Originally posted by Jordan14
If you can't rise the temperature of the reactor to 440-450C (the reflux will heat by vapors and maybe you should cool it down to at least 320C. But it is possible that a temperature balance will be established by vapor flow at 300-315C, the best interval), try a heat insulation for the reflux.
In my experiment of PE cracking, till 440C at the reactor there was no noticeable oil in the condencers. The temperature of the reflux didn't rise at all, because there was no cracking yet, so no vapor flow, so no convection heat transfer to reflux! The reflux's temperature rose very slowly for at least two hours, and all this time the entire meager amount of the diesel fraction could not escape the reflux column due to lack of temperature. It was re-cracked and therefore formed a little gasoline fraction. The reflux temperature was already about 200C. Then, when the reactor temperature reached 450C, the degree of cracking increased almost instantly, the reflux temperature began to increase rapidly due to the rapid flow of hot vapors, and at 320C instead of liquid, a wax appeared in the condensers.
