Can anyone build a magnet generator?
Has anyone or can anyone truly BUILD a continuous MAGNET GENERATOR?
Things to research
One name to research is Perendev. Another is Matthew Jones. I'm not 100 percent convinced, but am open to the possibility. A healthy scepticism is warranted. There are many proposed explanations for the effects that have been witnessed. Second point: You may need to explain exactly what you mean by magnetic generator. For example, do you mean a generator of electricity that incorporates magnets in its design? This is typical. Or, for example, do you mean a machine that derives its primary motive power from magnets to generate mechnical power? Question 2: Does a positive answer imply over unity? Perhaps one could have a magnetic generator entirely within the accepted laws of physics? Consider all these angles. Third point: What do you mean by anyone? For example, I know several individuals that can't add 2 + 2. I sure don't expect them to build ANYTHING. On the other hand, there is nothing stopping you from trying. Are you afraid of Big Brother? If so, go hide yourself.There is a reason why science has been successful and technology is widespread. Don't be afraid to do the math and apply the laws of physics.
There are umpteen thousand different "magnet generators". Magnet motors use magnets passing by coils to create a magnetic field which collapses causing back EMF, a very high voltage pulse consisting not primarily of electron energy but mainly photonic and anti-photonic energy. This can be routed through an appropriate circuit such as John Bedini's SSG circuits. This energy can then be used to charge batteries/capacitors or go through anything that uses high voltage pulses, like spark plugs. This energy is not ideal for directly running most appliances, but batteries charged with it are. This is an example of a magnet motor generator. You can also find ways to run the motor off the high-voltage spikes to make the motor apparently run until it eventually breaks down. This gives the appearance of a perpetual motion machine, but don't be fooled, it does have a source of energy other than what you put in. This source is best explained as the energy that magnets pull out of the environment. It has been described as many things: Aether, Dirac Sea, Virtual Photon Sea, the "fabric" of "space-time", etc. If you are a spiritual person it is somewhat synonymous with the Breath of Life and Prana/Kasha.
To get back to your question, here are some people who made "magnet generators":
Nikola Tesla
John Bedini
Bruce DePalma
Bob Teal
and there are many others who have replicated and expanded their research including:
Peter Lindemann
Rich Friedrich
and the countless usernamed garage kids of our generation
All of these people are somewhat involved in what has been dubbed the Free Energy Movement. Its based on using relatively inexhaustible fuel sources including ambient electromagnetic or aether, stuff like water powered generators, ambient heat, and combining these with other outdated technologies like wind, geothermal, wave, nuclear, etc.
Go ahead and ask me for details on any which one.
