a)critique these ideas and (b) build them to see what the results are.
I intend to, but I have to gather resources and learn simple circuits first and time I believe is short. I don't care who gets credit as long as something is accomplished. Especially so if it is quick, simple, cheap and it works. I really feel that more people needs to become free of the grid, the energy grid, economy grid and medical grid as I don't fully trust any governments.
The first is a vision of looking down at a board (wooden?) with nails/pins? drove in a square pattern on this board. Wire is wound around these "pins" and fashions what I assume is a square coil. Though it could be anything.But I'm certain the wire is wrapped around each pin (for grip?) and that there are several windings. I'm not sure about the spacing between each row as I only "saw" it from above. I'm not even sure if anyone has ever wound a square coil or what the properties of such a design might be or how to use it. I'd appreciate any ideas you have.
The second though is more complete and seems so simple I can't believe it will work but it will only a minimum of parts and time to test.
Can someone tell me why you couldn't take a piece of plastic pipe and screw on caps and a rod of either plastic, metallic; hollow or solid and place it inside. On either end of this rod fasten a magnet and on the end caps fasten a magnet with the same poles facing. Would they not then repel and travel to the other end where again it would be met with repulsion and move back? Then couldn't you wrap a coil around the pipe and generate electricity with this back and forth motion? I do realize the magnetic force would have to be unequal or the rod would just tremble in the middle. I don't know but that could be benefical? Anyway it seems to me that you could put magnets of different strenghts on each end or a spring on one end or both to counteract the tendency to equalize. Or introduce some type of intermittent shielding effect.
To be honest this "pipe" motor is part my imagination and part vision. The "pipe" was what I dreamed and I supplied the magnets. Could be the "square coil" and the pipe somehow fit.
So can anybody supply any thoughts to help me make sense of it these two items or the pipe and magnet motor?
Thanks again
-RG
Thanks again
-RG
