Originally posted by snowinidaho
I have no way of measureing the BTU's. The torch is nade of a simple 10mm diameter copper pipe with a steel or copper mesh attached to the birning end. The gas needs to go through the mesh, but no flames can go back through the mesh, because the burn rate is very slow.
Thanks for this info
Yes PE will give mostly paraffin which is still great for using in your diesel burned, you only need to heat it a bit. If this paraffin is put through the process again, about half of it will become clear liquid fuel and other half will be a bit denser paraffin that will now melt at higher temperatures. Another time through the process will make almost all contents of the reactor into liquid fuel, but the remaining paraffin will now be just as candle wax, will burn the same and smell the same. So you can also make your own candles
